»RSS Benchmark sajt
      Strana 105 od 166 PrvaPrva ... 55595101102103104105106107108109115155 ... PoslednjaPoslednja
      Prikazani rezultati od 1.561 do 1.575 od ukupno 2481
      Tema: Ventilatori
      1. #1561
        Member Avatar korisnika Kasa5033
        Na forumu od
        Aug 2013
        Lokacija
        Prijepolje-Beograd
        Poruka
        2.887
      2. Moja mašina
        • CPU: Intel i7-8700K Delid 5Ghz 1,32V
        • MoBo: ASUS Maximus X Hero
        • RAM: Corsair Vengence LPX 2x8GB 3000MHz CL 15
        • VGA: MSI GTX 1080 Gaming X ( ASUS HD 7970 DC II TOP rezerva )
        • MON: ASUS MG 279Q
        • HDD: Samsun 840 EVO 1TB + Samsung 860 EVO 1TB
        • Case: Thermaltake Core V51/ Cooler Master V700 700W 80+ Gold
        • SND: Hyper X Cloud I, Logitech Z333
        • OS: Win 10 Pro 64 bit
        • TV: Neki LG 32"
        • INET: Kablovska
        • Ostalo: Phobya G Charger 360mm V2, Alphacool VP655T+HF Top, Phobya Balancer 250 Black
      3. E to je vec drugi problem :/
        Sapphire R9 290 Tri-X 1250/1620 +200mV +50% power (3DMark Firestrike graphics score 14,421) [ MSI 9600GT 512MB GDDR3 650/756 ]
      4. #1562
        Member
        Na forumu od
        Mar 2011
        Poruka
        1.020
        Citat Citiram korisnika: gadafi Pogledaj poruku
        Da li još neko, osim Coolermastera, pravi ventilatore od 20 cm?
        Thermaltake, Nzxt, Bitfenix, Antec, Corsair, Xigmatek itd
      5. #1563
        Member Avatar korisnika gadafi
        Na forumu od
        Sep 2005
        Lokacija
        Niš
        Poruka
        3.288
      6. Moja mašina
        • CPU: i5 9600K, Noctua NH-U12P
        • MoBo: Gigabyte Z390 Gaming SLI
        • RAM: Kingston HyperX DDR4-2400 2x16 GB
        • VGA: Nvidia Quadro P2000
        • MON: Dell U2412M
        • HDD: Crucial MX100 256GB, WD 1TB RE4 + 1.5TB Green + 3TB SE
        • OPT: LG HL-DT-ST BH16NS40
        • Case: Cooler Master HAF-X, Seasonic Focus Gold 550FX
        • SND: OnBoard, Microlab FC 360
        • OS: Windows 10
        • LAP: Lenovo Ideapad 700-17isk
        • TV: LG 42LW4500, 49UH8507
        • INET: Kablovska
        • Ostalo: HP Deskjet 5150, Kyocera FS-1920, Canon CS-4400F
      7. Hvala. Moraću da probam neki drugi. Imam utisak da ovaj fabrički u kućištu kilavo duva.
        x1gor: Boot Loader nije program, vec vrsta programa ...
      8. #1564
        Member Avatar korisnika nenad 970
        Na forumu od
        Dec 2013
        Lokacija
        Srbija
        Poruka
        1.826
      9. Moja mašina
        • CPU: x5660 4.6Ghz/Phobya castom loop
        • MoBo: Asus P6X58D-E
        • RAM: 3x4gb samsung 8-10-9-31-T1 1920Mhz
        • VGA: MSI 1080-ti sea hawk
        • MON: BenQ XL2720Z
        • HDD: Crucial SSD 240GB BX200 SATA3 2,5"/WDC WD500AALX
        • OPT: /
        • Case: HAF 932 advanced/Super Flower Leadex II 1000W GOLD
        • OS: windovs 10 enteprise
        • Ostalo: i ostale trice i kucine
      10. Mozda je off i unapred se izvinjavam ali evo sta mi se desilo::::
        Par dana vec komp iz cista m ira se igasi i onda non stop restartuje ,ne moze da digne sistem.Ja ga izgasim sve izvadim memaru ,vratim on radi,sve mislio da je nesto do memare do juce.Juce radio normalno i ja ga ugasim ,imao neka posla,kad sinoc da upalim,ma kaki,nema boga,sve zivo povadio i nece skinuo i graficku ,on udje do biosa i eror F1 CPU fan,jedino njega nisam cupao jer vrti mamu mu,izvucem ga posle jedno 7 sati zezanja i na kraju zivaca i komp ozivi,ovo da sam sanjao nebi doziveo,ja sve mislio maticna ili napajanje na izdisaju
        Eto kako jedan obican vent moze da sludi coveka,znaci vrti ali sigurno negde probija i neda kompu da digne sistem.
        Pevac
      11. #1565
        Na forumu od
        Aug 2013
        Lokacija
        Prijepolje-Beograd
        Poruka
        2.887
      12. Moja mašina
        • MON: ASUS MG 279Q
        • TV: Neki LG 32"
        • INET: Kablovska
      13. To je zastitini mehanizam kada se ventilator suvise sporo okrece da se nebi pregrejao procesor. Meni se ranije desavalo na stock ventu za Hyper 212+, zna nekad da ode ispod 600rpm pri paljenju i onda ploca to vidi kao CPU Fan Error. Samo u biosu za fan monitoring stavis taj fan na ignore, ili podesisi nizu granicu za rpm, tipa da kad ode ispod 300rpm da se to opet desi. Vrti se on, ali ne dovoljno brzo da bi ploca dalje pustila
      14. #1566
        Na forumu od
        Dec 2013
        Lokacija
        Srbija
        Poruka
        1.826
      15. Moja mašina
        • MON: BenQ XL2720Z
        • OPT: /
      16. ^
        Bem ti zastitu umalo nisam polomio plojku xaxa,stavio sad koji se vrti na 1500 pa nek se zastiti sad
        Pevac
      17. #1567
        Na forumu od
        Aug 2013
        Lokacija
        Prijepolje-Beograd
        Poruka
        2.887
      18. Moja mašina
        • MON: ASUS MG 279Q
        • TV: Neki LG 32"
        • INET: Kablovska
      19. Pa moguce je da je crkavao, ali ja mislim da ploca ima PWM CPU 4pin konektor, tako da on nece uvek raditi na 1500rpm ako to nije potrebno da se ohladi procesor, samo kada predje odredjenu temp ploca dize broj obrtaja. Te recimo iz tog razloga, ako je procesor u idle i prilikom paljenja, kod nekih venitlatora ode broj obrtaja ispod recimo 600rpm jer je PWM Duty na 0% i oglasi se CPU Fan Error iako se u stvari sasvim lepo vrti
      20. #1568
        Na forumu od
        Dec 2013
        Lokacija
        Srbija
        Poruka
        1.826
      21. Moja mašina
        • MON: BenQ XL2720Z
        • OPT: /
      22. U pravu si,svi su 4-pinci na ploci,*mjau**mjau**mjau* prvi put u zivotu probao da vidim kako je to kad se ne cuje da radi komp i skoro pop*****,axaxxa nije za mene tisina,mora se na max
        Pevac
      23. #1569
        Na forumu od
        Aug 2013
        Lokacija
        Prijepolje-Beograd
        Poruka
        2.887
      24. Moja mašina
        • MON: ASUS MG 279Q
        • TV: Neki LG 32"
        • INET: Kablovska
      25. Ne moras na max, mozes da podesis da BIOS ignorise taj fan i da AiSuit ili ploca sami podizu broj obrtaja u zavisnosti od opterecenja, ili da podesis da se u startu vrte na bar 700rpm
      26. #1570
        Na forumu od
        Dec 2013
        Lokacija
        Srbija
        Poruka
        1.826
      27. Moja mašina
        • MON: BenQ XL2720Z
        • OPT: /
      28. Mogu reci da nisam naviko da ne cujem onaj huk vazduha koje proizvode 14-tice,kad su na 800 sve mislim da se nesto pokvarilo,necujni su haha,a ne moze se klokovana masina drzati a da se ne cuje,mora se odvrteti vent za 5ghz+
        Pevac
      29. #1571
        Na forumu od
        Aug 2013
        Lokacija
        Prijepolje-Beograd
        Poruka
        2.887
      30. Moja mašina
        • MON: ASUS MG 279Q
        • TV: Neki LG 32"
        • INET: Kablovska
      31. Moze ja mislim da se podesi da se ventilatori zavrte jace kada je procesor pod opterecenjem i kada mu poraste temperatura i proporcionalno da se povecava brzina. Tako da kada samo vrtis nesto po netu ili gledas film, da budu tihi na 800rpm, a kada upalis neku zahtevniju igru ili kada radis neki render ili slicno, da se zavrte na max ako je to potrebno
      32. #1572
        Na forumu od
        Dec 2013
        Lokacija
        Srbija
        Poruka
        1.826
      33. Moja mašina
        • MON: BenQ XL2720Z
        • OPT: /
      34. Ma znam za to da pod opterecenjem pojacava ploca brzinu venta,ali kako mi se ovo desilo i blago receno bio po****o,malo sam ja to rucno izesovao,tako da ono ne cuju se ako ne obracas paznju,jer nisu bas na max ai na max kada su isto nema tu brundanja samo onaj huk na koji sam ja naviko,jos kada se zatvori stranica skoro pa necujno,mada ja skoro nikad ne zatvaram stranicu,xaxax,na gigasitu to se nije desavalo ali asus je asus ,bolji klok tecnije radi al zato umalo prolupah
        EDIT:Ajd da ujedno pitam ,gde ima da se nabave ty 143 ventovi,ako prodam plojku castio bih ovaj CPU sa par njih i onda moze igra da se nastavi dalje
        Menjao nenad 970 : 20.03.2015. u 19:26
        Pevac
      35. #1573
        Member
        Na forumu od
        Dec 2014
        Poruka
        80
        Sto se tice CM jetflo da li se meni samo cini da su ramovi kulera veci u odnosu na neke druge, tipa CM sickleflow, dakle ne sam kuler , nego ona 4 krila koja imaju otvore za srafove ? Ja bih uzeo ovaj cooler ali me je strah da ne moze da mi stane u kuciste, jer je prostor za monitranje coolera u mom kucistu u levom uglu pozadi, a ne na sredini. Bilo bi lepo ako je neko imao i sickleflow i jetflo da mi kaze da li su iste velicine racunajuci ram, da ne bacam 1.700 dindzi za dzabe.
        Menjao Reaper89 : 29.03.2015. u 18:32
      36. #1574
        Na forumu od
        Aug 2013
        Lokacija
        Prijepolje-Beograd
        Poruka
        2.887
      37. Moja mašina
        • MON: ASUS MG 279Q
        • TV: Neki LG 32"
        • INET: Kablovska
      38. Iste su velicine Imam oba, inace na sajtu Cooler Mastera ti pisu tacne specifikacije oba ventilatora
      39. #1575
        Member
        Na forumu od
        Dec 2014
        Poruka
        80
        Citat Citiram korisnika: Kasa5033 Pogledaj poruku
        To mi odgovorili i u CM podrska sekciji, meni se sve sa slike cinilo da su oni uglovi na jetflo-u veci, mozda zbog dizajna jer nemaju klasican kvadrat ram kao sickleflow. Uzeo bih jetflo jer ima 4pin pwm za moju plocu, a ostali cooleri kod nas su uglavnom 3pin, ovako mogu da kontrolisem obrtaje, ali me malo odvraca sto mnogi pricaju da je jetflo bucniji i od sickleflow-a, cak i na 1000, ali i bolje hladi.
        Oni aerocool shark mi se isto cini da su dobri, 82cfm na 1500, ali isto kazu da su bucni, a ne mogu da se kontrolisu obrtaji kod onih koji imaju 4pin ploce, jer ima samo 3pin prikljucak.
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
