Negde sam zapoceo temu oko brzine ucitavanja SC2 na HDD-u vs. SSD-u pa nisam mogao da isprobam tada jer je HDD bio encrypted.
Formatirao sam ga, sada je normalan HDD u eSATA kucistu. Obican 5400rpm laptop HDD, 80MB/s max. read/write cca, znaci nista specijalno. Poredjenje sa C300/256 koji je "glavni" SSD u laptopu (znaci full-speed @SATA2, nije na USB ili u nekoj fioci )
Nema nikakve razlike da li se ucitava igra i nivo sa HDD-a i sa SSD-a. Odziv je dosta bolji na SSD-u doduse, tj. bilo je trenutaka kada je igrica zastala kao kad vam net secka online game
Provericu jos jednom posle restarta, dve stvari su radjene u to vreme koje mogu da uticu na to (bio je ukljucen PF i kopirao sam podatke nazad na taj HDD ).
Mislim da seckanje nije tipicno ni za koji HDD, tako da je brzina sasvim ista (bukvalno nije bilo razlike u brzini load-a i posle restarta, znaci bez cachiranih podataka sa HDD-a).
Mogu i Warcraft 3 da poredim, ali ako tu vidim razliku idem odmah da se prijavim kao zamena Data-i iz StarTreka jer sam W3 igrao jos na P3 racunaru
Source/reviewThe Samsung 830 features a 3-core MCX controller, 2x nm Toggle MLC NAND, 256MB SDRAM cache and firmware, all made by Samsung.
Koji NAND je u Samsung 830 od 128GB i 256GB?
I u Crucial modelima istih kapaciteta?
Micron Technology, Inc. (NASDAQ: MU) is an American multinational corporation based in Boise, Idaho, USA, best known for producing many forms of semiconductor devices. This includes DRAM, SDRAM, flash memory, SSD and CMOS image sensing chips. Consumers may be more familiar with its consumer brand Crucial Technology and retail subsidiary Lexar Media.
Kingston To Cut Prices of NAND Flash-Based Products
Memory industry major Kingston is working towards reducing prices of its products that are based on NAND flash memory. This includes a large chunk of Kingston's product portfolio, as the only products excluded would be DRAM. NAND flash-based products include memory cards, USB flash drives, and SSDs. Kingston will reportedly cut prices by as much as 15 percent. Responding to a DigiTimes report, Kingston said that it is adjusting its NAND flash product pricing to coordinate with the rest of the industry to shift towards more advanced processes, and that it wants to enhance its presence in the NAND flash market. In other words, Kingston is clearing its inventory to make way for newer, more advanced technology.
"...., the fact that we're still able to reproduce a BSOD on the latest publicly available SF-2281 firmware but not on the SF-2281 based Intel SSD 520 does say a lot about what you're paying for with this drive."
As luck would have it, our own Brian Klug happened to come across an unexpected crash with his 240GB non-Intel SF-2281 based SSD two weeks ago when he migrated it to another machine. The crash was an F4 BSOD, similar in nature to the infamous BSOD issue from last year. While two of the systems we reproduced the BSOD bug on were cured by last year's firmware update, Brian's system (an X58/Core i7 build) was BSODing regularly playing Battlefield 3. Games end up being a great way to trigger the SF-2281 BSOD issue as they frequently switch between periods of idle and load, which does a good job of stressing the power state logic in SandForce's firmware.
Ma LSI se zaebo kad je stavio SF.
Napomena: This feature currently requires accessing the site using the built-in Safari browser.
