Step #1
Users with firmware 1.6 begin by downloading activate.iso from this link.
http://www.megaupload.com/?d=BDULVM6J
Step #2
Once you have the activate.iso downloaded
Insert a blank DVD+R DL
Note: You must use a dual layer! CD +/- R or DVD +/- R will not work.
Step #3
Open up IMGburn and set the layerbreak setting to Optimal by going to
Tools --> Settings... --> Write -->
Select Calculate Optimal on the top left corner.
Note: Once you burn the Activate.iso you can go back to any other settings.
Step #4
Burn at 2.4x / 4x / 8x
I recommend 2.4x since it's a small file you want to make sure you have everything written on there.
Step #5
IMGburn will bring now bring to your attention that activate.iso is small enough to fit a DVD5 or (DVD +/-/R)
Ignore it and continue burning on a dual layer. Click Yes
Step #6
IMGburn will now ask if you would like to write the image on one layer. Since it's small enough to fit on one layer.
Click Yes
Step #7
Once the disc is made pop the disc into your xbox360. Let it read, after a while it will say Play DVD.
Press A on your controller and you should get a message saying to play this game please insert in an
xbox360 console. You can now eject it.
Step #8
The next game you insert in your 360 will boot regardless of stealth or Wave structure. Effectively disabling the security measure on 1.6
Warning: This disc is a one-shot boot iso meaning it will only work for the next game you insert. After you eject your wave 4 game,
1.6 stealth will be re-activated. Meaning you will need to insert your activate.iso disc again to play another wave 4 game.
Other thoughts and FAQ:
This is a temporary fix while ixtreme 1.7 is released.
