Ugradi ventilator koji će stalno ubacivati svež vazduh u podrum![]()
We have seen the blue fin technology to protect the condenser coils from corrosion and damage. Gold fin technology is a similar kind of technology where the manufacturers of ACs apply a golden hydrophilic coating to the condenser coils.
The Golden Fin condensers are better than the Blue fin condensers in the sense that they improve the heating efficiency of the AC in the Reverse Cycle models by accelerating the defrosting process.
The gold fin condensers do not rust. Hence, this technology provides greater protection to the coils. The gold fin technology is universally handy as it is beneficial in coastal areas as well as other areas. The gold fin coating can take care of acidic, salts, and water accumulation on the condenser coils. Also, the gold fin coating is non-toxic and 100% environmentally friendly.
+1Stvarno, na -10C spoljne temperature koliko 'ladnoce klima izbacuje na spoljasnjoj jedinici da na unutrasnjoj isporuci aj recimo +40C? Slusaj ljude bre pretvorices podrum u zamrzivac, moze da se desi da zaledis i vodovodnu/kanalizacionu instalaciju i sta ces onda?
Pokusavam da budem pametan oko svega ovoga![]()
Dok se vi dogovorite kako da zaledite taj podrum :smash: mene zanima zašto svake godine čitamo isti članak o najjeftinijem i najskupljem grejanju, a da nema ni traga o pominjanju grejnih tela kao što su inverterske klime ili još bolje toplotne pumpe.
Da li je to zabranjena tema u Srbiji, da se narod što više drži u neznanju i da loži drva, ugalj, pelet i ostale energente koji zagađuju sve živo...
Najkuplje na struju, spominju TA peć i kvarcne grejalice OMG i el. kotlove. Tu je stao sav napredak u tehnologiji... Bože me sačuvaj :S:
NAJJEFTINIJE GREJANJE NA DRVA, NAJSKUPLJE NA STRUJU
https://www.kamatica.com/analiza/najjeftinije-grejanje-na-drva-najskuplje-na-struju/62821
Ima, za neku malu sračunatu snagu, tj Pdesign sigurno nije veći od 2.4kW
