Audio Performance
More pleasant news: the H3 sounds wonderful. It's certainly not a flat response akin to studio monitors, but the 'dipped' EQ here exaggerates the bass and high frequencies without compromising clarity or pushing the EQ shape so far that it sounds artificial. You get a sturdy low-end response in games, movies and music and a perfectly usable mix for competitive games like Counter-Strike:Global Offensive (CS:GO) and PlayerUnknown's Battlegrounds (PUBG) without having to switch between profiles, turn surround sound on or off, or any other messing about. The all-important footsteps and weapon-switch sound cues cut through, and there's no need for a special 'gaming' mode, as other headsets employ.
I think a lot of the sound quality's success comes from its comfortable fit. Because the sound isn't leaking out anywhere around your ears, low-end resonant frequencies are voiced in the snug chamber around the ear without losing power. And the leatherette contact point material only helps that cause, creating a seal, rather than a breathable mesh.
The Ultrasone Meteor One appear to be less suitable for ambitious gaming sessions on the computer or console, apart from the voice quality of the microphones. However, these wireless over-ears have the potential for use as versatile everyday headphones that provide a coherent, powerful sound when listening to music, watching films, gaming on a mobile device or exercising. With their foldable design, weatherproof finish and long-lasting battery, these headphones are ideally equipped for this kind of use.
Ja imam priliki da kupim ove vrvt bi mi lik dao za 110 eura (MMX 300 Gen 2 koristene).Verovatno si video i u onom klipu iznad da skoro svi hvale PC38X, posebno kao gaming sluške. E sad, ne znam koliko bi na kraju koštale, sa slanjem i dažbinama.
Ali postoji i dobra alternativa, u poznatoj domaćoj prodavnici (27.480 din, oko 233€, što i nije loša cena s obzirom da trenutno na Amazonu koštaju $269) - Beyerdynamic MMX 300 (2nd Generation)
Vidim da si iz NS, tako da postoji mogućnost da ih probaš pre kupovine, u P prodavnici, što je uvek najbolja opcija. Poredim okvirnu cenu PC38X sa dažbinama (220$), i ovih 233€ ali sa domaćom garancijom od 2 godine.
https://www.igorslab.de/en/so-must-headset-beyerdynamic-mmx-300-2-generation-in-long-term-test/2/
https://www.techpowerup.com/review/beyerdynamic-mmx-300-2nd-generation/
https://www.pcmag.com/reviews/beyerdynamic-mmx-300-2nd-generation
https://www.pocnetwork.net/product-reviews/beyerdynamic-mmx-300-pro-gaming-headset-2nd-generation/
https://latestintech.com/beyerdynamic-mmx-300-gen-2-review/
Nisam probao ni PC38X, ni MMX300 II, ali mi (na osnovu testova i utisaka) deluje da bih ipak pre kupio Beyerdynamic.
To je neki moj subjektivni utisak na osnovu testova, da su zvučno malo bolje, i robusnije-kvalitetnije izrađene, samim tim i trajnije, ali možda i grešim.
Pošto sam pre par meseci isto odlučio (Oluv sa YT uticao dosta) - zanima me koje podešavanje za EQ koristiš? Mogu se razna naći na netu, velike su razlike između njih.Na kraju sam uzeo Soundcore Life Q30. Imaju ANC, 3.5mm i USB-C, baterija je u rangu ATH (60 vs 70h).
Nisam neki audiofil pa da mogu da procenim neke detalje... Imam B&O H5 i ATH-ckx5 i zadovoljan sam kako zvuce Q30 - uz podesen EQ.
E ja sam ovo koristio:Pošto sam pre par meseci isto odlučio (Oluv sa YT uticao dosta) - zanima me koje podešavanje za EQ koristiš? Mogu se razna naći na netu, velike su razlike između njih.
Znam da treba svako sebi da prilagodi, ali eto, ako već ima gotovih rešenja što da ne.
Koje si probao jos?Taj mi najgori.
Nemam nesto konkretno da kazem ovo mi je bolje ili ne, svejedno mi je, oba su mi dobra
