2021-04-07 20:12:16 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Login,Username:telecomadmin
2021-04-07 20:12:47 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,LANDevice.WLANConfiguration.X_HW_AdvanceConf:1.1,DtimPeriod:1,BeaconPeriod:100,RTSThreshold:2346,FragThreshold:2346
2021-04-07 20:12:49 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,InternetGatewayDevice.LANDevice.WLANConfiguration:1.1,Channel:6,AutoChannelEnable:0,X_HW_HT20:0,RegulatoryDomain:HR,TransmitPower:100,...
2021-04-07 20:12:49 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,LANDevice.WiFi.Radio:1.1
2021-04-07 20:14:33 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,X_HW_DEBUG.AMP.WifiCoverSetWlanBasic:,SsidInst:1,SSID:4TheHorde-2.4G,Enable:1,Standard:11bgn,BasicAuthenticationMode:None,...
2021-04-07 20:14:33 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,InternetGatewayDevice.LANDevice.WLANConfiguration:1.1,Enable:1,SSIDAdvertisementEnabled:1,SSID:4TheHorde-2.4G,X_HW_AssociateNum:32,...
2021-04-07 20:14:33 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,LANDevice.WLANConfiguration.WPS:1.1,Enable:0,X_HW_ConfigMethod😛ushButton
2021-04-07 20:14:33 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,LANDevice.WLANConfiguration.PreSharedKey:1.1.1
2021-04-07 20:15:09 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,LANDevice.WLANConfiguration.X_HW_AdvanceConf:1.5,DtimPeriod:1,BeaconPeriod:100,RTSThreshold:2346,FragThreshold:2346
2021-04-07 20:15:10 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,InternetGatewayDevice.LANDevice.WLANConfiguration:1.5,Channel:36,AutoChannelEnable:0,X_HW_HT20:3,RegulatoryDomain:HR,TransmitPower:100,...
2021-04-07 20:15:10 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,LANDevice.WiFi.Radio:1.2
2021-04-07 20:15:10 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,LANDevice.WiFi.X_HW_GlobalConfig:1,BandSteeringPolicy:1
2021-04-07 20:17:16 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,X_HW_DEBUG.AMP.WifiCoverSetWlanBasic:,SsidInst:1,SSID:Moj zivot -2.4G,Enable:1,Standard:11bgn,BasicAuthenticationMode:None,...
2021-04-07 20:17:17 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,InternetGatewayDevice.LANDevice.WLANConfiguration:1.1,Enable:1,SSIDAdvertisementEnabled:1,SSID:Moj zivot -2.4G,X_HW_AssociateNum:32,...
2021-04-07 20:17:17 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,LANDevice.WLANConfiguration.WPS:1.1,Enable:0,X_HW_ConfigMethod😛ushButton
2021-04-07 20:17:17 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,LANDevice.WLANConfiguration.PreSharedKey:1.1.1,PreSharedKey:-
2021-04-07 20:17:54 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,X_HW_DEBUG.AMP.WifiCoverSetWlanBasic:,SsidInst:5,SSID:moj zivot-5G,Enable:1,Standard:11ac,BasicAuthenticationMode:None,...
2021-04-07 20:17:56 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,InternetGatewayDevice.LANDevice.WLANConfiguration:1.5,Enable:1,SSIDAdvertisementEnabled:1,SSID:moj zivot-5G,X_HW_AssociateNum:32,BeaconType:11i,...
2021-04-07 20:17:56 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,LANDevice.WLANConfiguration.WPS:1.5,Enable:0,X_HW_ConfigMethod😛ushButton
2021-04-07 20:17:58 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,LANDevice.WLANConfiguration.PreSharedKey:1.5.1,PreSharedKey:-
2021-04-07 20:20:37 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,X_HW_DEBUG.AMP.WifiCoverSetWlanBasic:,SsidInst:1,SSID:Moj zivot -2.4G,Enable:1,Standard:11bgn,BasicAuthenticationMode:None,...
2021-04-07 20:20:37 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,InternetGatewayDevice.LANDevice.WLANConfiguration:1.1,Enable:1,SSIDAdvertisementEnabled:1,SSID:Moj zivot -2.4G,X_HW_AssociateNum:32,...
2021-04-07 20:20:37 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,LANDevice.WLANConfiguration.WPS:1.1,Enable:0,X_HW_ConfigMethod😛ushButton
2021-04-07 20:20:37 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,LANDevice.WLANConfiguration.PreSharedKey:1.1.1
2021-04-07 20:20:53 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,X_HW_DEBUG.AMP.WifiCoverSetWlanBasic:,SsidInst:5,SSID:moj zivot-5G,Enable:1,Standard:11ac,BasicAuthenticationMode:None,...
2021-04-07 20:20:53 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,InternetGatewayDevice.LANDevice.WLANConfiguration:1.5,Enable:1,SSIDAdvertisementEnabled:1,SSID:moj zivot-5G,X_HW_AssociateNum:32,BeaconType:11i,...
2021-04-07 20:20:53 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,LANDevice.WLANConfiguration.WPS:1.5,Enable:0,X_HW_ConfigMethod😛ushButton
2021-04-07 20:20:53 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Set,LANDevice.WLANConfiguration.PreSharedKey:1.5.1
2021-04-07 20:22:41 [Critical][Config-Log] Terminal:WEB(192.168.54.30),Result:Success,Type:Logout,Username:telecomadmin
