Probao
NBA zahteva oanj C distribution i directx nov probaj prvo to updatuj, nadji na netu najnovije verzije
Probao
Two new candidate builds, 6.1.7264.0.win7_rtm.090622-1900 and , has been assembled in the RTM branch (win7_rtm), according to WZor. Therefore, the current builds in the RTM branch are:
6.1.7260.0.win7_rtm.090612-2110
6.1.7261.0.win7_rtm.090615-1900
6.1.7262.0.win7_rtm.090617-1900
6.1.7263.0.win7_rtm.090619-1900
The build with the name “6.1.7264.0.win7_rtm.090620-1900” is a fake as the build 7264 was assembled on 22nd of June and not 20th. More candidate builds may appear in next few weeks...
01.06 - 19.06
building rtm escrows
22.06 - 10.07
rtm recall
10.07
windows 7 rtm final build target
13.07
windows 7 rtm sign-off
Click Start –> type CMD and right click Run as Admin
diskpart
list disk
select disk 1 (your primary hard drive is denoted disk 0)
clean
create partition primary
select partition 1
active
format fs=fat32 quick
assign
exit
Open your drive under explorer, copy all files from vista/7 iso to the usb drive
AndrewRt je napisao(la):How to burn Image to a Flash Drive
1. Get a copy of UltraISO
Kod:xxxx - obrisah linkove
2. Open the Win7build7100 Image with UltraISO
3. Select your "USB" Drive
4. Go to the "Bootable" tab and select "Write Disk Image..."
5. Next you need to "format" the flash drive. This will erase everything currently on your flash drive so back up the stuff you want!
6. "Write" the image to the disk.
7. Writing done
Now all you need to do is boot up with it plugged in and make sure your BIOS is set to boot from USB first.
Ja sam ga instalirao samo zato sto mi trenutno win 7 x64 ne nalazi drivere za scanner, a kroz virtual XP radi bez problema. Probao sam i tv karticu jer nisam isprva provalio kako da mi proradi i daljinski. Ona nije htela da radi. E sad, ja nisam drivere za plocu instalirao u virtual xp a drivere za grafiku sam ostavio te koji dolaze sa tim xp sp3 ( i njega sam download-ovao sa Microsoft site-a). Ti probaj da instaliras drivere za plocu, zvuk i grafiku pa onda probaj i tv kartu pod virtualnim xp, ko zna, mozda proradi i pod njim.
Da li mi mozda treba DualCore Optimizer za Win7, ili mozda neki AMD Processor Driver?
OK, a kakva je situacija sa Nerom? Instalirao sam v7.0.1.2 Premium [samo Burning Rom], prijavio mi je error na kraju instalacije ali program je tu. Nisam josh nista rezao sa njim, vredi li da skidam nesto novije ili je i ovo dovoljno.![]()
Pratim ovaj thread vec dugo i procitao sam ga celog, cisto onako iz opsteg interesa. Ali sad mi je zatrebala konkretna informacija, za koju se ne secam da li sam je negde procitao:
Koji su minimalni hardverski zahtevi za masinu da bi imalo smisla instalirati Win7? (Ne po specifikaciji Microsofta, nego po vasem licnom misljenju i iskustvu)
Kod mene je Nero Micro 8.2.8.0, fercera kako treba.
Microsoft objavio cene za Windows 7
Sreda, 1. jul 2009. 05:57
Kompanija Microsoft ovih dana predstavila je cenovnik najnovijeg Windowsa, koji bi na tržištu trebalo da se pojavi krajem oktobra.
Iako opcija apgrejdovanja na novu verziju prvobitno neće biti dostupna u Evropi, već samo na tržištu Amerike, Evropski regulatori tvrde da takva odluka Microsofta ograničava izbor kupcima.
Windows 7 pojaviće se u tri verzije, pa će tako za Home Premium biti potrebno da se izdvoji oko 130 američkih dolara. Za Professional verziju biće potrebno oko 315 dolara, dok će Ultimate verzija koštati oko 330 dolara.
Windows 7 će se proizvoditi u verzijama od 32 i 64 bita.
Ovaj opertaivni sistem će, između ostalog, manje trošiti električnu energiju, biće efikasniji i biće povezaniji s mobilnim telefonima.
Ukoliko korisnik ima dva računara, sistem treba da omogući automatsku sinhronizaciju fajlova, tako da on ne mora stalno da šalje fajlove s jednog uređaja na drugi.
(MONDO)
Ako ne verujesh da OS moze da troshi manje struje, pogledaj ovaj chlanak:
http://anandtech.com/mac/showdoc.aspx?i=3582
Tj. pod Mac OS-om macbook radi 8 sati, dok pod Vistom i Win7 oko 6 sati.
Jesi li preuzeo ownership nad njima?Jel ima neko pojma zasto ne mogu nekim fajlovima da promenim permissions u full control iako sam ulogovan kao administrator???
takeown /f %1 /r /d y
icacls %1 /grant administrators:F /t
