The Chinese company confirmed today that the Magic 6 series and Magic V2 RSR Porsche Design will have their international debut on February 25.
Both series will be unveiled during an event scheduled to take place at Mobile World Congress (MWC) 2024, which is set to kick off on February 26.
Honor will introduce the Magic 6, Magic 6 Pro, Magic V2, and Magic V2 RSR Porsche Design, a luxury version of the standard Magic V2.
Nije bio ni obican Honor Magic 5, ne verujem ni da ce 6, nazalost.E običan Magic 6 kad bi dosao i ovde, to bi bila ozbiljna stvar.
Pa uodnosu ako pogledamo pocetnu cenu prosle god na HM5 lite, ovo je bezobrazno + nema velika unapredjenja uodnosi na prethodnika. Taj 4k video i nista specijalnoZar je bio manje?
The recently announced Honor Magic6 Pro comes with a second-generation silicon-carbon battery that ensures more reliable performance in various conditions as well as increased power density. The battery is the first in the world of smartphones to have a standalone chip called Power Enhanced Chip Honor E1.
The new battery tech uses silicon instead of graphite for the negative electrode. Silicon itself has several key advantages over graphite, the most notable being its density. The silicon anode offers 10 times the power density of the graphite, but it expands in volume by up to 300% and has a shorter life cycle. That's why Honor uses a silicon-carbon anode to offset the inherent drawbacks of silicon.
Honor says the Microtunneling Laser Guidance technology makes a big difference when used for the silicon-based anode. It increases the contact area between the electrolyte and the silicon-based anode, unlocking the usable capacity in the low-voltage range. In away, it helps increase battery capacity you can use more of the available charge.
The second-generation silicon-carbon battery also boasts improvements in charging. To ensure optimal performance the company even added a standalone chip to manage the battery.
The chip itself constantly adjusts the current depending on the environment and loads involved. Per Honor's words it makes the battery safer, and enables it to perform better in extreme weather environments, especially in cold weather, and offers more accurate percentage readings of the remaining battery. It allowed the new Magic6 Pro to charge at 80W, instead of 66W.
Honor claims Magic6 Pro outperforms every smartphone at -20°C with its efficiency. Interestingly, Tesla has been working on such battery tech since 2016 and has already implemented it on some of its vehicles.
sparrowsnews.com
www.androidcentral.com
Magic 6 Pro lasts longer than any other phone I used in 2024 thus far, and that's down to the combination of a massive battery and the efficient Snapdragon 8 Gen 3. I got close to two days even with heavy use, and with regular usage, the Magic 6 Pro easily netted two days between charges.
It also posted the highest scores of any device I tested in PCMark's demanding Work 3.0 battery life test, going up to 17 hours and five minutes.
This camera setup comes with the Sport Portrait Algorithm, which should allow you to capture portrait shots with a natural bokeh effect even in fast-moving scenarios. HONOR utilizes binocular depth estimation and sports portrait segmentations so that it precisely adjusts the background with a natural bokeh effect. It utilizes main and telephoto cameras at the same time for such shots.
Xiaomi 14 ultra ,pocetna cena 1500 eura ,ovi 1300,ja stvarno neznam ko ce da im kupuje ove telefone,pored dva vodeca brenda.Najavljena je cena od 1300 EUR za Evropu za 6 pro model.
