D
delimir
Guest
14. septembar.
Principal Skinner je napisao(la):Искрено се надам да ATI неће усрати мотку у средњем сегменту као што су то урадили, хммммм, задњих 1024 пута
Iz gore navedenog review-a je napisao(la):Pored svih već dokazanih kvaliteta, kao što je kombinacija adaptivnog (transparentnog) umekšavanja ivica u HDR modu (funkcija koju NVIDIA G7x čipovi ne podržavaju)
ivanbo2003 je napisao(la):Covek je lepo napisao kombnacija AA+ HDR,a ne samo transparent AA...
Guru3D je napisao(la):I have to demystify a myth also. Team red claims that Series 7 can't handle both HDR and antialiasing at the same time. That's only partly true, NVIDIA's Series 7 product can do so for sure yet they use another method. Here's the issue, G7x hardware does not support multisample antialiasing with fp16 render targets. The G7x series however can support AA with HDR through a variety of other methods, including supersampling and application specific implementation.
Typhoon.X je napisao(la):Cela zabuna je proizashla iz toga shto si generalizovao stvari... Istina je da Nvidia ne podrzava HDR+AA ali samo u slucaju da je HDR primenjen kroz FP16 metod... Ali podrzava tu funkciju u slucaju da je HDR implementiran bilo kojom drugom metodom...
byMaX je napisao(la):Da bi to prikazao na SDR mediju, koji ima nivo osvetljenja svakog piksela od svega 256 boja. tj. 8 bit integer, potreban je Tone Mapping, i to je ok
- What is rthdribl
Rthdribl is a technical demo of "High Dynamic Range Image-Based
Lighting". DirectX(R) 9.0 high-precision texture formats and
version-2.0 of Pixel Shader represent real-time true HDR rendering.
Light sources and reflected or refracted lights that are very bright
cause Glare.
Technical features of this demo are:
- True HDR (High-Dynamic Range) Rendering
- IBL (Image-Based Lighting)
- Glare Generation (Afterimage, Bloom, Halo, Ghost, and Star)
- Automatic Exposure Adjustment
- Iris shaped Depth of Field blur
- Realistic Motion Blur
- FSAA (Full-Scene Anti-Alias)
- Fresnel Reflection (Specular Reflectance, Metallic Color-Shift)
etc.
