Malo download-a
  • Začetnik teme Začetnik teme Crni
Kill-a-watt je za ukupnu potrosnju, a sumnjam i da ovaj kontroler moze ista vise. Njega je zanimalo svaka komponenta ponaosob. A to je tesko do nikako provjeriti sem da pogleda po review-ima koliko koja trosi. A za ovo u trenutku, Frlo tesko.
Speedy Fox
Boost Startup in up to 3 times!
Speed-up browsing history
Overall quicker operation
Smaller profile size
Available for both Windows and Mac OS
Version history:
2.0.2 Fixed incorrect drawing of profiles tree with Windows themes turned off
2.0.1 SRWare Iron and Pale Moon browsers support
2.0 New awesome user interface; support Skype, Chrome, Mozilla Thunderbird profiles; custom profiles: drag & drop support; remember custom profiles, detailed optimization log, latest SQLITE engine 3.7.11
1.6 Added option to run Firefox after optimization (also when running using command line). SQLite engine is updated to 3.7.4 version.
1.5 SpeedyFox for Mac! Latest SQLite engine (3.7.3) support
1.4.3 Latest SQLite engine (3.7.1) support
1.4.2 Unicode profile/path names support
1.4.1 Windows 2000 support, main icon display is fixed, small bug fixes
1.4 command line support, see menu Help->Command line syntax for details
1.3 Better optimization (all databases), fixed issue of detecting if Firefox is running
1.2 Ability to select custom Firefox profiles
1.1 Portable and 5 times smaller executable
1.0 Initial release
http://www.crystalidea.com/speedyfox
Wise Care 365
Clean up, defragment and optimize the Windows Registry
Defragment and free up space on your hard disk
Protect your privacy by erasing personal tracking data
Recover lost files
Hide important files or folders
Prevent unauthorized use of personal applications
Auto shut down your PC
Free up Memory to boost game and enterprise software performance
Simple "One Click Tune-up" option will optimize your PC
http://www.wisecleaner.com/wisecare365.html
RealPlayer Mini 1.5.28666
RealPlayer Mini is new light weight media player designed to provide awesome video playback experience with simplicity and intuitive controls. It is full of nifty features that allows you to enjoy your video contents to their fullest. RealPlayer Mini is designed to be fast, light and intuitively simple. It is quick to start up from your desktop, loads and plays big video files instantly, and quick to respond to your selfish playback needs. Also, you can go through all features and functions with keyboard shortcuts - another way to make playback fast and simple. Playback speed control, A-B section repeat play, bookmarking and chaptering, subtitles handling, pixel shader, manually control aspect ratio, create and manage video playlists, make video snapshots, capture desktop screen as video file...RealPlayer Mini is powered by Daum Communications Corporation and its media player called PotPlayer, and it is distributed by RealNetworks K.K.
http://codecpack.co/download/RealPlayer-Mini.html
Skype Lite
Skype no longer requires any presentation, every computer user know that it is the most popular VoIP (Voice over IP) client on the market. Skype Lite, however, is a version of the software in which all its unnecessary features are removed, to ensure fast and easy navigation.
Installing might be a little bit confusing, as double clicking the executable file does not launch any visible window, but the software is automatically installed in Program Files.
This minimal and uncluttered version of Skype does not install any toolbars, thus reducing user frustration to a minimum. It also features removal of the Internet Explorer plugin, Mozilla plugin, autorun on boot and desktop shortcut.
Just like the desktop version, Skype Lite requires users to enter their username and password, or create a new account, if they do not have one. Then invite friends and start chatting.
What Skype can do is already known: video calling, conference calling, sharing files, instant messaging – all in the simplest manner possible. Lite might now have some missing features, but its level of performance is as strong as ever.
People who are used to being practical will love the feel that Skype Lite offers. Basically, they get the same complexity and functionality of Skype, minus the unnecessary components that would hog the PC resources.
The software runs perfectly on any computer, and the difference between standard Skype and Skype Lite is easily noticeable. Navigating through Lite is easier, and the CPU usage is minimal. Users should not be afraid to experiment with it. Less is more.
http://www.softpedia.com/get/Office-tools/Fax-Telephony/Skype-Lite.shtml
aMSN
aMSN is a free open source MSN Messenger clone, with features such as:
Offline Messaging
Voice Clips
Display pictures
Custom emoticons
Multi-language support (around 40 languages currently supported)
Webcam support
Sign in to more than one account at once
Full-speed File transfers
Group support
Normal, and animated emoticons with sounds
Chat logs
Timestamping
Event alarms
Conferencing support
Tabbed chat windows
http://www.amsn-project.net/
Free Any Burn
Main Features:
Burn image file
Burn files and folders
Burn Audio CD from mp3/ape/flac...
Support all CD, DVD, and Bluray image files, including iso, bin/cue, nrg, mdf/mds,daa, uif, isz, ...
Burn files and folders in your hard drive to CD, DVD, or Bluray disc
Create standard Audio CD which can be played in regular CD player from mp3, ape, flac, wma, ...
Erase rewritable disc
Create image file from disc
Create image file from files and folders
Support two erasing methods, quick erasing and full erasing
Copy CD, DVD, or Bluray disc to ISO or BIN/CUE image file
Create ISO or BIN/CUE image file from files and folders in your hard drive
Copy disc
Convert image file
View drive and disc information
Copy source disc to destination sector by sector
Convert all CD, DVD, or Bluray image file to ISO or BIN / CUE format
View detail information about your drive and disc
http://anyburn.com/
Poznati Puran po svom defragmenteru izbacio all in one alat za odrzavanje racunara-Puran Utilities.
Disk Check Helps you to fix errors, recover bad sectors on your hard disk using chkdsk.
Uninstaller Helps you to uninstall software that you do not need and also software that you are not able to uninstall otherwise.
Puran Startup Manager Helps you to enable/disable Windows startup items. It assists your decision in various forms.
Puran Service Manager Helps you to enable/disable Windows services. It assists your decision in various forms.
Puran Disk Cleaner Helps you to find and delete junk files from your computer. It is highly customizable too.
Puran Delete Empty Folders Helps you to delete empty folders from your system. It is extremely fast.
Fix Shortcuts Helps you to automatically fix or delete broken shortcuts.
Puran Registry Cleaner Helps you to clean Windows registry for better performance.
Puran Registry Defrag Helps you to defrag and compact Windows registry for better performance.
Puran Defrag Helps you to automatically defrag and optimize your hard disk drives.
Puran Duplicate File Finder Helps you to find duplicate files on your computer. It is highly customizable and extremely fast.
Data Recovery Helps you to recover data from your damaged media like scratched DVDs, VCDs, BLU Rays etc.
Disk Files Helps you to look into details of files distribution on your computer. It is highly customizable.
Gaming PC Helps you to create a Gaming Environment on your PC to give your games/apps best of your computer.
Permanent Delete Helps you to delete your files permanently so that they cannot be recovered by any software.
Puran Wipe Disk Helps you to wipe entire disk or just free space so that no files on it can be recovered.
Puran Shutdown Timer Helps you to schedule various shutdown tasks. Many scheduling options are available.
Splitter Helps you to spilt any file into files of specified size.
Delete History Helps you to delete history and other data of various applications including web browsers.
Minimal PC Helps you to close and switch back all the specified services/processes on your computer in a click.
Batch Fix Helps you to automatically keep your system clean and error free by running selected utilities.
Maintenance Wizard Helps you to run selected utilities in a pre-defined order for getting best performance out of your computer.
http://www.puransoftware.com/Puran-Utilities.html
Wise Program Uninstaller
Free of Charge
Wise Program Uninstaller is another freeware from WiseCleaner.com. All users are free to use it, update it and get the basic technical support on it.
Support of Win 8
Wise Program Uninstaller has been tested many times on Win 8 (both 32 bits and 64 bits). It is quite compatible with Win 8.
More thorough and complete
Wise Program Uninstaller can search out more leftovers after you uninstall an unwanted program and then it can provide a deeper and more thorough removal of the residual entries of the uninstalled program. This point has been verified by comparisons with Windows and other similar programs.
Combined Safe Uninstall and Forced Uninstall together
Sometimes, you are annoyed by some stubborn programs or entries which can't be uninstalled/removed or completely uninstalled/removed by common uninstall or safe uninstall. But Forced Uninstall of Wise Program Uninstaller could uninstall/remove them easily and cheerfully.
Added program repair feature
Wise Program Uninstaller provides you with the entrance to repair the installation of some programs.
http://www.wisecleaner.com/wiseuninstallerfree.html
jel postoji neki free program koji može da skine šifru sa mem kartice? Naime u pitanju je stara kartica koja je korišćena u nokia 6300 i telefon je otišao u more, crklo sve, samo je sačuvana kartica, na kojoj ima brdo slika, ali je nokia tada pravila one zaštite za kartice i sad ta kartica ima šifru koju nikako ne mogu da skinem, a potrebne su nam slike. hvala
Jesi li koristio pomenuti program i kako se pokazao?
Pogledajte prilog 96918
Free of Charge
Support of Win 8
Zasto moj antivirus(ESS 5) blokira ovaj unninstaler koji sam hteo da skinem sa adrese koja je postavljena?Da li je to ispala ili...?
DDownloads
korisna stvar za svez sistem
Kod:
http://www.morethanacleaner.de/download/viewdownload/30-ddownloads/124-ddownloads-first-public-beta
SMART v2
Vrlo dobar program za sve one koji žele da na siguran i bezbolan način da optimizuju svoju Services bazu.
U ponudi su vam Default, Safe tweaks, Moderate tweaks, Advanced tweaks i Costum tweaks.
Programčići 😉
Mali, a slatki
MiniTool Partition Wizard Home Edition – najbolji za particionisanje iz Win-a , bolji od partition magica i Acronis Disk Director-a.. može i Ext4 iz Wina da napravi .. http://www.partitionwizard.com/free-partition-manager.html
Disk Genious – za MBR, boot sektor, restore particija - http://www.diskgenius.net/download.html
TeraByte Image for Windows – clone software koji podržava i mount VHD-ova i VmWare image-a i njihovo clon-iranje na fizički disk ! ovo nisam našao ni u jednom drugom programu http://www.terabyteunlimited.com/downloads-image-for-windows.htm
pozZZzZZ
ili su im platili za reklamu? :\
Kada neki od ovih čudotvornih ubrzivača napravi neki i7 ili 8350 od mog dual cora odma ću ih predložim za Nobela. Do sada su svi uspeli samo da mi ga uspore ako ne i upropaste.
@igysa
U tri različite teme si postavio identičan tekst i linkove. Zaista preteruješ.
