@voodoons
kako si preabcio fsb preko 400?
Pogledaj moju konfu iz moja masina. Ne mogu da prebacim fsb 400 nikako. Da li je do proca, ploce ili nesto trece?
Na kom fsb-u je wall za moj cpu?
One simple BSEL mod, and you get yourself a E8500 chip. You just need to tape one contact point, like... this:
Credit goes to someone on the ocforums for the picture.
If the motherboard supports overclocking, by BSEL modding, you can effectively leave your chip at the 333MHz FSB strap instead of 266MHz FSB strap. That should be an easy 333 to 400 overclock, and then, you will have yourself a 3.80GHz chip. That's how I did it with the GIGABYTE GA-73PVM-S2H. Originally, any strap below 333MHz on the GIGABYTE GA-73PVM-S2H wouldn't let me overclock much above 333MHz.
ali srebro je srebro
Pa ovde mi ne bi bash pomoglo srebro jer trebam da onesposbim taj vod, a srebro je provodno jel?
ah, da
utripovao sam da trebas dva pina da spojis...hehe
E7200 je milina za modovanje, samo jedan pin treba da zamaskiram i CPU je modovan
Napomena: This feature currently requires accessing the site using the built-in Safari browser.
