Windows 7 has got many new keyboard shortcuts.
Here are the most useful ones:
* Win+Up Arrow :- Maximize the current window
* Win+Down Arrow :- Restore Down / Minimize Current Windows
* Win+Left Arrow :- Dock the current window to the left half of the screen
* Win+Right Arrrow :- Dock the current window to the right half of the screen
* Win+Shift+Left Arrow :- Move current window to the left monitor (with dual monitors)
* Win+Shift+Right Arrrow :- Move current window to the right monitor (with dual monitors)
* Win+Home :- Minimize all but the current window
* Win+Pause :- Open the System Properties portion from the Control Panel
* Ctrl+Shift+Esc :- Open Windows Task Manager
* Win+P :- Open the projection menu (generally used for laptops connected to projectors)
* Alt+F4 :- Close the active window
* Alt+Tab :- Switch to previous active window
* Alt+Esc :- Cycle through all open windows
* Win+Tab :- Flip 3D
* Ctrl+Win+Tab :- Persistent Flip 3D
* Win+T :- Cycle through applications on taskbar (showing its live preview)
* Win+M :- Minimize all open windows
* Win+Shift+M :- Undo all window minimization
* Win+D :- Toggle showing the desktop
* Win, Right Arrrow, Enter :- Shutdown
* Win, Right Arrrow, Right Arrrow, R :- Restart
* Win, Right Arrrow, Right Arrrow, S :- Sleep
* Win, Right Arrrow, Right Arrrow, W :- Switch Users
* Win+L :- Locks computer
Ok, na to sam i mislio.
Nego jel jos uvek postoji Norton Ghost ? Pre neke 2,3 god njega su najvise preporucivali.
Hoce li neko u 5 stavki da mi objasni kako se radi backup, pa restore, bio bi vrlo zahvalan. Da ne izvrcem sad net 2h.
Sve sam instalirao. Zadnji su KB976422, KB218563, KB79538, KB2158563, KB979538. Sto se tice update za win. Zvuka uopste nema, prijavljuje da uopste nema nijednog drivera instaliranog za zvuk. A trebao bi da bude Ati jev i ovaj Realtek. Kad hocu update drivera za zvucnu, kaze imam zadnju verziju. Uninstalirao sam sve sto ne funkcionise, opet ne moze da instalira drivere.
Skinuo zadnju verziju za realtek, instalirao, opet prijavljuje da nema instaliranih drivera. Tray ikone ima X.
Restore je resio problem. E sta sad da radim? Nema vishe update a za mene? da iskljucim u potpunosti win update?
aaa ljudi imam gadan problem koji me nervira u pm vec sam ovde postavio pitanje i niko nije znao odgovor na isto nasao sam po netu odgovore ali mrka kapa dakle radi se O nestanku NEW TEXT DOCUMENT iz NEW submenu ja dakle desktop/Desni klik/New/Text Document Kako to da vratim cackao sam registar NISTA cackao tune up NISTA kako da vratim taj bull $hi*
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.txt]
"PerceivedType"="text"
@="txtfile"
"Content Type"="text/plain"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.txt\PersistentHandler]
@="{5e941d80-bf96-11cd-b579-08002b30bfeb}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.txt\ShellNew]
"ItemName"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,\
6f,00,74,00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,\
00,6e,00,6f,00,74,00,65,00,70,00,61,00,64,00,2e,00,65,00,78,00,65,00,2c,00,\
2d,00,34,00,37,00,30,00,00,00
"NullFile"=""
[HKEY_CLASSES_ROOT\.txt]
@="txtfile"
[HKEY_CLASSES_ROOT\.txt\OpenWithList]
[HKEY_CLASSES_ROOT\.txt\PersistentHandler]
[HKEY_CLASSES_ROOT\.txt\shell]
[HKEY_CLASSES_ROOT\.txt\shell\open]
[HKEY_CLASSES_ROOT\.txt\shell\open\command]
@="notepad.exe %1"
[HKEY_CLASSES_ROOT\.txt\ShellNew]
"NullFile"=""
ja stvarno ne znam zašto te update uopšte i radimo (bar mi koji imamo ver. "kupljene" na nekom dragom nam sajtu)...sem kad nema neki prob. sa nečim ili se doda nešto od hardware-a, pa update može da donese nešto korisno inače u 80% slučajeva su to neke totalno beskorisne stvari koje naprave neki "koiflikt", tačnije sudare se npr. driver za zvuk koji smo koristili na integr. kart. sa nekim dodatkom i rezlutat budu ovakvi problemčići ili još gora varijanta : ne znajući odemo na gen. test pa se posle čudimo što nam se W deaktiviro ,)
aj baš daj listu šta si skinuo, pa da vidimo šta je šta i šta je moglo da napravi takav karambol, što u principu ne bi smelo da se desi! p.s. odavno se priča o fp za w7, jel neko zna šta je s tim?
Pogledaj da li postoji ovako nešto u registru... (vidi sliku)
Ovo bi trebalo da ti pomogne...
Kod:Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.txt] "PerceivedType"="text" @="txtfile" "Content Type"="text/plain" [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.txt\PersistentHandler] @="{5e941d80-bf96-11cd-b579-08002b30bfeb}" [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.txt\ShellNew] "ItemName"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,\ 6f,00,74,00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,\ 00,6e,00,6f,00,74,00,65,00,70,00,61,00,64,00,2e,00,65,00,78,00,65,00,2c,00,\ 2d,00,34,00,37,00,30,00,00,00 "NullFile"=""
http://social.answers.microsoft.com...p/thread/022309a6-cd08-41df-8e55-95e83397ae73
ili ovo
Kod:Windows Registry Editor Version 5.00 [HKEY_CLASSES_ROOT\.txt] "Content Type"="text/plain" @="txtfile" "PerceivedType"="text" [HKEY_CLASSES_ROOT\.txt\OpenWithList] [HKEY_CLASSES_ROOT\.txt\PersistentHandler] @="{5e941d80-bf96-11cd-b579-08002b30bfeb}" [HKEY_CLASSES_ROOT\.txt\shell] [HKEY_CLASSES_ROOT\.txt\shell\open] [HKEY_CLASSES_ROOT\.txt\shell\open\command] @="notepad.exe %1" [HKEY_CLASSES_ROOT\.txt\ShellNew] "NullFile"=""
Joj, joj, joj...![]()
@="txtfile"
"NullFile"=""
Evo, ovo odradio sam export iz svog registry-a... Samo napravi .reg i pokreni
Kod:Windows Registry Editor Version 5.00 [HKEY_CLASSES_ROOT\.txt] "PerceivedType"="text" @="txtfile" "Content Type"="text/plain" [HKEY_CLASSES_ROOT\.txt\PersistentHandler] @="{5e941d80-bf96-11cd-b579-08002b30bfeb}" [HKEY_CLASSES_ROOT\.txt\ShellNew] "ItemName"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,\ 6f,00,74,00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,\ 00,6e,00,6f,00,74,00,65,00,70,00,61,00,64,00,2e,00,65,00,78,00,65,00,2c,00,\ 2d,00,34,00,37,00,30,00,00,00 "NullFile"=""
Evo i slika.
Misliš njikolaj?Meni je ta dva update-a danas na poslu nudio, PRO verzija je u pitanju dok kod kuće baš sad proverih i nema ih (isto PRO).
