»RSS Benchmark sajt
      Strana 3 od 14 PrvaPrva 123456713 ... PoslednjaPoslednja
      Prikazani rezultati od 31 do 45 od ukupno 199
      Tema: AKCIJA: Isključite autorun!!!
      1. #31
        Member
        Na forumu od
        Nov 2005
        Poruka
        563
        thanx +1
        Msi i945p-v5 neo, celeron 331 2.66@3.2, 2gb transcend ddr2, zotac 7300gt ddr3 128mb @ 650/1750, wd 80gb, bb350w psu, samsung 700p+ (2048x1536@60hz), sb live 5.1 + neo sw g32
      2. #32
        Member Avatar korisnika VexMunja
        Na forumu od
        May 2005
        Lokacija
        Near my Pa4x-76
        Poruka
        2.717
      3. Moja mašina
        • CPU: i5 3570K +Hyper 212 EVO @ 4.2 Ghz
        • MoBo: Gigabyte Z77X-UD5H
        • RAM: Kingston HyperX 2x8 GB
        • VGA: Sapphire Pulse RX 580 8GB
        • MON: Dell P2414H
        • HDD: SSD SAMSUNG 860 EVO 250GB +SSD Kingston Hyperx 3K 120GB +WD Red 2TB +Toshiba 2TB
        • OPT: LG GH20NS10
        • Case: Antec P182 EU + Seasonic SS-620GM
        • SND: Focusrite Saffire Pro 24 DSP + ESI nEar08 eXperience + Audio Technica ATH-M50 + Bayer DT 231 Pro
        • OS: OS X 10.14.3
        • TV: TV LED Samsung UE-42F5500
        • INET: Kablovska
        • Ostalo: Logitech Combo MK520 ,TP-Link WDR3600
      4. Ako si stavio ovo
        Ja autorun iskljucujem odavno- u startu me je nervirao kad ubacim CD,a on mi sljepne na desktop,ili Nero nareze i odmah krene da ga vrti autorun... Rekoh ***ebi me... i od tada sam autorun poslao u vecna lovista...
        Keyboard\Live\Studio\DAW\Plugins\Mixer\Monitors \ Soundcard\Speakers\Samples\Playing|Enjoying=MUSIC
      5. #33
        Member Avatar korisnika opusten
        Na forumu od
        Aug 2004
        Lokacija
        Brace Jerkovic, BG
        Poruka
        262
      6. Moja mašina
        • CPU: I3 2100 box
        • MoBo: MB MSI H61M-P23
        • RAM: 2x4gb 1333Mhz Exceleram Cl9
        • VGA: Saphire 6670 1gb DDR5
        • MON: Benq G2420HD
        • HDD: SSD Mushkin 120Gb SATA3, HDD Seagate 2TB SATA3 64MB
        • OPT: DVD/RW Pioneer 216
        • Case: CM Elite, Thermatake 700W 14"Fan Modularno
        • SND: integrusha
        • OS: Win 8.1
        • INET: Kablovska
        • Ostalo: G25, Custom made playseat
      7. +1. Postavio na poslu, veceras i kod kuce, u subotu i kod drugara kad mu reinstaliram mashinu.
        There is no knowledge that is not power.
      8. #34
        Member Avatar korisnika terzazak
        Na forumu od
        Feb 2007
        Lokacija
        Niš
        Poruka
        1.597
      9. Moja mašina
        • CPU: AMD Phenom II 965, Xigmatek S1284
        • MoBo: GA-790FXT-UD5P
        • RAM: Geil GV34GB1600C8DC
        • VGA: Zotac 1060 3GB AMP
        • MON: Benq G2420HD
        • HDD: 850 EVO 500gb+WD640+1,5TB HD153WI
        • OPT: Samsung 222f/BEBE
        • Case: CM 690+Chieftec 750W-14cs
        • OS: Win 10, Bitdefender
        • TV: LG 32LH3000
        • INET: Kablovska
        • Ostalo: Xiaomi Redmi 4 prime
      10. Procitao sam savete i iskljucio autorun (doduse sa Tune up-om brze se odradi ).
        Stavio sam flesku da testiram(nije odradila autorun) ali je AV ( Bitdefender ) odmah prijavio da trojanac autorun.te pokusava da neovlasceno upadne u komp ..(naravno obrisao ga je ).
        Posle sam i skenirao celu flesku i AV je pronasao jos dva virusa (Backdoor.IRCBot.ACKK i Win32.Worm.Autorun.LZ -oba je naravno obrisao)
        Inace flesku sam danas koristio na poslu na kompu koji ima instaliran Nod 3.0 (samo kao info bez namere da kritikujem AV)
        Tako da za ovaj savet pozdrav
        Prvo hopni, pa reci skoč
      11. #35
        Member Avatar korisnika balsa
        Na forumu od
        Feb 2003
        Poruka
        558
        Arrow
        Ja sam razvio svoj sistem "vakcinisanje" USB drajvova, pošto malo malo pa zapatim nešto.
        Neko je već pominjao stavljanje praznog autorun.inf fajla sa "read only" atributom, no to izgleda više nije dovoljno.
        Ja zato najpre sve USB drajvove formatiram u NTFS (ako neće, treba samo proguglati kako); neko kaže da NTFS nije dobar za USB drajvove, nek govori ko šta hoće, ja dosad nisam imao problema.
        Zatim napravim prazan autorun.inf . Pa onda metnem "read only" atribut.
        Onda podesim NTFS permissions tako da za autorun.inf ukinem sve dozvole (baš sve) i još dodam EVERYONE: Full control: Deny.
        Ni ovo, naravno, nije 100% rešenje, ali zahteva da se trojanac malo više zeza za NTFS permissions nego što obično ume. Zasad zaštita funkcioniše.
        Menjao balsa : 14.01.2009. u 19:36
      12. #36
        Member Avatar korisnika sakall
        Na forumu od
        Apr 2006
        Lokacija
        Beograd
        Poruka
        358
        Citat Citiram korisnika: okmijun Pogledaj poruku
        Meni non-stop iz jedne kopirnice pakuju neke *.exe viruse.
        (Jedan se zove nesto kao acrobat.exe, al ne verujem da ima veze sa adobom)
        Tacno tako..nema nikakve veze za acrobatom ali je zao zeznu za uklanjanje...mora mnogo cckanaj ok registra i jednostavnije je reinstalirati komp nego njega ukloniti...samo se pazi
        all you touch and all you see...is all your life will ever be
      13. #37
        Banned Avatar korisnika Shang Tsung
        Na forumu od
        May 2005
        Lokacija
        Београд, Миријево
        Poruka
        1.880
      14. Moja mašina
        • CPU: AMD X2 550 Phenom II @ 3.5GHz, cooled by Scythe Ninja 2
        • MoBo: Gigabyte 770T-UD3P
        • RAM: 2x2GB Exceleram EP3001A DDR3 1333MHz@1600MHz
        • VGA: MSI Radeon 5850 Twin Frozr II
        • MON: Samsung SyncMaster 2233SN
        • HDD: Patriot TorqX TRB 64GB + 2xSamsung F3 500GB + Samsung F2 1.5TB
        • OPT: Pioneer 111D
        • Case: Nzxt Lexa S (windowed) Powered by Corsair CX400
        • SND: Creative Audigy 4 + Logitech Z-2300 + Sennheiser HD515
        • OS: Windows 7 Professional x64 SP1 (org.)
        • INET: Kablovska
        • Ostalo: Logitech K200 + Logitech G400 + Razer Goliathus Omega Speed, Canon LBP2900
      15. Citat Citiram korisnika: balsa Pogledaj poruku
        A jel mislis da je teze lupiti dvoklik na reg fajlu koji su napravili nasi drugari sa ovog foruma, pa jos uvek praktikujes to svoje?
      16. #38
        Na forumu od
        Feb 2003
        Poruka
        558
        Ako sam dobro razumeo, dvoklik na reg fajl služi da se zaštiti računar.
        Ovaj moj metod služi da se zaštiti USB flash.
        To nije isto.
      17. #39
        Newcomers
        Na forumu od
        Mar 2007
        Lokacija
        Beograd
        Poruka
        10
      18. Moja mašina
        • LAP: Dell Inspiron N5010
      19. Da dodam, gasenje autorun-a moze da se odradi i preko tweakUI programceta za XP, pretpostavljam da moze da se nadje nesto slicno za vistu.
        http://www.microsoft.com/windowsxp/D...powertoys.mspx
        poz
      20. #40
        Member
        Na forumu od
        Dec 2002
        Lokacija
        Novi Sad
        Poruka
        458
      21. Moja mašina
        • CPU: Intel i5-2500k
        • MoBo: ASUS P8Z68-V PRO GEN3
        • RAM: 4x4GB DDR3 @1600Mhz 1.5v
        • VGA: SLI 2xMSI GTX460 768MB
        • MON: DELL 2311H
        • HDD: Samsung 830 128GB, Samsung F1 1TB, F4EG 2TB, Seagate 7200.12 1TB, WD15EARS, WD20EARX, WD EXT 1.5TB
        • OPT: LG SATA DVD-RW
        • Case: Cooler Master 690 II
        • OS: Windows 7 x64
        • TV: Toshiba 40"
        • INET: Kablovska
        • Ostalo: ASUS TF101, Nexus S, Note II
      22. Posebno iritira kad se prikljuci neki prenosni disk, pa win pocne da ga skenira [why? WHYYYY???] i na kraju da onaj retardirani meni na kom svi izaberemo NO ACTION.
        A autorun.inf je najlaksi nacin da se zarazi neki komp. Na zapadu se cesto "zaboravljao" zarazeni USB na prometnom mestu, gde bi neko radoznao pokupio flashic, turio u komp i nesvesno instalirao virus, u ovom slucaju spyware-ove najgore vrste.
        Zato pamet u glavu i [apdejtovani] antivirus na svaki komp XD
      23. #41
        Banned
        Na forumu od
        Jul 2008
        Lokacija
        BGD.SRB
        Poruka
        607
      24. Moja mašina
        • CPU: AMD Athlon-64 2800+ BOX
        • MoBo: Microstar K8T NEO-FSR (VIA K8T800)
        • RAM: 1.0 GB DDR400 Kingston (2 x 512 MB)
        • VGA: Asus GeForce FX-5700 128 MB / 128 bit
        • MON: Asus MW221U (22" wide @ 1680×1050 & 32 bit / 60 Hz)
        • HDD: WD SATA II 250 GB (7200 rpm, 16 MB)
        • OPT: LiteON LH-20A1H (20x DVD±R, LightScribe)
        • Case: Eurocase ML5410 ATX 350W
        • SND: integrisana / Logitech X-220 2.1 35W
        • INET: DSL
        • Ostalo: Win XP Pro SP3
      25. Citat Citiram korisnika: sakall Pogledaj poruku
        Ma, ovo nije tačno - većina antivirusa uklanja ovog smora bez ikakvih problema! Lično sam to uradio sa nekoliko zaraženih USBova kod sebe - bocnem taj USB u moj komp, autorun krene, a Avast ga saseče u korenu...
      26. #42
        VIP member Avatar korisnika akki
        Na forumu od
        Apr 2005
        Lokacija
        Beograd/London
        Poruka
        2.468
      27. Moja mašina
        • CPU: Core 2 Quad Q6600@3.6GHz + Cooler Master GeminII
        • MoBo: Gigabyte GA-X38-DQ6
        • RAM: GEIL 4x2GB PC2 8500 DDR2 1066 MHz
        • VGA: Gigabyte GF 8800GT 512MB DDR3 GV-NX88T512HP
        • MON: DELL 2408WFP; iMac27''
        • HDD: 2x WD Raptor WD1500ADFD + 2x WD Caviar SE16 WD6400KS
        • OPT: Pioneer DVR-108D & 112D
        • Case: Cooler Master 690 + 5xBlue LED Silent Fan 140 + GIGABYTE Odin Pro GE-M800A-D1 800W
        • SND: Creative Audigy 4 Pro + Creative Inspire 5300
        • OS: Vista 64 Ultimate+Sp2+OS X
        • LAP: HP 2140 Mini-Note; MacBook Air
        • TV: Panasonic TX-P65VT20B; 50G10
        • INET: DSL
      28. uradio... hvala...
      29. #43
        Member Avatar korisnika __zevs__
        Na forumu od
        Sep 2006
        Poruka
        3.809
      30. Moja mašina
        • CPU: Intel i5-3570K
        • MoBo: Gigabyte GA-Z77X-D3H
        • RAM: 4x4 GB DDR3 1866
        • VGA: Integrale
        • MON: LG W2453V
        • HDD: WD 640GB x3 + 250GB Seagate Baracuda
        • OPT: Nec 4551A, Pioneer 212D
        • Case: Kuciste: LC Power Pro-910B; Napajanje: Corsair 400CX
        • SND: Integrisana/Altec lansing 121
        • OS: Slackware
        • LAP: Lenovo S10e
        • INET: Kablovska
      31. То је једна од ствари које су ме увек нервирале (ауторан)... И наравно увек искључено, мада свакако јако ретко користим видовс
      32. #44
        Member Avatar korisnika BelThaZoR
        Na forumu od
        Apr 2006
        Lokacija
        Rio de Zarkovo
        Poruka
        809
      33. Moja mašina
        • CPU: Intel Corei7 4790k, Corsair H100
        • MoBo: Asus Maximus VII Formula
        • RAM: 2x8GB Corsair Vengeance Pro 1600Mhz
        • VGA: ASUS GTX670 2GB
        • MON: 2x DELL U2412M
        • HDD: Corsair Neutron GTX 240GB, WD30EFRX-68EUZN0
        • Case: Cooler Master HAF X; Seasonic SS-850km
        • SND: CREATIVE X-Fi Titanium Fatal1ty Pro PCI-E; Logitech Z-5500, Corsair Vengeance 2100
        • OS: Windows 7 64bit
        • TV: Samsung LE32B550
        • INET: Kablovska
        • Ostalo: Logitech MX5500 keyboard, Razor mamba, self-made FreeTrack
      34. Podrzavam akciju, uradio sam preko TweakUI, samo za removable devices. Za one koji ne zele/ne znaju da petljaju sa registrijem, ovo je najlakse. Mene je mrzelo da petljam sa regijem pa sam odabro laksu varijantu. Za neupucene: TweakUI za XP se moze naci na microsoftovom sajtu:
        Za Vistu ne postoji
        Za sve one koji imaju probleme sa inficiranim fleshevima preporucujem Flash Disinfector, meni je pomogao xy puta
        http://experi3nc3.wordpress.com/2007...ector-by-subs/
        pozz
        Menjao BelThaZoR : 15.01.2009. u 17:02
        In theory, there is no difference between theory and practice, but in practice, there is.
        Data recovery guru
      35. #45
        Banned Avatar korisnika Dule13
        Na forumu od
        Apr 2006
        Lokacija
        Београд
        Poruka
        3.701
      36. Moja mašina
        • CPU: Xeon x4 x5460
        • MoBo: Ga-P35C-DS3R
        • RAM: 8GB Patriot DDR3 1333
        • VGA: 7850 Sapphire
        • MON: 37` TV
        • Case: Termal Take Armour Jr.
        • SND: Xonar DX ББ1612 МОД
        • INET: DSL
      37. Citat Citiram korisnika: RazbojNick Pogledaj poruku
        Ako mogu da dodam, isključivanje autoruna se lako obavlja iz Start>Run>GPEdit.msc>Local Computer policies>Administrative Template>System>Turn Off Autoplay na "Enabled". Ovim se isključuje autorun na celoj mašini, za razliku od postupka iz prve poruke koji utiče samo na trenutnog korisnika sistema. Ako je nekome i dalje lakše da otvara regedit, onda neka umesto HKEY_CURRENT_USER ide u HKEY_LOCAL_MACHINE, ostatak je isti.
        EDIT: ili neka primeni reg fajl koji je Igoritza ostavio...
        Ово је по мени лакше, само још после измене треба укуцати у cmd-u:
        gpupdate /force или рестратовати комп.
        Menjao Dule13 : 15.01.2009. u 17:01
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
