Samsung Galaxy K Zoom
http://www.gsmarena.com/samsung_galaxy_k_zoom-review-1099.php
http://www.gsmarena.com/piccmp.php3?idType=3&idPhone1=6210&idPhone2=5447&idPhone3=6033
Cini mi se da sto se ovog testa ^ tice S5 daje malo bolje i cistije slike.
-In terms of image quality, the Samsung Galaxy K zoom camera is good by smartphone standards but not perfect. The noise levels are kept in check though photos aren't as sharp as you would get out of the Galaxy S5. That said, the colors are more accurate (the S5 has a tendency to overexpose) and the white balance is spot on.
The lens has impressive zoom prowess for sure, but that comes at a price. There's noticeable corner softness and barrel distortion at the wide end of the zoom lens.
-The Samsung Galaxy K zoom did very well in our audio quality test, putting up a performance that we wouldn't mind seeing from a flagship smartphone.
The hybrid device had flawless output when connected to an active external amplifier, producing excellent scores all over the field. Its volume levels are higher than on the Galaxy S4 zoom, fixing the only issue its predecessor had on that occasion.
Impressively enough, there's very little degradation when you plug in a pair of headphones. Save for the relatively minor hike in stereo crosstalk, the output remains perfect. The volume remained strong, making up for a solid showing overall.
Ma s5 odvrnuo gamu pa slike izgledaju kao da ima vise detalja. Al svejedno dobar je u 90 % slucajeva. K zoom ima manuelna podesavanja pa uvek moze malo bolje. Ja sam zadovoljan kako radi posao. Nije najidealniji ali jako dobro radi posao.
Manuelna podesavanja ga jako cupaju :)
K Zoom je daleko bolja sprava kad su fotografije u pitanju
Sjajno. ***, da postoji kao dual sim varijanta, momentalno bih pokusavao da ga nadjem.
A cak mi kamera i nije najbitniji element na telefonu, ali ovo je stvarno odlicno, nekako sam impresioniran telefonom generalno, i dizajn je dobar, i zvuk...
Ja sam ovim impresioniran
izazvao si me hunder, izazvao si me :D mada znaš da ja nešto uvek karabudžim, nikad neću slikati ovakvu sliku bez "dodatne opreme" ali sa.... videćemo :p samo da nađem vremena
inače odlična fotka :)
Ispalo je odlicno stvarno, svaka cast. Mozda je boja meseca malo nerealna ali ok.
to je auto white balance odradio poso :) to se lako menja.
*** bio auto WB. Ali nije bio beo kao sinoc. Bio je crvenkasto zuckast. Doduse svetlije.
Pa drugari iskocila mi jedna prilika koja me lomi opasno. Qx100 za 320e. E sad nisam pametan sta raditi???
Pa sta ce ti ta budzevina kad imaš odličan camera phone?
ni meni nije jasno...ako ćeš da nosaš QX100 bolje prodaj K Zoom i dodaj tih 320e i uzmi RX100 i neki obični Android...izaći će te isto para
Prodaj K Zoom i uzmi QX-100 za 320 evra. Iz ma' Na mestu bre!!!
A koliko je rx100?
Naj jeftiniji je 450e
A to ne ulazi u ovu cenu
U stvari ja bih se strpeo, evo sad gledam... U inostranstvu ima nov qx-100 za 250 evra, tako da 320 nije bas neka cena. Tamo RX-100 ima za oko 300. Ali rx ne mozes da postavis na stativ, a da drzis telefon u ruci i kontrolises ga... Ja bih QX kupio samo tako i upario ga sa nekim finim telefonom, milina...
Bolje je kupiti polovan RX100. To je logicno i isplativije.
Ali ovo je cyber trip za burzuje koji hoce da se zezaju sa ovom kamerom (na tabletu, na telefonu koji nema ni priblizno ovako dobru kameru + stativ, bezicna kontrola, zoom itd). Jos da ne neku foru ima xenon koji se ''izvlaci''..
Ovo sa sada nema neku logicnu primenu za sire mase ali ko zna, mozda ce imati vecu primenu u buducnosti, ne konkretno ova lens kamera nego generalno.
Inace ovo stize uskoro i na njihove telefone a naravno i na neke nove QX/RX, bas me zanima kako ce sve to izgledati u praksi http://www.sonyalpharumors.com/first-image-taken-with-the-sony-curved-sensor/
www.toppreise.ch/prod_327692.html
Meni se QX-100 jako svidja. Izabrao bih ga umesto kompakta any day
https://www.flickr.com/photos/47106816@N04/10110194366
I prosetaj levo-desno, ima jos slika...
Koliko ovaj japanac nema pojma da namesti kameru pa to boli. Mozda je experimentisao pa sve okacio na flickr. Elem vidim da je na iso 3200 suma prihvatljivo malo. Ko meni na iso 400 :D e to je razlika u kvalitetu i velicini senzora. A taj rx100. Full manual. Jel? Promenjiva blenda,iso,ss...
^ http://docs.esupport.sony.com/dvimag/DSCRX100_guide/en/contents/02/03/07/07.html
E sad svaki sledeci RX je malo bolji.. uglavnom za low light koliko sam primetio uz jos neke izmene, imas u foto delu negde zavucene teme o tim kamerama. Ali i prvi RX100 je odlican, jeste i dalje skup ali kako i da ne bude kada prakticno nema konkurenciju.
Imas jos galerija qx100 a i rx100/II/III po flickru, u pravim rukama to su sjajne dzepne kamere.
Realno, ko kupi bilo koji RX moze da zaboravi na kamere na telefonima jer je to kompakt koji staje u svaki dzep a kamere na svim telefonima nece moci da prismrde u full manual jos ko zna koliko vremena. Evo iso 25k i 1/4 pa zamisli sta moze da se uradi sa nizim iso i stativom :) https://www.flickr.com/photos/26972240@N03/9435405905
E sad, ko hoce veci zoom ima rx10.. ali to cudo ne staje u dzep.
Mocno,mocno. Zar qx100 sa novom verzijom sw ima vece mogucnosti od ove prve verzije rx100. I jel to u sustini isti senzor isti procesor koji obradjuje sliku. Android je tu samo ekran i komande
I u kom rangu dslr su gore pomenuti.
Pazi, poredjenje svih ovih minijatura sa dslr-om je smesno, zna se za sta sluze dslr i kako se izvlaci maksimum iz njih. Ali ono, recimo da mogu da se porede sa jeftinijim dslr.
Mislim da qx100 i rx100 dele istu tehnologiju ali nisam siguran.
Bilo je nekih apdejtova za qx.. a na jesen ce mozda i novi modeli. Imas ovde temu, da ne spamujemo k zoom http://forum.benchmark.rs/showthread.php?311796-Sony-Lens-Camera&highlight=sony+lens
S'obzirom da te interesuje fotografija i da imas kombinacije za uredjaje po nizim cenama mozda si mogao da se docepas nekog rx100/II, moze i neki polovan. Mislim da rx imaju opticki steadyshot, video si koliko dobro radi softver na Z2 a ovo je jos jedan korak dalje.
Uffff. Dobar je ovaj zoom nema sta. Ali oci traze manje šuma u nocnim uslovima tj indore uslovima. Treba mi iso 800 i ss 100 bez šuma. Zar mnogo trazim :)
