»RSS Benchmark sajt
      Strana 3 od 301 PrvaPrva 12345671353103 ... PoslednjaPoslednja
      Prikazani rezultati od 31 do 45 od ukupno 4510
      Tema: ATI Catalyst/AMD Crimson - diskusija, pitanja, linkovi
      1. #31
        Member Avatar korisnika blackbear
        Na forumu od
        May 2007
        Poruka
        1.148
        Posto si vec koristio Driver Cleaner, cisto da vidimo da nisi zaneredio
        reistry i da ujedno vidimo da ti sami 9.11 ne uzrokuju problem,
        pokusaj da instaliras 9.12beta (samo drajvere i CCC).
        Ours Is Not To Reason Why Ours Is But To Do Or Die
      2. #32
        Member Avatar korisnika moto tomo
        Na forumu od
        Jan 2005
        Lokacija
        Миљаковац
        Poruka
        741
      3. Moja mašina
        • CPU: i5-4690K@4.5GHz+XIGMATEK Loki
        • MoBo: GIGABYTE GA-Z97-D3H
        • RAM: 4x4GB 1866@2000MHz Kingston HyperX Fury
        • VGA: PowerColor R9 270
        • MON: LG W2242T
        • HDD: Patriot Blast 240GB,1TB Seagate Barracuda ST1000DM003
        • OPT: LG GH22NS50
        • Case: Antec 900 / SS-500ET
        • SND: Onboard
        • OS: Win7 64bit
      4. Ја користим ово упутство већ пар година и никад нисам имао проблема са инсталацијом нових драјвера
        Spoiler:
        Old Catalyst Removal
        Now we move on to the simplest, and yet most commonly mishandled part of using graphics drivers - the removal of previous Catalyst drivers. To do this successfully, you need to follow some simple steps which will help guarantee that your installation of the drivers is 'clean', and leads to trouble-free performance. I particularly recommend this procedure if you are installing the ATI Catalyst Control Center for the first time. To completely remove your existing Catalysts, and all traces of them from your system manually do the following:
        1. Uninstall any existing Catalysts. To do this, go to Control Panel>Add or Remove Programs in XP or Control Panel>Programs and Features in Vista. Select the 'ATI - Software Uninstall Utility' option (or similar) if available, and click the Change/Remove button. Follow the prompts from there to uninstall your existing Catalysts, and reboot as prompted. If you cannot find any ATI entries, you are probably using the default Windows drivers, which means you can skip to the Catalyst Installation section further below.
        2. When you reboot, you will find Windows will detect your graphics card as one (or more) new devices. It will then attempt to find appropriate drivers for your card. Cancel out of all such attempts. If you can't then don't worry about it, but it is preferable if you prevent this from occurring.
        3. This step is optional, however it is strongly recommended if you are either (a) downgrading your Catalyst drivers to an older version, or (b) experiencing problems and want to ensure you have a complete 'clean' install of the Catalyst drivers/Control Center. Basically the aim is to find all the individual ATI graphics driver files and remove them manually. The instructions differ based on your OS:
        Windows XP: Go to your C:\Windows\System32 and C:\Windows\System32\Drivers directories, and find and delete all files beginning with 'ATI...'. You may notice that some of these files keep recreating themselves - don't worry, these are just the default XP ATI drivers which are protected and can't be permanently deleted. Just delete all the ATI driver files and let XP decide which default files the system should keep. Alternatively you can use the Windows Search function (Start>Search), with the search string ATI*.* to make searching and deletion faster. Importantly however, do not delete the files under the \ServicePackFiles or \Lastgood directories, or under any game or application-specific directories. Just stick to files found under the two directories mentioned earlier. Finally, make sure you delete the entire program folder(s) where you installed the Catalysts. The default install location is C:\ATI and/or C:\ATI Technologies but if you chose another location when installing, go there and delete the folder and all its contents. Also delete the \Documents and Settings\[username]\Application Data\ATI and \Documents and Settings\[username]\Local Settings\Application Data\ATI directories if you have previously installed the ATI Catalyst Control Center at any point.
        Windows Vista: See the 'Viewing, Updating or Uninstalling Drivers' section of the Windows Drivers chapter of the TweakGuides Tweaking Companion for Windows Vista. It is trickier to manually remove driver traces in Vista, so you must read the instructions carefully to see how it's done.
        Finally, make sure you delete the entire program folder(s) where you installed the Catalyst drivers. The default install location is Program Files\ATI Technologies but if you chose another location when installing, go there and delete the folder and all its contents. Note, while I recommend learning to use the manual method, if you are worried about accidentally deleting the wrong file, use the free Driver Sweeper utility.
        4. This step is optional, but again it is recommended if you want to ensure a "clean install". It involves removing any ATI registry entries left over. To do this, I recommend using either RegSupreme, or its earlier (and completely free) cousin, RegCleaner 4.3. To use RegSupreme, start the program and once it has cached your files, start a 'Deep' scan, then wait and choose the 'All' item under the Select menu to highlight all the 'invalid entries' found, and click the Fix button to remove them all, making sure to save a backup under a descriptive name. To use RegCleaner, open the program and on the front page put a tick next to all the 'ATI'-related entries, and then click the 'Remove Selected' button. If you want to use the Windows XP Registry Editor instead, go to Start>Run and type "RegEdit" (without quotes). Then go to the HKEY_LOCAL_MACHINE key, select the 'Software' subkey, and scroll down to the 'ATI', 'ATI Technologies' and 'ATI Technologies Inc.' entries. Right-Click on each of these keys and select Delete to remove them. Note that this method is not as thorough as using RegSupreme or RegCleaner, which find other hidden ATI entries.
      5. #33
        Na forumu od
        May 2007
        Poruka
        1.148
        1. korak iz ovog uputstva je upravo taj koji zna
        da napravi problem, ali da bi se to totalno izbeglo
        upravo treba da se ide putem kojim sam naveo:
        1.CCC
        2.drajver
        3.ATI Catalyst Install Manager
        Jer upravo "ATI Catalyst Install Manager" pri deinstalaciji
        zna da napravi brljavu ili sa CCC-om ili sa drajverima,
        a na ovaj nacin koji sam naveo taj problem je totalno zaobidjen.
        3.i 4. koraci nisu neophodni kao sto covek i kaze ili
        jedino ako je clean install bas neophodan, ali tek
        kao sledeci korak posto utvrdi da li sami 9.11 prave problem.
      6. #34
        Na forumu od
        Jan 2005
        Lokacija
        Миљаковац
        Poruka
        741
      7. Moja mašina
        • MON: LG W2242T
        • OPT: LG GH22NS50
        • SND: Onboard
        • OS: Win7 64bit
      8. Clean install је најбољи начин за избегавање било каквих проблема са инсталацијом нових/старих драјвера. Одузме ти 5~10мин. времена али зато ако нешто није уреду одмах си елиминисао проблем са инсталацијом и знаш да је проблем до самих драјвера....мојих 5¢
      9. #35
        Member Avatar korisnika Uruk
        Na forumu od
        Nov 2009
        Lokacija
        Insmut
        Poruka
        5.002
      10. Moja mašina
        • CPU: i5 8400 / Frio 14
        • MoBo: Asrock z370 pro4
        • RAM: CMK16GX4M2B3000C15R
        • VGA: GTX 1060 6GB AMP!
        • MON: ViewSonic VP2250wb
        • HDD: M.2 240GB KC1000 / Toshiba 2TB
        • Case: Carbide 400c / EVGA SN 550 G3
        • SND: Creative
        • OS: WIN 10 - 64bit
        • LAP: ASUS Eee PC
        • Ostalo: Logitech
      11. meni ovo izbaci kad krenem da uninstal ATI Catalyst Install Manager
      12. #36
        Member Avatar korisnika mhz
        Na forumu od
        Dec 2003
        Lokacija
        BG
        Poruka
        603
      13. Moja mašina
        • CPU: Intel® Core™ i7-4820k @ 4.5GHz
        • MoBo: MSI X79-GD65 (8D)
        • RAM: Transcend 16GB 1600MHz
        • VGA: Asus R9-280X DC2T 3GB
        • MON: Dell S2340L
        • HDD: Samsung 840 Pro 256GB~Seagate 4TB 5400rpm
        • OPT: Pioneer DVR-212
        • Case: CM Advance II APS-750 Bronze
        • SND: Realtek integrusa :D / Logitech Z-5300
        • OS: Win 8.1 x64
        • TV: LG 50PV350
        • INET: Kablovska
      14. Isti problem sam imao sa 3450 reset u toku instalacije.
      15. #37
        Na forumu od
        Nov 2009
        Lokacija
        Insmut
        Poruka
        5.002
      16. Moja mašina
        • SND: Creative
        • LAP: ASUS Eee PC
        • Ostalo: Logitech
      17. Citat Citiram korisnika: mhz Pogledaj poruku
        .....i kako si resio problem???????????????
      18. #38
        Na forumu od
        Dec 2003
        Lokacija
        BG
        Poruka
        603
      19. Moja mašina
        • MON: Dell S2340L
        • OS: Win 8.1 x64
        • TV: LG 50PV350
        • INET: Kablovska
      20. Nikako,stavio sam 9.8 i radi
      21. #39
        Na forumu od
        Nov 2009
        Lokacija
        Insmut
        Poruka
        5.002
      22. Moja mašina
        • SND: Creative
        • LAP: ASUS Eee PC
        • Ostalo: Logitech
      23. Uspeo sam istalirat betu 9.12, dosta komplikovano se namesta clone monitor+tv, igre nisam ni probavao ,samo malo u Borderlands mozda 3-4 fps-a vise sa dinamic shadow 40-60,bez isto kao i pre zapucano na 62 fps-a ,rez. 1680/1050
        Menjao Uruk : 19.11.2009. u 13:30
      24. #40
        Na forumu od
        May 2007
        Poruka
        1.148
        Citat Citiram korisnika: moto tomo Pogledaj poruku
        Clean install je najbolji nacin ako zabrljas. I ne mozes ti da predvidis
        na kojoj konfiguraciji i do kakvog problema ce doci, ako uradis
        clean install a Catalyst je lose napisan.
        Moja poenta je bila da redosled u tom uputstvu je pogresan
        i da zbog toga moze doci do problema.
        Taj redosled (iz 1. koraka) deluje logican, sto je lik naveo,
        ali nazalost ne radi kako uvek treba.
        Ima ljudi koji svaki put bez deinstalacije instaliraju drajvere jedne preko drugih
        pa nemaju probleme, ja sam za deinstall zato sto sam tako navikao i uvek
        je blio uspesno.
        A clean install nije neophodan za totalno normaln rad drajvera i treba
        da se koristi jedino ako nastupi problem, inace gubljenje vremena.
      25. #41
        Na forumu od
        May 2007
        Poruka
        1.148
        Citat Citiram korisnika: Uruk Pogledaj poruku
        Ipak si instalirao 9.12beta, trebao si odma, ako pocnu texture i vegetacija da nestaju
        u Borderlands samo upali Catalyst A.I.
      26. #42
        Na forumu od
        Nov 2009
        Lokacija
        Insmut
        Poruka
        5.002
      27. Moja mašina
        • SND: Creative
        • LAP: ASUS Eee PC
        • Ostalo: Logitech
      28. Citat Citiram korisnika: blackbear Pogledaj poruku
        OK. A.I mi je stalno i upaljen. Negde sam procito da je to opcija kad CPU pomaze GPU u savladavanju textura
      29. #43
        Member Avatar korisnika cikaunx9
        Na forumu od
        Sep 2004
        Lokacija
        NS
        Poruka
        182
      30. Moja mašina
        • CPU: AMD Ryzen 1600x | Noctua NH-D14
        • MoBo: Asus Prime x370 Pro
        • RAM: Samsung OEM B-die 2x16GB @2933
        • VGA: Gigabyte GTX 560 Ti
        • MON: Dell U2412
        • HDD: Crucial MX300 525GB | 7TB HDD
        • OPT: Pioneer DVR-215BK
        • Case: Chieftec LBX-01B | Antec 550W
        • SND: Asus Xonar DX | Genius SW-HF 5.1 5005
        • OS: Win 10 x64
        • TV: Panasonic TX-P42S30E
        • INET: Kablovska
        • Ostalo: Microsoft Sidewinder
      31. I dalje ne radi dxva (ni u verziji 9.10 nije radila akceleracija). Prosto je neverovatno da tako izbacuju drajvere, a ne radi sve kako treba, odnosno od verzije do verzije, cas radi, cas ne radi. Glavna novina im je podrska za akceleraciju H.264 videa preko Adobe Flash Player-a 10.1, a to ustvari ne radi
        Quantum vis, tantum scis!
      32. #44
        Na forumu od
        Nov 2009
        Lokacija
        Insmut
        Poruka
        5.002
      33. Moja mašina
        • SND: Creative
        • LAP: ASUS Eee PC
        • Ostalo: Logitech
      34. Citat Citiram korisnika: cikaunx9 Pogledaj poruku
        Ako nije problem , mozes malo pojasniti to akceleracija , posto mi je ovo prva ati karta , a imam velikih problema sa gta4, zapucan mi je fps na 25. sa 9.12 cak i na 20Fps. Koju god rezoluciju da stavim isto(800/600 20fps, 1680/1050 20fps)
      35. #45
        Member Avatar korisnika B-ZiGER
        Na forumu od
        Aug 2007
        Lokacija
        Karaburma
        Poruka
        2.348
      36. Moja mašina
        • CPU: i5 6500@4.48Ghz@Alpenföhn® Brocken
        • MoBo: GIGABYTE GA-Z170-HD3@Non K OC Bios
        • RAM: 16gb DDR3 @ 1866
        • VGA: MSi 1080 Ti Lightning !!!
        • MON: Benq 27'' 2760H & Vox 50'' Led
        • HDD: SSD Samsung 840 EVO120gb & 2TB & 1.5tb & Wd1tb & 4TB WD
        • Case: MASTERCASE PRO 5/Novatech Black Edition 750W Modular
        • SND: Integrusa & Microlab
        • OS: Win 8.1 PRO x64bit
        • TV: Benq 27''&Vox 50''Full HD
        • INET: DSL
        • Ostalo: DeLL&R8A BloodY,Afterglow,Logi-K400,BB KEYONE,PS4 za bleju.
      37. Ja cu da ispljujem i pohvalim 9.11 verziju.Znaci prvi drajveri(verzija) (Vista je u pitanju) koji na mom racunaru nisu trazili restart kompa da bi proradili i to bi bilo to sto se tice hvale.Borderlands bagovi CoDMw2 20 fps manje tj. mnogo veci drop frejmova nego na 9.10 dalje nisam testirao ali verujem da nije neka sjajna situacija u prevodu vracam 9.10.
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
