Kako je se samo Intel oslobodio brige,oko reklamacija na cpu-e ostecene OC-om..ko klokuje,bude primoran da se dobrovoljno odrekne garancije.
Znaci ili OC ili garancija..trece nema.
Racunao sam koliko treba za novu platformu i generalno oko 1000 eur da sklopis cpu+ploca+memorija a da to valja. 6700k + neka Asus Deluxe ploca + 16 GB DDR4, opciono 32GB.
A gde je ostalo za one koji tek sklapaju konfiguraciju? Cene su sve jace i jace a perfomanse nista specijalno.
Ako je 6700K kod "madjara" 400e, koliko ce tek biti kod nasih retailera i etailera? Kad se vec daje za DDR4 platformu, bolje dati jos 100-120e i uzeti X99 i 5820k + blagi OC na 4 GHz.
Ma ebes garanciju kad smanjenjem 20C produzavas zivot CPU,tako ko voli nek izvoli![]()
420e kod madjara, 470 kod nas... mozda. X99 here I come!
Po mojoj racunici, na osnovu MSRP u US (+nas PDV 20%), i5 6600k bi trebao da kosta 260e a i7 6700k 370-380e (i u Nemackoj je ta cena). 5820k je 365e (madjarska), pa je jedina veca razlika izmedju Z170 i X99 cena maticne ploce, pa ko voli vise jezgara...![]()
Skylake brings a lot of benefits to content creators - particularly in terms of improvements to Quick Sync and additional image processing options (including real-time 4Kp60 RAW import). However, it is a mixed bag for HTPC users. While the additional video post processing options (such as LACE for adaptive contrast enhancement) can improve quality of video playback, and the increase in graphics prowess can possibly translate to better madVR capabilities, two glaring aspects prove to be dampeners. The first one is the absence of full hardware acceleration for HEVC Main10 decode. Netflix has opted to go with HEVC Main10 for its 4K streams. When Netflix finally enables 4K streaming on PCs, Skylake, unfortunately is not going to be the power efficient platform that it could have been. The second is the absence of a native HDMI 2.0 / HDCP 2.2 video output. Even though a LSPCon solution is suggested by Intel, it undoubtedly increases the system cost. Sinks supporting this standard have become quite affordable. For less than $600, one can get a 4K Hisense TV with HDMI 2.0 / HDCP 2.2 capability. Unfortunately, Skylake is not going to deliver the most cost-effective platform to utilize the full capabilities of such a display.
BCLK is locked from excessive change on the multiplier locked CPUs - a built-in feature Intel named "BCLK Governator" prevents necessary adjustments for significant OC. No way to override it. We tried.
