Thief 4
nex999
Moderator
CPU & Cooler
Core i9 14900KF*Noctua NH-D15
Matična ploča
MSI MAG Z790 Tomahawk WiFi
RAM
Corsair Vengeance DDR5 64GB 6400MHz
GPU
Asus TUF RTX4090
Storage
2x 2TB Samsung 990 PRO NVMe M.2
PSU
Corsair HX1500i
Kućište
NZXT H7 Flow
Monitor
LG Ultragear 27GS95QE-B, LG CX
Ako je sudeci prema...
http://uk.gamespot.com/pages/forums/show_msgs.php?topic_id=26868659&tag=topics;title
11 maja cemo sigurno saznati koji je to projekat na kome radi Eidos.
Drugi izvor:
http://thief.wikia.com/wiki/Unnamed_Thief_4_project
A posting on Eidos Montreal's website suggests that Thief IV may be about to undergo development. The post states states that, "Eidos-Montréal is proud to announce the recruitment for our 2nd "AAA" project. ... A hint! The title begins with the letter " T "... The article then goes on to draw several other conclusions. Nothing is known yet on what a possible new plot might be, apart from claims that it was initially intended to be a "retelling" of the original games. "
I treci (matoro ubi' boze, uzeti sa rezervom):
http://www.ttlg.com/forums/showthread.php?p=1399221#post1399221
Basically Thief 4 was going to be a retelling of the original games, except set in modern times. It would have modern versions of the same characters from the old games, who's roles would have been translated to modern day parallels. Some of the old maps were going to make a reappearance as well. To be clear, it was not going to be anything like Splinter Cell or similar games. Garrett wasn't going to be turned into a James Bond type of guy with a bunch of gadgets or anything like that. He would still be the dark, sarcastic loner who uses his own skills and ingenuity to do his thieving, not gadgets. I don't think we were even going to let the player use a gun, just simple tools and weapons. The art direction would have been similar to the steampunk from the previous games, just translated to modern times, with the same crowded and dilapidated city streets and such. I guess the Silent Hill series is the closest reference I can think of for what we had in mind for looks, but it would have been pretty different from that too. We were going to somewhat modify the "rules" of the modern world to make them more conducive to the Thief-type stealth game also, and not necessarily realistic. There wouldn't be light switches that anyone can just turn on to reveal you, the enemies wouldn't all have machineguns, there wouldn't be lasers, etc. Basically we were going for a very similar type of gameplay to the original series, just in a twisted steampunkish modern setting.
It was only in pre-production for about two months before the Ion Storm "end times" began, so the concept never got much more fleshed out than this, but that's basically what it would have been.
It would have used the same engine as T3, but we were hoping it would be optimized a bit more and get some new features.
Thief mi je jedan od omiljenih naslova, tako da se ipak radujem, uzdrzano, ali se radujem🙂
I meni je Thief omiljeni serijal, samo mi se nesto ne svidja ovo nagadjanje da ce cetvrti deo biti u modernom vremenu, pokvarice samo duh i atmosveru prethodnih delova. Mada ,ko zna, ako se posmatra kao samostalna igra koja je pricom odvojena od prethodnih delova, mozda bude i dobro.
U je*o te, sto su brzi ovi moderatori! Nisam stigao cak niti objasniti!
Bas me obradovala ova vijest. Ali ovo sa modernim vremenima je bas bez veze. Koji biser se toga sjetio?
To je samo spekulacija na osnovu onog pisanija sa Through The Looking Glass foruma iz 2006. godine...ne mora da znaci da ima veze sa istinom uopste🙂
Mada...Eidos je sad u vlasnistvu Square Enixa, pa moze svasta da bude- Garett bi mogao da lici na devojcicu...:d
Znam da je spekulacija, ali jos je Ion Storm poceo raditi cetvrti Thief u modernom okruzenju.
Onda bi i Hitman mogao da lichi na devojchicu. 😀
A mozda ce to biti izmisljena buducnost u odnosu na vreme u kome se odvijala radnja u prva 3 dela, jer je vreme u prva 3 dela neodredjeno i istorijski neuporedivo sa sa bilo kojim razdobljem u ljudskoj istoriji.
Thief 4. Fuck yeaah!!!!!!!!!!!:banana:. Thief The Dark Project je bila jedna od prvih igara koje sam igrao na svom PC-u, i definitivno mi je jedan od favorita, čoveče samo kad se setim onih genijalno odrađenih black and white static picture uvoda u misiju. Uopšte igra je bila prava mala revolucija u svoje vreme, nisi morao da pobiješ sve živo oko sebe da bi uspešno kompletirao misiju, fazon je bio da ako je moguće infiltriraš na određenu lokaciju i da pokradeš sve živo, dok se stražari češu po glavi pitajući se WTF su sva svetla pogašena i zar nismo imali malo više zlata??? Sve u svemu nadam se da neće upropastiti odličan serijal.
Sjajno🙂 Me happy.
Ovo je vijest godine 🙂 Jos kada bi odradili "Vampire: The Masquerade - Bloodlines" sequel!
Snima se film THIEF 😀.[YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/oLpqXn7FJKU&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/oLpqXn7FJKU&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
Ajde da malo probudim temu iz mrtvih. 😀
Thief 4 - Online Elements, Using Unreal Engine 3?
Industrious folks on the NeoGAF forums have been combing through Eidos Montreal jobs looking for hints in Thief 4. Based on the position requirements, they have good evidence that Thief 4 will use the Unreal 3 engine (no surprise) but will also have some sort of mutiplayer or online component. Examples include a job for an "online programmer" who will be "involved in many aspects such as networking, gameplay, debugging, online and offline tools on Thief 4".
Upravo zavrsio Thief 3 cisto da udjem u pricu malo dok iscekujem Thief 4 🙂
Ako ces da udjes u pricu kako treba onda igraj keca i dvojku ako jos nisi 🙂 (zapravo ti nije potrebno ali su sjajne igre)
Ovo sam odigrao da bih video sta se toliko hajpuje i igra je stvarno bila super i dan danas. Odigrao bih ja i keca i dvojku ali mi je to vec previse unazad(grafika i to 🙁 )
Grafika je i tad bila ruzna (igrao sam ih u realnom vremenu 😀) 🙂
I ja ali mi nije smetalo tada niti mi smeta posle toliko godina. Igre su remek dela.
Thief 2 sam igrao davno ali još su mi u glavi neke misije sa kojima sam se mučio. Svako mora da odigra dvojku, igra je genijalna
Thief (2014 Reboot)
Sound the news-horn! Sound it from the highest mountains! Ready your loins! Thief is back.
Unconfirmed leak, yada yada, you know the drill. But, yes, this very much appears to be screenshots of Square-Enix’s rebooted Thief series and OHMIGOD THIS IS REALLY HAPPENING.
Update: now confirmed as real, called ‘Thief’, out on PC and next-gen consoleboxes in 2014.
It looks a lot like Dishonored, dunnit? But then Dishonored looked a lot like Thief, eh? This comes, lest we forget, from the team who did a pretty darn-tootin’ good job of Deus Ex: Human Revolution, and now they now get a swing at another PC gaming classic, hopefully with the benefit of experience and hindsight. The godfather of stealth has returned at last: what stories will he tell?
The full, original, batch of screenshots are on GamesManiac (discovered, inevitably, by NeoGAF), but I’ve put a few here for your assessment until someone tells me not to. Click on ‘em for much larger versions, if you like.
http://www.rockpapershotgun.com/201...Feed:+RockPaperShotgun+(Rock,+Paper,+Shotgun)
Link sa slikama:
http://vk.com/gamesmaniac?z=album-49981920_170847341
Nice 😉
Al su svi zaredjali sa reboot-ima, nemam nista protiv.
sjajno !!!! :whip:
ovo jedva cekam, mnogo volim Thief serijal
Sigurno cemo dobiti i novi trejler od Visual Works-a. Jos uvek nisu nadmasili svoj epski Deus Ex Human Revolution trejler. 😀
Bog otac to nece nadmasiti. 😀 Bez preterivanja, mislim da sam ga odgledao 60-ak puta. Michael McCannov soundtrack preslusan trocifreno.
Slike me opasno podsecaju na Dishonored. Jedva cekam ovo da izadje!
Nek bude u pola shmeka kakaj je bio thief 3 ja cu biti vise nego zadovoljan 🙂
