Game features :
Game engine:
Physical simulation & improved animations:
Take advantage of PhysX™ supporting the vehicle simulation, in-game interactions and the revamped animation system.
Volumetric clouds
The net code is beeing optimized.
4 times more detailed ground textures
Improved Data-Streaming
Improved micro AI and pathfinding
Improved water simulation (visually as well as physically)
Blending from animations to ragdoll
Higher particle limit
More audio samples
New scripting technology
New lighting tech/HDR ( JC twitter feed)
JAVA
Render to Texture
Improved lighting tech
Artistic direction:
The game will feature more powerfull sounds, similar to popular sound mods.
Heat haze effect
Gameplay:
Customizable Soldier Load:
Choose your uniform (2), assemble your weapon kit, change your loadout, get loaded up.
Multiplayer Gameplay:
Challenge both cooperative & competitive scenarios with full support of dedicated servers for both Windows and Linux.
Completely Extensible & Moddable:
Design & create countless customizable scenarios using the intuitive & easy-to-use mission editor.
Underwater operations now supported (2)
HALO
All the buildings on Lemnos are enterable and can be destroyed. .
Weapon modification on the fly is now possible.
The game will feature a 3D editor.
Action menus will be improved
Helicopter sounds will be on par with the ones in TOH.
The game will include the Take On Helicopters flight model, however it will not be avaiable in the main SP campaign.
The Mk8 SDV will have a periscope.
The player will be able to attach explosive charges to enemy boat huls and other vehicles.
The player will be able to remotely operate mortars .
Helmet mounted cameras
Objects like tactical vests will have weight and different carrying capacities.
Headgear will offer different levels of projectile protection.
PvP will be improved.
The game will feature an improved wounding system (no specifics for now
Improved MP interface
Improved command interface
The player will be able to wear civilian clothes
Hands now move with the steering wheel.
Different muzzle flash samples
Grenade launcher zeroing works like in real life.
There will be a dropdown menu in the editor where you can customize your soliders gear such as camo,headgear, balistic vest and backpack.
Fastroping will be suported.
Shockwaves will be simulated.
Different camo-types ( urban etc)
Your loadout will affect your mobility- enhanced fatigue system
Iimproved UAV's
Iimproved artillery system- set the angle etc manually
Vehicles can now be towed.
Micro UAV's that can be deployed on a squad level.
Some weapons platforms can be operated remotely and some can function on their own.
All the stationary armament can be dismantled and transported by troops or vehicles.
The MP chat system will be improved.
Modular vehicle turrets
Multiple types of 45 mm rockets ( in AA,AT,AP)
Working mirrors and MFD's
ArmA 3 will feature backward compatibility, meaning that people should be able to get older assets into Arma 3.
