Izasla Opera v9.0 final!
Ja imam slicne simptome i to bez proxy-a, da li je neko resio ovaj problem?
Napisao sam par postova posle toga kako sam resio problem. Povecao sam broj konekcija na serveru za sebe, sa default 160 na 1.000.000 i posle toga nije zabadala Opera :d
Sto kaze ciga, a mozhe i tako :d
Novo od Opera tima:
Opera 9.1 will include Fraud Protection
As presented at the Opera Backstage event in London today, Opera 9.1 will include enhanced fraud protection. Today we display the name of the certificate owner in the right end of the address field when you're on a secure site. In 9.1 we will reuse that field to display more information about the trust level of the site you visit...
http://my.opera.com/desktopteam/blog/2006/10/17/opera-9-1-includes-fraud-protection
Changes in Opera 9.10 Build 8629 Beta:
- Improved stability
- Prevented page reload when navigating to "#"
- Fixed problem where pages showed the incorrect favicon
- Fixed problem where multimedia keyboard shortcuts would not work when Opera was focused
- Attempted to fix problems experienced on some pages when using a slow Internet connection by increasing opera:config#Network|HTTPLoadingDelayedTimeout to 60 seconds
- Fixed bug where document.body.currentStyle.height reported the wrong value
- Fixed bug where currentStyle.width was not correct if width is set by a script
- Fixed bug where 'Open all' from Widgets menu was broken
- Fixed bug where BCC header was visible to recipients in resent messages
- Fixed bug where cookies could not be removed using XMLHttpRequest
Fixed bug where one could not log in to Gmail with "Accept only cookies for the site I visit" enabled
- Changed Mozilla ID string spoof to mimic Firefox
- Fixed bug where browser.js wasn't cached correctly
- Fixed issue where stored passwords were lost after enabling/disabling the master password
- Made IE ID string spoof as Windows on Linux/UNIX and Mac
- XMLHttpRequest didn't handle redirects
- Enabled use of the Authorization header in XMLHttpRequest
- "Save target as" and "Save to disk" now play well together
- "Save directly to" now works
- Improved error message when a dictionary isn't installed for the spelling checker
http://snapshot.opera.com/windows/o910w_8629m.exe
i zanimljiv dodatak :)
pa vidis da nije enableovano :D
nesto kao anti-phishing u IE7... po mom misljenju, to su lose stvari, jer usporavaju surf...
Dodaci za moroneriju, koja kuca brojeve kreditnih kartica i passworde u bezmalo svaki sajt koji im kaže da to urade. Za korišćenje interneta još uvek nije potrebno polagati neki "vozački ispit". Nažalost.
Nego, mene zanima, na koju foru Yahoo onim svojim antiphishing sličicama identifikuje komp? Cookies nisu, kod mene se redovno brišu. IP adresa nije - menja se. Nije ništa specifično za određeni browser, jer se pojavljuje u svim (ne baš uvek, ali se uvek ponovo pojavi). S jedne strane paranoišemo oko security-ja, s druge strane nam Yahoo pokazuje da može da nas prilično precizno identifikuje.
Vidim da postoje dve verzije opere za win: Windows MSI (4.7 MB) i Windows Classic (3.8 MB)
Koja je razlika osim u velicini?
Nema razlike, prva koristi MSI installer a druga običan. Zavisno od toga ko šta voli, ja mrzim MSI instalere.
I ja uvijek skidam classic installer (takodje ne volim msi installer, a i manji je classic - a ja na dialup-u).
između ostalog zato što ne mogu da ga otvorim dvoklikom jer mi je u TC postavljen plugin koji MSI tretrira kao arhive. ;)
Koje su razlike između msi i obične instalacije?
Nema razlike osim u velicini (classic je manja).
Preciznije rečeno (ni ja nisam bio precizan u prethodnom odgovoru), sadržaj paketa je apsolutno identičan, samo se installer razlikuje.
inace ovo nije 9.1 nego 9.03.8629 :)
Ma i za neke ranije bete se desavalo da pise drugo u About :)
Da li neko zna da li je moguce u operi 9 da se namesti da poput opere 8.x ne otvara stalno downloads sekciju prilikom save-a neke slike?
ima na ovom topicu pogeldaj par strana unazad
Skini najnoviju verziju, to je samo 9.0 imala taj "problem", posle su izbacili tu opciju.
Otkucaj u Address baru "opera:config", pa onda u search otkucaj "transfer", i pojavice ti se stavka "TransferWindow" u kojoj treba da -odčekiraš- stavku "Activate On New Transfer". Klik na "Save", resetuj Operu i to je to.
Inače, search opcija u Config sekciji = jaaaaako korisna stvar....
:wave:
Changes in Opera 9.10 Build 8643 RC1:
- Source editor text "reload from cache" now reads "Apply changes"
- Fixed 100% CPU on google maps and some other pages
- Fixed an issue with opacity on links that have images nested in them
- Find in page now has colors that are easier to see, while also being configurable (opera:config#Colors|HighlightedBackground)
- Some fixes to Search in hotclick menu
- Removed "Open when download complete" from File type dialog (while we fix it..)
- Fixed accesskeys on pages with frames
- Several fixes to Fraud protection
- Fixed crash when changing file handler on UNIX
- Now also UNIX has its Mask as IE mask the platform as well
- A lot of memory leaks plugged and crashers removed
- Fixed problem finding nested IMAP mailboxes
- Fixed problem with Chinese and Korean text input
http://snapshot.opera.com/windows/o910w_8643.exe
Meni ova zadnja ne radi kako treba jer ako ostanu nekoliko tabova otvorena i iskljucim operu,, sledeci put kada otvorim operu mesto stranica vidim samo kodove pa mora reload za sve tabove.
Vratio sam se na onu predzadnju.
Build 8649: http://snapshot.opera.com/windows/o910w_8649.exe
Changes since last weekly
* Fixed bug where "Go to URL" feature deselects last one or two characters of a URL
* Fixed bug where newsfeed count did not updated in Mail panel status bar
* Fixed bug where cnn.com didn't always finish loading
* Fixed bug where accesskeys didn't work right on frame pages
* Fixed bug where Gzipped pages was not decoded when loaded from cache
* Added preference to disable trust button in address bar opera:config#SecurityPrefs|EnableTrustButton
* Fixed Finnish translation
Ima li neki drugi shortcut osim Ctrl+Shift+klik misem za otvaranje linka u novom tabu u pozadini?
Nezgodno jednom rukom, Firefox skracenica je Ctrl+klik i mnogo je jednostavnija.
Mogu li promijeniti shortcut? Trazio sam u Shortcuts (Preferences), al ne nadjoh...
klik na tockic misa (tj. 3rd button) resava stvar
Hvala na brzom odgovoru!
Jos sam malo caprkao po Shortcut opciji i promijenio nesto tako da mi sada Shift+klik otvara link u pozadini. znaci ipak se moze i to
Changes in Opera 9.10 Build 8660 Beta:
- Windows media plugin now works even if java is disabled
- Fixed hanging when hovering some pages, for example elkjop.no
- Fixed issue with floating point numbers treated as integers on some linux systems (caused some CSS and scripts to fail)
- Several Fraud protection fixes
- Several Memory leak and crash fixes
- Wand data is stored in a new format - please read below!
http://snapshot.opera.com/windows/o910w_8660.exe
