- Ryzen 5 5600
- MS B350M Mortar Arctic
- 16GB DDR4 HyperX 3200Mhz
- XFX Qick RX 6700XT
- 1 TB SSDa + 3TB HDDa
- Seasonic MII EVO 520W
- Monitor
- LG 29WK600
- Laptop
- HP Pavilion Aero 13
- Steam
- jovyland
- Optički internet
- Mobilni internet
EVO je naslednik odlicnog NZXT Beta kucista, a od njega se razlikuje po mestu za napajanje koje je sada smesteno na dnu, mnogo boljim mogucnostima za cable managment i dva dodatna otvora za 12-ice na vrhu. Cena kucista bi trebala da bude ista kao i kod "starijeg" modela, odnosno ~60 evra kod nas. Da bi cenu zadrzali na sto nizem nivou, kuciste ce se isporucivati bez fanova, za razliku od Beta koja dolazi sa samo jednim, pa je dodatno investiranje u bar dve 12-ce pozeljno. I ovako, kuciste predstavlja best buy u ovom cenovnom rangu, a tu je i black-painted enterijer. U prodaji ce se naci od septembra.
http://www.nordichardware.com/news,9739.html
http://www.hardwaresecrets.com/news/4104
http://www.nzxt.com/products/beta_evo/BETA EVO Classic Series
Mid tower black steel chassis
Announcing the Beta EVO, a sleek, all black value packed mid tower case at a budget price. Beta EVO features advanced cooling performance with support for up to 6 120 mm fans with an option of a 140mm fan at the top. Beta EVO also provides external dual radiator support along with a meshed front panel allowing for enhanced cooling potential.
Full of options for expansion, the case fits high performance 10.5” graphics cards, up to 4 external 5.25” drives and 5 internal 3.5” HDD racks. Beta EVO provides a number of features that significantly enhance ease of installation including screwless installation for 5.25” drives and superior wire management capabilities with the bottom mounted PSU and 180° turned HDD cage. It also features punched holes in the motherboard allowing for quick CPU bracket removal.
Features
- Fits ATX Standard Motherboards and Power Supplies
- Fits large 10.5” performance graphic cards
- Expanded cooling directly cools video cards and CPU
- Support for up to 6 120mm fans with the option of dual 140mm at the top
- Screwless installation for hard drives and external 5.25” drives
- Black Internal finish for sleek look
- Meshed front panel allows for better airflow than traditional cases
- Superior wire management with bottom mounted :: PSU and CPU punchout for heatsink removable
- Removable PSU filter
- 180 degree Turned HDD for a cleaner internal finish and better wire management
- External Dual radiator support
- Top mounted USB/Audio for convenient usage
