Kupih danas ovo cudoviste. Za pocetak, evo par specifikacija:
· Unique Top mounted 200mm TriCool exhaust fan to cool the hottest system
· Perforated front bezel for maximum air intake
· Two front loaded HDD cages for up to 6 hard disk drives
· The HDD cages act as air ducts to take air in more efficiently. Optional middle
120mm fan bracket to cool the hottest graphic cards or CPU
· Two 120mm TriCool blue LED front fans to cool hard disk drives
· Window side panel comes with an optional 120mm fan mount for maximum VGA
cooling.
· Top mounted I/O ports for easy access
· Top tray for your MP3 player, digital camera, etc.
· Power supply mounts at the bottom of the case (power supply not included)
· Dimensions: 19.4" x 8.1" x 18.4" (L x W x H)
49.3cm x 20.6cm x 46.8cm (L x W x H)
· Advanced cooling system:
- 1 top 200mm TriCool fan with 3-speed switch control
- 1 rear 120mm TriCool fan with 3-speed switch control
- 2 front 120mm special black TriCool blue LED fans with 3-speed switch control to
cool HDDs.
- 1 side (optional) 120mm fan to cool graphic cards
- 1 middle (optional) 120mm fan to cool CPU or graphic cards
· 9 Drive Bays
- External 3 x 5.25"; Internal 6 x 3.5" for HDD, or
- External 6 x 5.25"; Internal 3x 3.5" for HDD, or
- External 9 x 5.25"
· Motherboard: Fits micro and standard ATX
· 7 Expansion Slots
· Top I/O
- Power & reset button with blue LED
- 2 x USB 2.0
- 1 x IEEE 1394 (FireWire®, i.Link®)
- Audio In and Out
Ono sto je bitno je da odlicno hladi, to mozete i sami da predpostavite naravno jer se u kompletu sa kucistem dobija 1 20CM!!! exaust top fan, 1 12CM exaust back fan i 2 x 12CM front fans. Svaki od navedenih ima switch od 3 brzine, LOW - necujhno, MID - kao standardno kuciste, HIGH - skoro kao usisivac. Izradjeno je od celika, nema ostrih ivica. ZAnimljivo je da se PSU stavlja DOLE a ne GORE! Ja sam prezadovoljan, e sad, kao najvecu prednost bih izdvojio lep dizajn, raspored i kolicinu ventilatora i naravno GIGANTSKI ventilator na vrhu, a kao manu, pa, nervira me sto nema nekog panela koji moze da se nakaci na prednju stranu kucista i da se odatle posebno pojacava brzina fan-ova. Sve u svemu 10/10. Evo i par slika
Ako kupujute kuciste iz neke jace klase, toplo preporucujem ovo, nema greske
cooling.
cool HDDs.
· 9 Drive Bays
· 7 Expansion Slots
· Top I/O
- 2 x USB 2.0
- Audio In and Out
