QubitCoin [Q2C]
X Failed to update your account: Unable to connect to RPC server for coin address validation
Eeee...usro si motku! :)
Jel zato pise ovo?
We are investingating issues in the backend. Your shares and hashrate are safe and we will fix things ASAP.
Payouts disabled, you will not receive any coins to your offline wallet for the time being
Blockupdate disabled, blocks and transactions confirmations are delayed
Findblocks disabled, new blocks will currently not show up in the frontend
da. htedoh da skinem novi wallet da rekompajliram, posto je izasao i zezno sam u koracima.
Jao gde bas sada :wall: moram da idem u grad mnogo me mrzi da vracam sve na Q2c-pool.
X Unable to connect to wallet RPC service: RPC call did not return 200: HTTP error: 500 - JSON Response: [-1] CDB() : can't open database file wallet.dat, error 2
Pa strpi se...stavio si valda neki nizi iznos na autopay. Nisi valda sve drzao na pool-u?
Resice to vlax brzo.
Sto bi rekli, prvi macici se u vodu bacaju. :d
Stavio na 500novcica na autopayout a iskopao sam 605Unconfirmed za sat i neki kusur.Ostavljam na par sati nadam se da ce Vlax da sredi dok ja malo :beer::bottle:
jeai spasio novcanik, ja nisam imao autopayout?
aaaa uvek backup prvo pa rad, pogotovu ako radis live
Ja sam imao po oko 400 confirmed/unconfirmed. ***, videcemo sta ce biti.
Meni isto na 500 namesteno, oce sam proraditi ili ponovo moramo ukljuciti na servverima?
proradice samo da ga postavim ponovo
4000 qubita u minusu, al ***....
evo samo da redownloaduje block chain pa idemo live again
Edit:
Sinhronizovao je wallet, sad bi trebalo ponovo da pocne da vam radi
Jeli neko ispratio ovo sa bitcointalk-a?
I use sourcecode from ig0tik3d miner, plus an other library from another author. I reworked these codes to work togheter. It will be opensource for sure.
Any way, there are good news Smiley
I achieved 50% more khs/sec now!!!
Probably I'll release it today or tomorrow, with source code. I dont know yet if I'll release Windows binaries today. Anyway I need that who tries it, report me a feedback, because I tried it just with a i5 from a friend.
And, remember, it is just for AES-NI/AVX supporting processors.
Here the source: https://github.com/elmad/QubitCoin-cpuminer-v.1.2-avx-aes
jesoi ga probao? kad kliknem na download samo se zaglupi i nema sta da skida?
