Intel's Light Peak
  • Začetnik teme Začetnik teme Stator
Stator
O cemu se zapravo radi?
Ovo je standard / kabl buducnosti!
With the initial specification set to transfer data at a blistering 10Gpbs full duplex over cables as long as 100 meters (and with speeds up to 100Gbps lined up for future revisions), a single Light Peak connection could replace DVI, USB, gigabit Ethernet, FireWire, eSATA and just about anything else that would connect your computer to its environs.
Jedan standard za sve: monitore, diskove, kamere, povezivanje kompova itd.
Ja jedva cekam 🙂
Predstavljanje u Intel labaratoriji
http://www.youtube.com/watch?v=izNoF1SWtSg
Intel Light Peak Demo @ IDF 2009
http://www.youtube.com/watch?v=khPx1dEIPnA
nije za sve 😉 samo za neke napredne stvari 😉
Bravo Milane🙂
Kako stvari stoje, za ovo je definitivno zaslužan, pored Intel-a, i Apple, sviđalo se to nekome ili ne.
Inače, nisam neki Apple -fun-boy, ali ne volim kad se kritikuje bez razloga, eto.
interesantan presek link 😉
jedan u klin, drugi u ploču 😀
"Apple, Intel and the ports business
What Intel has and Apple lacks on its own is the ability to garner widespread adoption of new cabling schemes and the economies of scale that follow. Back in the 80s, Apple largely just ignored the generic PC world and its third-rate port specifications. While PCs shipped with RS-232 serial ports and Centronics parallel ports for printing and slow disk drives, Apple gave its Macs an improved RS-422 serial port that was backwardly compatible but offered the ability to accommodate AppleTalk/LocalTalk networking.
On the other hand, Apple also adopted the high performance SCSI interface for hard drives and printers and scanners, something that was deemed too luxuriously expensive for mainstream PCs. That subsequently kept SCSI and its interface support chips relatively expensive to manufacture.
Steve Wozniak's Apple Desktop Bus was adopted by Apple in 1986 for connecting together a variety of input devices and serial peripherals, from keyboards and mice to stylus tablets, barcode scanners and video cameras. Despite some use outside Apple by Sun and NeXT, ADB similarly never caught on among generic PCs, which continued using two PS/2 connectors, one for the keyboard and one for the mouse. That similarly helped keep ADB peripherals relatively expensive.
Apple then developed FireWire as a high speed cabling system that could accommodate the future needs of digital video and replace SCSI with simpler cabling. This too was slow to broadly catch on among PC makers. Intel delivered its own USB specification as a slow, ADB-like peripheral connection standard to replace RS-232 serial, Centronics parallel, and PS/2 connectors on PCs. While it didn't initially gain much attention among PC users, Apple adopted USB as a way to jettison both ADB and serial ports on the iMac, and kickstarted the market for low speed USB peripherals.
Intel then upgraded the USB standard to 2.0, a move that encroached upon the performance of FireWire (without actually delivering many of the features FireWire was designed to provide). This effectively killed any mainstream market for FireWire outside of niche markets, and again subsequently kept FireWire relatively expensive to implement.
Stronger together
On their own, Apple and Intel had limited success in promoting new standards into the mainstream; together, the pair seemed to be very complimentary partners. Intel acts as the establishment insider, holding down prices with high volume mainstream production, while Apple serves as the vanguard, pushing new technologies into an industry notoriously resistant to change."
nastavak na gornjem linku. ima dosta odgovoara i na chupo92 pitanje 😉 (bez da se spominje EFI koji će pre ili kasnije doći i na PC)
btw nije mi jasno zasto su uopste zakomplikovali npr. USB sa 3 različite vrste konektora...
Pa verovatno zato što na nokiju ne bi mogao povezati standardni USB, a micro USB ne drži dovoljno dobro za neki gamepad...
ajde ok za nokiju i te "prosirene USB" ali zbog cega postoji npr. onaj kockasti USB za stampace?
za micro USB si u pravu - najverovatnije nije dovoljno "stabilan" za neke primene... ovoga se stvarno nisam setio :/
Samo pogledati koliko neistina ima u ovom linku. PC imam Gigabitni Ethernet već od 2004-te, a teško mi je da poverujem da ga je apple imao od početka 2000. godine. :trust:
Dodjavola ljudi! Jel iko razmisli pre nego sto postuje ili je Apple vs ostali default ponasanje i u temama o pleskavicama?
Ocekivao sam neke komentare tipa: koliko ce taj metar optike kostati, da li ce imati bakar u sebi ? Ako nece imati kako cu onda napajati svoj externi hard itd. Da li nam to stvarno treba pored eSata standarda i USB 3.0.
Ali neeeeeee zasto praviti konstruktivnu raspravu kada je mnogo bolje trolovati forum...
USB * 3, FireWire, SATA, eSATA, LAN... mnogo prikljucaka i mnogo standarda. Bilo bi dobro kada bi se to svelo na nesto jedinstveno i univerzalno.
Ako Intel zaista uspe da isporuci to sto obecavaju...pa to bi mogla biti mala revolucija. Samo ostaje pitanje cene.
MS je po pitanju cena dobrotvorni davaoc u odnosu na Apple, to niko nemože osporiti.
Back on topic, interesuje me mehanička izdžljivost ovih kabela, i koliko su savitljivi, jer imam osećaj da će se lako "zalamati".
Pa generalno optiku nije preporucljivo savija vise od nekih 60 stepeni 90 je vec veoma kriticno. Sto mislim da je podnosljivo za vecu zelja korisnika.
Tu će i nastati problemi, ja recimo kablove (UTP,USB i Audio) vezujem za "nogare stola", i na nekim mestima se zalamaju po 90 stepeni.
Mada sumnjam da će dozvoliti mogućnost da se kabal zalomi, ipak mislim da će ga projektovati propisno.
Iako se tako čini, ne radi se o ničem novom. Mainframe tehnologije (FICON, wiki FICON) dolaze na PC. Osnovna upotreba: serveri, SAN, umrežavanje, virtualizacija ....
E sad, zašto inzistirati da apsolutno svako povezivanje periferije ide preko fiber optike kad to nije potrebno, a pitanje da li će ikad biti?
nego sad se setih nečega:
pa preko LightPeaka neće moći da se napaja ni jedan uređaj! (osim ako ne izmisle kvantni-expra-modulator 😀)
preko USB masa periferija radi bez eksternog napajanja što sa LightPeakom neće biti slučaj!
Mozda zajedno sa optickim kablom provuku i bakarnu paricu.
pa preko LightPeaka neće moći da se napaja ni jedan uređaj! (osim ako ne izmisle kvantni-expra-modulator )
Ljubi ga majka pametnog 😀
ne znam kako sam to prevideo... :d
Intel Labs' Light Peak interconnect tehnologija
[YOUTUBE]nfGevFIVKw4[/YOUTUBE]
Sve je objasnjeno u videu.
Pitanje da li ce krajnjim korisnicima trebati pored USB 3.0
Vidimo da je FireWire postojao ali koliko ljudi ga je koristilo?
Koliko ce ovo poveceti cene uredjaja?
Ploca, periferija... i da li ce mo mi morati da placamo 18% ako kupujem monitor sa ovim ulazom! 🙁
uspeh ovoga ce iskljucivo zavisiti od Intelove volje da saradjuje na razvoju standarda!
Pogledajte sta se desilo sa USB 3 i koliko se "poradjao" samo zbog politicenja i merkanja "time-to-market" momenta od strane Intela i cinculiranja sa finalizacijom standarda
Intel Light Peak Tehnologija
Evo da otovrim novu temu za diskusiju oko nove tehnologije koju razvija Intel.
Za ovu novu tehnologiju sam nacuo pre par meseci, a evo u ovom tekstu pise da ce se izgleda pojaviti i pre 2012. godine. Navodno, bice 2 puta brza od USB 3 tehnologije.
http://www.electronista.com/articles/10/11/03/inte.light.peak.may.get.early.debut.apple.first/
Stavio sam ovu temu u ovaj podforum, posto je moguce da ce ova tehnologija biti koriscena i za izradu memorijskih stikova.
hvala. nije mi jasno kako nisam nasao pretragom, ali u svakom slucaju posto vidim da je poslednja poruka u tom postu bila od 3. oktobra, mozda neko od moderatora moze da prebaci moj post na pravo mesto 🙂
