Ima, ima odavno....
Ma, vidiš da je mali vickast.
Koji program koristite za ocitavanje temperatura,zauzeca ram memorije itd...kao ovaj na slici?Evo,jos malo pa ode svih 3GB vrama :S:
Pogledajte prilog 111715
Ajde da ne mucim vise neke internet pocetnike😀Mitigate stuttering: Navigate to (My) Documents\my games\BioShock Infinite\XGame\Config, open XEngine.ini, and follow the instructions in this post. (Credit to Mechazawa.) Additionally, if you have a card with more than 512MB of VRAM, find the PoolSize cvar in XEngine.ini and change it according to your amount of GPU memory, using the formula [amount of VRAM in GB] x 600 -- also ensure that the -ReadTexturePoolFromIni cvar has been added to the game's launch options (right-click -> Properties -> Set launch options; may cause instability). (Credit to GSY Miguel and antitrop.) Lastly, setting the bInitializeShadersOnDemand cvars in XEngine.ini and XCompat.ini to TRUE may also help. (Credit to Irrational itself via KoruptData.) [Note that while disabling bUseBackgroundLevelStreaming in XEngine.ini also aids in reducing stuttering, it will break certain script events. Enable/disable at your leisure.]
Expand the FoV slider: Navigate to (My) Documents\my games\BioShock Infinite\XGame\Config and open XUserOptions.ini. Search the file for FieldOfView (not to be confused with DefaultFieldOfView), setting it to 1.500000, and MaxUserFOVOffsetPercent, setting it to 45.000000 -- adjust if necessary. (Credit to puzle.)
Expand the mouse sensitivity slider: Navigate to (My) Documents\my games\BioShock Infinite\XGame\Config and open XUserOptions.ini. Search the file for MaxMouseLookSensitivity and change the value accordingly (0.700000 would be a good starting point). (Credit to antitrop.)
"Disable" HUD: Navigate to (My) Documents\my games\BioShock Infinite\XGame\Config and open XGame.ini. Follow the instructions here and adjust the X (horizontal) and Y (vertical) values according to your resolution to effectively push it out of the way. (Credit to JonasBeckman @ Guru3D via neoenigma.)
Scale HUD: Navigate to (My) Documents\my games\BioShock Infinite\XGame\Config and open XUI.ini. Find the MaxResolutionUpScale cvar and adjust it according to your resolution (e.g. 0.5 works well for 2560x1600). (Credit to epmode.)
Improve SLI performance: Change the SLI compatibility bit in the game's Nvidia Inspector profile to 0x0C1902F5. (Credit to MaLDo.)
Obratite paznju posle i na kolicinu mem. Posle tweak-a za stuttering, kod mene je oko 1 gb u 1080p a u 2560x1440 oko 1,3gb.
bUseBackgroundLevelStreaming bolje ne koristiti, jer iako sam po sebi eliminise problem stuttera izaziva odrdjene kontra efekte u smislu loop-ovanja skriptovanih scena ili nestajanja npc-a. No, to je izgleda problem same igre a ne engine-a.
Opcija uvecanja HUD-a je naravno veoma korisna u vecim rezolucijama i za one koji imaju vise monitora...
E vazda ti tenk ju. Značajno je manji stutter, ali ga opet ima. Čak i sa izmjenom bUseBackgroundLevelStreaming opcije.
^ o kakvom trzanju je rec presao sam igru sve na ultra nije stucala?
Ni o kakvom, samo se ti opusti... Sve je u redu, bez brige, igra je i dalje najbolja svih vremena i paralelnih univerzuma, work of art, pomeranje granica, igra bez mane. :smoke:
Taj fix za stutter difoltuje teksture na low.
Ovaj je previse zatamljen, gubi se previse detalja u mracnim scenama... pixar i suptilniji lighting probaj ako nisi🙂Definitivno najlepsi preset za mene, steta samo sto sam skoro na samom kraju tj sto ga nisam koristio od pocetka 🙁
Da li se nekome desavalo, u kontrol panelu je physx namesten na GPU ali u igri na indikatoru stoji CPU
Presao,a sta je sa ovim gameplay ovo nema uigrici?
