»RSS Benchmark sajt
      Strana 159 od 166 PrvaPrva ... 59109149155156157158159160161162163 ... PoslednjaPoslednja
      Prikazani rezultati od 2.371 do 2.385 od ukupno 2478
      Tema: Ventilatori
      1. #2371
        Member
        Na forumu od
        Jan 2016
        Poruka
        923
        Propratna oprema za novo kuciste
        Poslato sa HUAWEI VNS-L21 pomoću Tapatoka
      2. #2372
        Member Avatar korisnika KOLOS
        Na forumu od
        Nov 2007
        Poruka
        2.187
      3. Moja mašina
        • CPU: i7-8086K | EK-Supremacy EVO
        • MoBo: Asus ROG Strix Z370-E
        • RAM: G.SKILL Trident Z 4000 16GB
        • VGA: GTX 1070 FE | EK-FC1070GTX
        • MON: AOC Q3279VWF
        • HDD: Samsung 970 EVO M.2 500GB
        • Case: Fractal Design Define R6 TG
      4. Uzeh i ja P12 za 25e, hoću da ih probam na radijatoru umesto EK Vardar ventova.
        Click image for larger version.
ID:	274201 Click image for larger version.
ID:	274202 Click image for larger version.
      5. #2373
        Member Avatar korisnika ivanbass1
        Na forumu od
        Apr 2016
        Lokacija
        Nis
        Poruka
        7.657
      6. Moja mašina
        • CPU: Ryzen 5 2600@4.0GHz, LC-CC-120 Push/Pull
        • MoBo: Msi X370 Krait Gaming
        • RAM: G.Skill Aegis 2x8GB 3000MHz CL16
        • VGA: RX 470 Sapphire Nitro+ 4gb
        • MON: AOC Q3279VWFD8
        • HDD: Patriot Ignite 240GB, WD Blue 500GB, Toshiba P300 3TB
        • OPT: Izbaceno zbog beskorisnosti
        • Case: MS Falcon 2x Arctic F14, 3x Arctic F12, Antec VP700P
        • SND: Microlab Solo 6C, Hyperx Cloud II
        • OS: Windows 10 64bit
        • LAP: Asus Vivobook Pro (i7 8750H, 2x8GB, GTX 1050 4GB, 1080p IPS)
        • Ostalo: Redragon Usas K553+Logitech g400s, Sandberg XXXL
      7. Ovaj dan treba zabeleziti u kalendaru kao crveno slovo
      8. #2374
        Na forumu od
        Nov 2007
        Poruka
        2.187
      9. Moja mašina
        • MON: AOC Q3279VWF
      10. I obavezno da se posti na vodi.
      11. #2375
        Member Avatar korisnika Accuphase
        Na forumu od
        Jan 2002
        Lokacija
        Germany
        Poruka
        926
      12. Moja mašina
        • CPU: AMD Ryzen R5 1600 & Alpenföhn Ben Nevis Advanced
        • MoBo: ASUS Prime X370-Pro
        • RAM: 2 x 8 GB Corsair Vengeance RGB DDR4-3600
        • VGA: Sapphire Nitro+ RX580 8GB
        • MON: AOC Q3279VWF
        • HDD: Crucial M550 256 GB (sistem), Toshiba 3 TB
        • OPT: DVD±RW LiteOn iHAS124
        • Case: be quiet! Pure Base 600 & Seasonic Focus 650 W Gold
        • SND: Zero DAC 24bit/192 kHz & Philips Fidelio X1
        • OS: Windows 10 Pro x64
        • LAP: HP 350 G2
        • TV: PHILIPS 47PFK4109/12
        • INET: DSL
        • Ostalo: Logitech G105 & G602
      13. Citat Citiram korisnika: jurodivi Pogledaj poruku
        Zanimljivo kako se ponaša Arctic P12 PWM...za max obrtajima je u prva 3, na 1000 RPM prosečan, na 500 ponovo dobar...s obzirom da je 5-pack 25€, fantastično. S druge strane, za upotrebu u kućištu bi se vrteo otprilike u rejonu oko 800-1000 RPM, što mu je slaba tačka...ali za CPU kulere i radijatore gde bi išao na više od 1000, je odličan izbor.
        Der8auer je naveo Arctic P12 PWM u testu kao model među prva 3 (od 4:00 priča o njemu), mada nije naznačio po kojim kriterijumima, pretpostavljam po odnosu protok vazduha/buka.
        Ako bi se gledao ukupni rezultat (protok vazduha/buka/cena), verovatno je Arctic P12 PWM apsolutni šampion testa.
        Takođe je šteta što nije naveo koja su to dva ventilatora još među prvih tri na testu (ako je Arctic jedan od njih), i koji je redosled istih.
        Test je specifičan, ne znam koliko ima veze sa praksom, na počeku videa objašnjava kako je radio test.
        Napravio je dve spojene komore, u prvoj se nalazi testirani ventilator i mikrofon, uz to i radijator (po potrebi).
        Ventilator potiskuje vazduh ka drugoj komori, u kojoj meri protok vazduha, tj. koju količinu izraženu u m³ potiskuje ka njoj.
        Jedan od korisnika je postavio komentar sa timestamp ka rezultatima, koji je CaseKing zakačio na vrh, tako da se može direktno brzo doći do tabela.
        3:03, kao ventilator za kućište, 100% brzina, zaista lep rezultat za Arctic P12 PWM (74m³, 52dba), bolja je samo Noctua NF-A12X25 PWM (80m³, 48dba) i Corsair LL120 RGB Dual Light (99m³, 61dba).
        Cena (trenutno najjeftinija ponuda sa Geizhals):
        Arctic P12 PWM PST: 5,19 €
        Noctua NF-A12X25 PWM 27,45 €
        Corsair LL120 RGB Dual Light 24,80 €
        Cena govori sve, za Corsair ili Noctua mogu se kupiti 5 Arctic.
        Kome treba ultimativni protok vazduha u kućištu, bez obzira na buku i cenu, top 3 sa tog testa bi izgledala ovako:
        1) Corsair LL120 RGB Dual Light
        2) Noctua NF-A12X25 PWM
        3) Arctic P12 PWM PST
        Top 3 buka/protok vazduha:
        1) Noctua NF-A12X25 PWM
        2) Arctic P12 PWM PST
        3) Corsair LL120 RGB Dual Light
        Top 3 cena/buka/protok vazduha:
        1) Arctic P12 PWM PST
        Na 1000 obrtaja kao ventilator za kućište Arctic stoji odlično po pitanju buke (37dba, 39m³), jedini koji može da mu parira je Noctua NF-A12X25 PWM (isto 37dba, uz veći protok vazduha - 44m³).
        Slično se može nastaviti i sa 1000/500 obrtaja (kućište, radijator), da ne razvlačim temu u nedogled, redosled zavisi dosta od prioriteta koji su korisniku važni, da li je to buka, protok vazduha, ili cena, ili što je najverovatnije zbir svega.
        Menjao Accuphase : 31.08.2019. u 14:36
      14. #2376
        Member Avatar korisnika anarki1302
        Na forumu od
        Feb 2009
        Lokacija
        Gornji Milanovac
        Poruka
        1.678
      15. Moja mašina
        • CPU: Ryzen 3700X@4.2ghz 1.3v / CM ML240 LITE
        • MoBo: MSI B450 Tomahawk MAX
        • RAM: 16GB Patriot Viper Steel 3600C17@3800C16
        • VGA: Giga 1070ti Gaming OC
        • MON: BenQ XL2411z 3D 144hz
        • HDD: A-Data Gammix S11 PRO, Cuda 3TB
        • OPT: ...
        • Case: CM 690 III+Seasonic Focus Plus Gold 850w
        • SND: Logitech X-530
        • OS: WIN 10
        • TV: LG 32LH3000
        • INET: Kablovska
        • Ostalo: ...
      16. Posle 2 dana koriscenja p14 pwm pst, prezadovoljan sam. Kombinacija je 2 intake napred, 2 exaust gore.
        Razlika jedno 7-8c sto se tice temp grafe, a cpu ne mogu da kazem, jer sam promenio sve, tako da nije merodavno.
        Inace, zeznuo sam se i uzeo value p14, umesto p12, posto nemam bracket za Phanteks, pa ide na dobos, a AIO koji nameravam je 240mm, tako da cu imati 3 viska. xD
        Ne kazem da sam sveznalica,ali ovde ima nekoliko velikih neznalica...
      17. #2377
        Na forumu od
        Apr 2016
        Lokacija
        Nis
        Poruka
        7.657
      18. Moja mašina
      19. Javi se za dva komada, ako nemas kupca
      20. #2378
        Na forumu od
        Feb 2009
        Lokacija
        Gornji Milanovac
        Poruka
        1.678
      21. Moja mašina
        • OPT: ...
        • OS: WIN 10
        • TV: LG 32LH3000
        • INET: Kablovska
        • Ostalo: ...
      22. Imas pm
      23. #2379
        Member Avatar korisnika Erik011
        Na forumu od
        Aug 2012
        Lokacija
        Beograd
        Poruka
        3.058
      24. Moja mašina
        • CPU: Ryzen 3900X | EK-Magnitude blok
        • MoBo: Aorus X570-I Pro WiFi
        • RAM: 2x16GB 4000MHz CL19
        • VGA: GTX 1080Ti Aorus | EKWB vodeni blok
        • MON: AOC 32" VA i Dell P2414H
        • HDD: Samsung EVO 970 500gb | Samsung EVO 840 240GB | WD Red 4TB x2
        • OPT: Samo naocare, drugu optiku ne posedujem.
        • Case: Phanteks Entho Shift | Corsair SFX 600W platinum
        • SND: Integrusa ftw.
        • OS: win 10 Pro
        • LAP: ASUS Zenbook 14"
        • INET: Kablovska
        • Ostalo: Mnogo radijatora, pumpi i vode.
      25. Citat Citiram korisnika: KOLOS Pogledaj poruku
        Utisci?
        Voli dugačke šetnje po plaži, tunjevinu i custom vodena hlađenja.
      26. #2380
        Na forumu od
        Nov 2007
        Poruka
        2.187
      27. Moja mašina
        • MON: AOC Q3279VWF
      28. Još su u kutiji...
      29. #2381
        VIP member Avatar korisnika RingeRaja
        Na forumu od
        Mar 2005
        Lokacija
        BG
        Poruka
        4.792
        Šta ti smeta kod Vardara?
        Jesu li bučni ili ne hlade kako treba?
      30. #2382
        Member Avatar korisnika oaxacus
        Na forumu od
        Jan 2015
        Poruka
        165
      31. Moja mašina
        • CPU: X5450
        • MoBo: Asus P5Q Deluxe
        • RAM: 4gb Corsair Dominator
        • VGA: 6770
        • OS: 7
        • INET: Kablovska
      32. Dobri su Vardar ventilatori ali trazi se jeftinije resenje.
        Cekamo Kolosa da ih testira na radijatoru da li zaostaju za EK.
        Mada bi i Erik mogao neku malu recenziju da napise za EK Meltemi.
      33. #2383
        Na forumu od
        Mar 2005
        Lokacija
        BG
        Poruka
        4.792
        Rekoh da pitam, pošto treba da mi stigne EK 240mm radijator uz koji idu Vardari, pa rekoh da pitam šta da očekujem.
        Tko leti, vrijedi!
      34. #2384
        Na forumu od
        Nov 2007
        Poruka
        2.187
      35. Moja mašina
        • MON: AOC Q3279VWF
      36. Citat Citiram korisnika: RingeRaja Pogledaj poruku
        Nemam zamerki na performanse, odlični su.
        Od kvalitetnog su materijala, čvrsti, teški. Koristim ih već 3 godine, rade bez greške.
        Iz mog iskustva, bez nekog vida gumene izolacije ih ne treba stavljati na radijator. Prilično vibriraju(motor). Mnogo su prijatniji i tiši kada se izoluju:
        Ne sviđa mi se to što su double-ball bearing ventilatori malo bučniji od drugih, tj. imaju neki specifičan zvuk, "metalni", čak i pri niskim obrtajima.
        Ne sviđa mi se i to što je fan hub, tj. sam motor preveliki i stvara se "dead spot" kada je direktno na radijatoru bez shroud-a ili bar fan gasket-a(kao gore na slici) koji će ga bar malo odaljiti od jezgra radijatora.
ID:	274295 Click image for larger version.
        P12 ima mnogo manji motor, samim tim očekujem da se dobro ponaša i kada je direktno na radijatoru. Mada to zavisi i od samog radijatora, jer faktički svaki ima svoj shroud različite debljine:
ID:	274293 Click image for larger version.
        Od P12 očekujem da bude tiši, da motor ne vibrira i da ima solidne performanse, ne mora da nadmaši Vardar po tom pitanju.
        Što se tiče same izrade, završne obrade, čvrstoće, kablića, vidi se da nisu ista klasa kada ih držiš u ruci. Ali za 5e po komadu, ako se ispostavi da su stvarno tihi kao što se priča, zažmuriću na jedno oko.
      37. #2385
        Na forumu od
        Aug 2012
        Lokacija
        Beograd
        Poruka
        3.058
      38. Moja mašina
        • OS: win 10 Pro
        • INET: Kablovska
      39. Citat Citiram korisnika: oaxacus Pogledaj poruku
        Ja sam mnogo osetljiv na buku, tako da ja furam samo ove sto nemaju nikakav zvuk motora/lezaja.
        Cors ML120 i Noctua A12x25.
        Svi dual ball bearing ventilatori imaju zvuk lezaja, jednostavno taj tip lezaja je dugovecan, ali se cuje.
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
