To je bio problem sa updateom, odavno je rešen, i to nije ono što tebe muči.Napiši ovde šta ti piše prilikom BSOD, lakše ćemo ti reći šta se dešava.
Ja AVG IS koristim, evo, već petu godinu i osim nekih sitnih trzavica, problema nisam imao, kao ni infekcija virusima.
da ne spamujem temu (ipak je ovo tema o AV programima) ali evo šta je neki WhoCrahed program našao, pa ako neko kapira o čemu se radi..)
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Mon 21.2.2011 22:28:18 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022111-30014-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x70710)
Bugcheck code: 0x1E (0x0, 0x0, 0x0, 0x0)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: wdf01000.sys (Wdf01000+0x1B61D)
file path: C:\Windows\system32\drivers\wdf01000.sys
description: Kernel Mode Driver Framework Runtime
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
