Izašao je 1.21.405.2 update za Desire, i može da se skine preko "System software updates" telefona. Rešen je i problem kada poruke stižu od strane operatera, a telefon izbacuje nasumične Facebook kontakte.
Changes reported:
- Updates bootloader to 0.80
- New radio image
- New youtube app with HQ option (1.6.20E).
- Fixed htc's weather widget (integrated into clock&weather widget) not knowing where you are (1.15.xxx just said the name of the country in some countries).
- SMS issue (from non-numerical senders) is resolved.
- fixed random contact showing when receiving operator SMS.
- fixes the voicemail bug for the French carrier SFR (short voicemail number used to call 911/emergency).
- Messages app now shows a count on the number of messages in the SMS inbox.
- calendar/contacts bug - unable to store contact's birthday - has been fixed.
- Long click on the menu button when in home screen now doesnt pop up the keyboard, like it uselessly did before.
- SMS reader does not show the little smiley androids any more - just the mere types.
- Exchange Company Address Book is now properly working. Was unable to use before the update.
Ta informacija što je procurela iz HTC-a za 23. jun, nije nužno podrazumevala da će update da bude Froyo. Rekli su samo update, nisu pominjali Froyo (nezvanično, naravno).
@kovle: Po EU i sl. je od 400-450€, tako da ti se ne isplati. Jedino tamo uz neki ugovor, pa da ti donesu samo fon...
@Trek: Zvanicno i 100% sigurno je, Google objavio: FroYo
Samo je pitanje kada ce (oficijelno) 2.2, posebno za SenseUI varijante
jel ima neko informaciju kada bi Desire mogao da se ocekuje u telenoru? Vec duze vreme ga nemaju.
