Oficijelni Core i7 thread
illidan
- Bike Camper -
CPU & Cooler
amd 5800x3d, cm atmos 240 - phanteks t30
Matična ploča
asus rog strix b550-i gaming
RAM
g.skill trident z neo 32gb cl16 3600
GPU
nvidia rtx 4070super founders edition
Storage
samsung 980 pro 1tb, wd black sn770 2tb
Zvuk
ifi zen dac v2 - fosi audio za3 - kef q350, fiio ft1, all balanced
PSU
corsair sf750 platinum
Kućište
lian li a4 h2o
Monitor
gigabyte mo27q28g
Miš & tastatura
g-wolves hts plus pro 8k, kbd.fans tofu65 raw alu - cream soda switches - gmk serika 2 keycaps
Pristup internetu
  1. Optički internet
evo i od team xtreem-a memorije
Teamgroup Xtreem/Xtreem Dark DDR3-1333/1600/1800/1866 Triple Channel kits
* Press release - TBA
* Team Group Xtreem TXD36144M1866HC9DC DDR3 1866 [email protected] 6GB Kit(3x2GB) optimized for XMP
* Team Group Xtreem TXD33072M1866HC9DC DDR3 1866 [email protected] 3GB Kit(3x1GB) optimized for XMP
* Team Group Xtreem TXD36144M1800HC8DC DDR3 1800 [email protected] 6GB Kit(3x2GB) optimized for XMP
* Team Group Xtreem TXD33072M1800HC8DC DDR3 1800 [email protected] 3GB Kit(3x1GB) optimized for XMP
* Team Group Xtreem Dark TXD36144M1600HC8DC DDR3 1600 [email protected] 6GB Kit(3x2GB) optimized for XMP
* Team Group Xtreem Dark TXD33072M1600HC8DC DDR3 1600 [email protected] 3GB Kit(3x1GB) optimized for XMP
* Team Group Xtreem Dark TXD36144M1333HC7DC DDR3 1333 [email protected]~1.6V 6GB Kit(3x2GB) optimized for XMP
* Team Group Xtreem Dark TXD33072M1333HC7DC DDR3 1333 [email protected]~1.6V 3GB Kit(3x1GB) optimized for XMP
Evo jos jednog testa ovde.
Cak je i u igrama na high-details, po ovome, ogromna razlika (gledajuci QX9770 vs i7-965)...
"Intel has also added PCI Express links directly into the CPU die" lol :zgran:
CPU nije da je dobar, nego ubija kako radi, mada zasad mi se chini da je i on gladan struje za OC oko 4G.... Skoro pa isto kao C2Q :trust:
^^ Pa nikad u istoriji racunara nesto nije bilo proporcionalno bolje koliko je skuplje, a izgleda da nece ni skoro tako da bude, cena mu je bash na mestu, 260 zelenih za najslabiji model je OK cena po meni, toliko bre koshta Q9550, a od njega je fino brzi, zar ne?
Kad se uporedi skok performani sa proslim generacijama procesora, to je obicno bilo <20%, a ovde ima ubrzanja cak i do citavih 50%... Ne da su ga napravili, nego im treba odati priznanje 🙂
potpuno se slazem sa tobom 😉
hehe ja taman hteo da okachim 🙂 ali si bio brzi 🙂
50% sam video samo u sintetici (citaj nebitno), realno je to 20ak% sto da se razumemo uopste nije lose. Za cene cemo videti, to su cene za Ameriku, praksa je pokazala da se dolari preslikavaju u evre, ali na to dodajte memoriju i plocu.
ps Setite se skoka sa Pentium D na C2D 😉
SLI izgleda mnogo bolje radi na i7
http://hothardware.com/Articles/Intel-Core-i7-Processors-Nehalem-and-X58-Have-Arrived/?page=14
Evo vam upozorenja:
Getting back to that 1.65V warning, Intel is quite serious about this voltage level and is ensuring the board manufacturers remind the users in a variety of ways ranging from statements in the user manuals to various BIOS warnings when changing VDimm above 1.65V.
We have been running exhaustive tests at various voltages and firmly believe that if VCore, QPI/IMC Voltage, and VDimm are properly aligned, that running VDimm up to 1.80V should be acceptable with proper cooling and non 24/7 operation. Of course that is not a promise, but we will have additional results shortly.
In the meantime, Intel also recommends not taking QPI/IMC (uncore) voltages above 1.3V. In fact, we think this setting is just as dangerous as or more so than high VDimm to the processor’s long term health.
Kako stoji on sa potrosnjom/grejanjem. Prvenstveno me zanima kada ce da krene sa mobilnim varijantama za LapTop-ove. I da li ovo znaci da ce 4 jezgra da relativno brzo postanu standard za lapove ko sto su danas 2 ?
Evo vam upozorenja:
Ocigledno totalno nebitno: ko hoce da igra po pravilima, imace DDR3 module na 2 GHz koji rade na 1.65V. Ko ima stare module - radice mu i oni, ali uz uobicajeno O/C rizik.
Enivej, sasvim je za ocekivati da ce vecina entuzijasta da poleti da kupuje nove 2 GHz DDR3 1.65V module, jer ce se isti overklokovati jos bolje od starih.
Performance
Core i7 does not disappoint in any area. The reviews show us that this latest processor sets a new standard of performance that's so high, AMD might not be able to ever catch up in our opinion.
On every benchmark that is CPU-intensive and not externally compute-limited, such as the 3D graphics card being the limiting factor, Intel's Core i7 not only dominates, but actually makes things embarrassing for AMD and in some instances Core 2. Scores which literally double those (or more) of AMD's Phenom X4 9950 Black edition are often seen.
http://www.tomshardware.com/reviews/Intel-Core-i7-Nehalem,2057.html
@Stator:
Potrosnja i grejanje na nivou ili malo jace od ekvivalentnog quad-core Penryna koliko ja vidim po testovima. Mobilne verzije nece biti pre H2 2009.
@delimir:
E znas sta, stvarno pocinjes da mi ides na zivce sa ovako glupim komentarima i tvojom vecitom zamenom teza!
Upozorenje koje sam okacio je namenjeno pre svega onima koji bi da overklokuju Nehalem, a ni obicnim korisnicima nije na odmet da to znaju jer ovo nije soba za vesti, dakle daleko je od nebitnog.
Ako nastavis sa tom praksom omalovazavanja cinjenica kad god ja napisem neku tehnicki relevantnu informaciju u vezi Intela i njegovih proizvoda u ovoj sobi pokrenucu peticiju da ti ispod username-a napisu "Intel PR" umesto "VIP member".
Svi ovde znaju da ja volim Intel, ali ti si na dobrom putu da mi ga ogadis ako te neko ne spreci u tome. Uopste nije trebalo Nedji (na tvoj zahtev i ucenjivanje!) oduzeti moderatorski status jer si se ti bas osilio od kad se to desilo, a nikakav kredibilitet ni znanje ne stoje iza tvoje price. Ako ti nisi u stanju sam da se kontrolises i da budes objektivniji, a niko drugi na benchu ne sme ili ne zeli, onda cu ja da te uzmem na zub i da ti trazim gresku u svakoj reci koju napises nezavisno od teme.
Iskuliraj malo, idi vozi bajs na Adi i cuvaj bolesnog psa. Ne znam sto si toliko revoltiran, kivan i nervozan. Nema razloga - posebno ne bi trebalo da se tako ponasas posto si karatista 🙂
Znaci, lepo je vreme napolju, prosetaj malo i iskuliraj se - nema potrebe da skreces temu u pogresnom smeru. Ovakvim komentarima omlovazavas samo sebe i pokazujes da si netolerantna i asocijalna osoba sto svakako nisu vrline. Ne znam da li je to istina, ali mi tako deluje.
AKo sam necim povredio tvoja osecanja i dusevni mir, ja se evo izvinjavam javno i molim moderatore da sporni komentar (u nastavku) obrisu - posebno, ako ce ti to pomoci da se osecas makar malo bolje.
Ajde sada lepo procitaj komentar, pa razmisli da li je tvoja replika na mestu i da li tako reaguje zrela osoba.
Znaci, ne znam sta si ti danas radio i sta ti se desilo, ali ovo je komentar koji iskazuje moje misljenje - i zaista, ja sam toliko cesto menjao hardver da mi ovo deluje kao skroz OK rezon, posebno za nekoga ko kesira 600 USD za CPU+plocu. Opet, kazem - totalno je nebitno, ako cu pomoci da se ti osecas bolje, moze komentar i da se izbrise.
Ako imas bas toliko slobodnog vremena da pratis svaki moj post i ispravljas ga u skladu sa nekim tebi znanim kriterijumima, nemam nista protiv, ali bolje da to vreme iskoristi produktivnije - previse ozbiljno shvatas pisanija po forumu - ovo je neformalna diskusija, just fyi.
Pozdrav.
@delimir:
Pokusacu da ti objasnim bez zelje da se upustam u dalju raspravu -- "ocigledno totalno nebitno" je deo tvog posta koji mi je sporan.
90% ljudi ce procitati taj pocetak recenice i primiti ga zdravo za gotovo, a u pitanju je drsko omalovazavanje onoga sto sam ja podvukao i sto smatram korisnim znanjem za sve koji prate ovu sobu i teme u njoj. Verujem da ce se vecina sloziti sa tim.
Takodje, mislim da nije problem u meni, vec u tome da si ti malo preozbiljno shvatio svoj posao -- udaras mi kontru kao da ce se u Srbiji prodati manje Nehalema samo zato sto sam ja rekao da treba biti oprezan sa naponima pri overclocku.
Sve u svemu, niko ne spori da je Intel jaci nego ikada, da je novi procesor dobar, ali da je isplativ za svakog to nije, a za stabilan 24/7 O/C treba ipak malo vise strucnosti, truda, skuplje opreme i opreza nego za Core 2 familiju.
To je sve sto ja imam da kazem na ovu temu, a ti ako mozes pokusaj da budes objektivniji i da ponekad kazes i nesto kriticno prema Intelu kada zasluze umesto sto ih samo hvalis.
najverovatnije, treci kvartal sledece godine 😉
Sve je to super ali preskupo za sada. Za 99% ljudi s foruma i nepotrebno, no fino za čitanje testova.
@MadMan
Pazi nije nepotrebno pogotovo za ljude koji dosta renderuju... Evo meni bi i te kako sela jedna Core i7 bazirana masina za Maxwell rendering, no morace da saceka to malo posle nove godine.
