Kako kupovati aplikacije na Google Play?
Da li neko možda zna kada će i da li će Srbija i RSD biti dodati kao zemlja/valuta sa kojima može kreirati taj Family Library na Google Play?
Google support, nemam reči koji papci- proveo sam puno puno vremena sa njima na četu, zavlačili me sa nekim generičkim glupostima, trošili mi vreme..
pošalješ schreenshot gde se lepo vidi u čemu je problem, koji je tačno error code i oni postavljaju nebulozna pitanja ?!
i mogu ti reći da je moj ticket otvoren već 9ti dan i da još uvek nemaju odgovor, rešenje,.
mislim da oni ne znaju za taj problem, odnosno da je vrlo malo zemalja koje imaju taj problem, kao Srbija,i onda njihov support ne zna kako tačno da postupi.
dopuna ticketa - poslao sam neki dan:
Just to clarify that I am having problem with Family Sharing, exactly with Google Play Family Library - I can not activate it. Sign-up process fails on "Set Up Family Payment method" step.
Error message:The selected currency and Country of RS/RSD are incompatible OR-IDGRA-02
I have created family group few days ago, My account is family manager, I have Visa and Master card set up in the past, and multiple Mastercard payments successfully were done in the past. Also Visa verified payment.
So don't know why Country currency problem happens in this particular case?!
njihov odgovor:
Thank you for writing back to us.
As I have informed you earlier, the issue has been escalated to the specialist team, currently they are reviewing your issue.
I will get back to you once I have an update from them.
If you have any concerns, please feel free to reply to this email and I would be glad to assist you.
Ima li pomaka za Google family payment method u Srbiji? Kod mene i dalje ne radi...
Da li prilikom kupovine aplikacije na Google Play-u, Google šalje prodavcu broj debine/kreditne kartice?
Prodavac je Google Play, oni prodaju i tudju u svoju robu, vlasnik aplikacije se naplacuje od njih.
Је ли овај проблем решен у међувремену? Добијам исту грешку.
Ne. Programer te samo razlikuje prema ID-u Google naloga, odnosno ID-evima uređaja. Na praktičnom primeru, ako si koristio probni period, gubiš pravo sa drugim uređajem, bez obzira što si odatle uklonio (još neki drugi povezani) nalog, ali se ID uređaja već uvezao sa Google nalogom. Rešenje je vratiti ga na fabrička podešavanja ili koristiti drugi uređaj što nije imao dodirnih tačaka sa određenim nalogom koji nije do sada povezivan i na njemu dodaš platnu karticu koju ranije nisi upotrebio.
Pitanje vezano za valute, da li jedino promenom zemlje u podesavanjima Google Play mogu da promenim valutu iz RSD u Eur?
Imam neki subscription koji treba da platim, a nemam dinarsku karticu kod sebe da to obavim, a znam da ce me odrati konverzija ako sa devizne platim... :)
Da li vam radi kupovina icega preko Google Playa za dete koje je u FamilyLink? Dete mi se na glavu pope da joj kupim za jednu gricu neku sitnicu ali nisam nasao nacin kako to da izvedem. Znam da je ranije bilo prakticno nemoguce to kod nas pa rekoh da pitam kakva je sada situacija.
Radi ali samo sa deviznom karticom. U koliko pokusam dinarskom dobijem onu poruku RS\RSD incompatible.
a kako dodjes do kupovine?:) moze korak po korak?:)
Pa sto kao i kad ti izbaci onu gresku, bitno je samo da platiš deviznom karticom.
Sta da radim nakon ovog? Ne dodjem do kartice uopste a nemam nikakvu notifikaciju na svom telefonu
    56.9 KB · Pregleda: 16
Na svom telefonu bi trebalo da nastelujes payment method za family. Ne znam tacno ali mislim da je tako. Sa debitnom izbacuje onu gresku.
Au i dalje ovo nije reseno.
To je bilo i pitanje, kako da nastelujem?:)
Pa napisao sam ti, na svom telefonu u payment methods u aplikaciji.
Upravljanje porodicom pa ides jednom na strelicu unazad i gore se pojave plaćanje i pretplata tab.
P.S. to je za moj nalog, ne mogu sada da nadjem gde je za porodicu 🤣
Trebalo bi da je u goigle play ali nemam vremena sada da cackam.
