Cayenne
Zapažen
Ok, posto kolege nece da kazu kako zaobici hotspot limit, pitao sam AI i evo interesantnog odgovora (nisam probao):
Here are the most common technical methods used to hide hotspot traffic from a carrier:
Adjusting the TTL (Time To Live)
This is the most common and effective method. Every data packet has a TTL value (usually 64 for smartphones). When a packet passes through a router—in this case, your phone acting as a hotspot—that value decreases by one. When your carrier sees data arriving with a TTL of 63, they immediately know it came from a tethered device.
• The Workaround: You can manually modify the default TTL setting on the receiving device (like your laptop) to 65. When the packet passes through your phone, it drops to 64, making the carrier think the data is coming directly from the phone itself.
Using Third-Party Tethering Apps
Instead of using the native iOS or Android hotspot feature, certain apps are designed specifically to mask tethered traffic.
• The Workaround: Apps like PdaNet+, Tetrd, or PairVPN force the tethered connection (often via USB or Wi-Fi Direct) to route through a proxy or VPN tunnel on the phone. This packages the data so it appears to the carrier as normal, on-device app usage rather than hotspot traffic.
Utilizing a VPN
While simply turning on a VPN on your laptop won't fix the TTL drop, it does stop the carrier from inspecting the contents of your traffic.
• The Workaround: If a carrier uses Deep Packet Inspection to see that your traffic is coming from a Windows PC browser or a background Windows update, a VPN on the connected device will encrypt that data. Alternatively, some Android apps allow you to route your native hotspot traffic through a VPN on the phone itself, hiding both the destination and the nature of the data.
Utilizing a VPN
