Dances.with.Wolves
General
Complete name : D:\Dances.with.Wolves
Format : Matroska
File size : 17.5 GiB
Duration : 3h 56mn
Overall bit rate : 10.6 Mbps
Encoded date : UTC 2008-11-02 15:58:01
Writing application : mkvmerge v2.4.0 ('Fumbling Towards Ecstasy') built on Oct 11 2008 20:13:15
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
[email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 3h 56mn
Bit rate : 8622 Kbps
Nominal bit rate : 9074 Kbps
Width : 1920 pixels
Height : 816 pixels
Display aspect ratio : 2.35
Frame rate : 23.976 fps
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.242
Writing library : x264 core 65 r999M cc51047
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy_rd=0.7:0.7 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-4 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=9074 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.70
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 3h 56mn
Bit rate mode : Constant
Bit rate : 1536 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Resolution : 24 bits
Language : English
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Veoma zahtevan rip, sta pusta i gde:
xpsp3 mpc (vmr9 renderless) na 7300gt i X2 na 2 GHz radi bez seckanja
vistasp1 64 mpc 32 (vmr9 renderless) na HD 3200 i X2 na 1.9 GHz secka dosta
vistasp1 64 mpc HC 64 (evr) na HD 3200 i X2 na 1.9 GHz radi bez seckanja ali bez titla
u cemu je ovde problem?
