A ovo je FO, nereferentne tek stižu![]()
There were two plausible CPUs to pick for this review — either the Broadwell-E 6900K, which compares directly with the Ryzen 7 1800X in core count and clock speed, or the Core i7-7700K, which is Intel’s top mainstream part (there wasn’t time to benchmark a third system). In this case, we opted for the 6900K, since that’s the Intel CPU closest to Ryzen’s overall value proposition. Chances are, if you buy a $500 CPU, you’re buying it for multi-threading, with gaming as an important option to serious hobby.
Vredi li ovo upariti sa 4670? Ili je cpu preslab?
Ovde su radili posebno testove sa AMD Ryzen 1800X i Intel i-7 6900K procesorima:
https://www.extremetech.com/gaming/...-ti-first-real-4k-gpu-drives-better-amd-intel
Nešto je brži 6900K u visokim rezolucijama ali šteta što nisu stigli da testiraju 7700K:
Sad ce titan XP korisnici da rade downgrade... Sramota
Za nijansu je brži 6900K i duplo skuplji
Evo testa i sa i7-7700K vs Ryzen. Interesantni su minimum FPS
Ne zaboravi i 400Mhz niži clock
Ni jedan ni drugi procesor se ne kupuju zbog igara zato i čekam poređenje sa 6700K/7700K ali ne od sLinusa, njega ne uzimam za ozbiljno.
A šta kažeš na 45W veći TDP? Ryzen 95W a 6900K 140W?
Here the Ryzen 7 1800X provided respectable results but nothing that aligns with the 45W “TDP” delta between it and the i7-6900K. Unlike the official TDP values would have you believe, the ultimate winner in a raw performance per watt dogfight will be highly variable, often boiling down to an application to application baseline.
Kako sad 400 MHz niži klok? Valjda 300MHz? Koji se gleda stock ili turbo?![]()
