Crysis Benchmark CPU/GPU [HIGH]
4/2/2008 22:41:32 - XP
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX9 1280x1024, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: High
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 56.03s, Average FPS: 35.70
Min FPS: 21.22 at frame 138, Max FPS: 44.78 at frame 1773
Average Tri/Sec: 35177096, Tri/Frame: 985404
Recorded/Played Tris ratio: 0.93
!TimeDemo Run 1 Finished.
Play Time: 50.83s, Average FPS: 39.35
Min FPS: 21.22 at frame 138, Max FPS: 45.58 at frame 1022
Average Tri/Sec: 39182268, Tri/Frame: 995774
Recorded/Played Tris ratio: 0.92
!TimeDemo Run 2 Finished.
Play Time: 50.79s, Average FPS: 39.38
Min FPS: 21.22 at frame 138, Max FPS: 47.34 at frame 1009
Average Tri/Sec: 39226932, Tri/Frame: 996172
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 39.365
konfiguracija iz potpisa, procesor, grafika na default
Da li su ok rezultati ok? Cini mi se nesto mali average fps.
Sa malim zakasnjenjem saljem skorove 9800GTX
Ocajnih 54 fps-a.
Ko sad kupuje graficku, treba da cilja na onaj Club3D 8800GTS 512MB za 230e, ubedljivo best buy u najvisoj klasi, u srednjoj - 9600GT za 140e.
8800GT ispada iz trke, po mom misljenju.
A evo i rezovi 8800GTS na istoj masini, samo mi nije jasno kako je to GTS brzi od 9800GTX-a
    197.3 KB · Pregleda: 97
@1965 - Ako nisi clockao grafu, rez je ok.
Aj da se i ja utopim u prosek 😀.
Palit 9600GT@750/1875/2000
4/1/2008 4:39:56 PM - XP
Play Time: 62.01s, Average FPS: 32.25
Min FPS: 14.85 at frame 151, Max FPS: 40.73 at frame 1778
Average Tri/Sec: 31788150, Tri/Frame: 985561
Play Time: 55.73s, Average FPS: 35.89
Min FPS: 14.85 at frame 151, Max FPS: 41.14 at frame 982
Average Tri/Sec: 35741780, Tri/Frame: 995857
Play Time: 55.66s, Average FPS: 35.94
Min FPS: 14.85 at frame 151, Max FPS: 41.24 at frame 1771
Average Tri/Sec: 35792520, Tri/Frame: 996017
Completed All Tests
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 35.915
Evo mi mog rezultata 😛 Kad nabavim patch 1.2 onda cu da ponovo odradim test.
CPU 2888MHz
GPU 700-1612-2000
Running GPU benchmark 1
Results will depend on current system settings
Press any key to continue . . .
Running...
Play Time: 142.36s, Average FPS: 14.05
Min FPS: 8.65 at frame 141, Max FPS: 17.15 at frame 992
Average Tri/Sec: 14213729, Tri/Frame: 1011743
Recorded/Played Tris ratio: 0.91
Play Time: 140.88s, Average FPS: 14.20
Average Tri/Sec: 14498460, Tri/Frame: 1021263
Recorded/Played Tris ratio: 0.90
Play Time: 140.59s, Average FPS: 14.23
Min FPS: 8.65 at frame 141, Max FPS: 17.95 at frame 1760
Average Tri/Sec: 14523436, Tri/Frame: 1020922
!TimeDemo Run 3 Finished.
Play Time: 140.37s, Average FPS: 14.25
Average Tri/Sec: 14553786, Tri/Frame: 1021443
TimeDemo Play Ended, (4 Runs Performed)
Ma sa patchom 1.2 meni je fps potpuno isti bio...
[OFFtopic] Plus shto me smorio taj patch jer su ubacili onaj debilni zvuk kad nekog pogodi tvoj metak. Chuje se preglasno, al ajde shto se chuje kad si blizu neprijatelju, vec ono i kad je na 50m od tebe kako ga pogodi metak tako se chuje ko da je na metar od tebe.... :wall: Tako da sam reinstalirao igru i odradio samo patch 1.1... Ako neko zna kako se taj zvuk utishava bio bih mu zahvalan...
Lame feature preuzet iz CoD-a.Resavas ga ovako:
U konzolu ukucas, ili editujes cfg:
g_useHitSoundFeedback [0,1] - This setting controls the new sound effect which occurs whenever your bullets hit the enemy. By default it is enabled, and any time you successfully hit an enemy target, even over a long distance, you'll hear a slight but distinctive 'thud'. If you wish to disable this and return to the way things were prior to the 1.2 patch, set this variable to =0.
4/6/2008 2:16:28 PM - XP
Beginning Run #1 on Map-island, Demo-benchmark_cpu
DX9 1680x1050, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
TimeDemo Play Started , (Total Frames: 1500, Recorded Time: 44.62s)
Play Time: 61.55s, Average FPS: 24.37
Min FPS: 13.83 at frame 196, Max FPS: 40.87 at frame 345
Average Tri/Sec: 27121052, Tri/Frame: 1112927
Recorded/Played Tris ratio: 0.65
Play Time: 47.78s, Average FPS: 31.39
Min FPS: 13.83 at frame 196, Max FPS: 44.48 at frame 123
Average Tri/Sec: 35040776, Tri/Frame: 1116141
Recorded/Played Tris ratio: 0.64
Play Time: 47.66s, Average FPS: 31.48
Average Tri/Sec: 35141384, Tri/Frame: 1116480
Completed All Tests
Run #1- DX9 1680x1050 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 31.435
4/6/2008 2:28:34 PM - XP
Demo Loops=4, Time Of Day= 9
Play Time: 77.71s, Average FPS: 25.74
Min FPS: 14.70 at frame 153, Max FPS: 39.67 at frame 885
Average Tri/Sec: -25034934, Tri/Frame: -972676
Recorded/Played Tris ratio: -0.94
Play Time: 64.87s, Average FPS: 30.83
Min FPS: 14.70 at frame 153, Max FPS: 42.42 at frame 992
Average Tri/Sec: -29583070, Tri/Frame: -959595
Recorded/Played Tris ratio: -0.96
Play Time: 64.94s, Average FPS: 30.80
Min FPS: 14.70 at frame 153, Max FPS: 42.63 at frame 993
Average Tri/Sec: -29557752, Tri/Frame: -959697
Play Time: 64.79s, Average FPS: 30.87
Min FPS: 14.70 at frame 153, Max FPS: 42.75 at frame 995
Average Tri/Sec: -29628198, Tri/Frame: -959761
Completed All Tests
Run #1- DX9 1680x1050 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 30.833
Evo ga mali update od mene za CPU test...
4/11/2008 7:09:25 PM - XP
Play Time: 55.82s, Average FPS: 26.87
Min FPS: 7.51 at frame 196, Max FPS: 44.48 at frame 119
Average Tri/Sec: 29367426, Tri/Frame: 1092845
Recorded/Played Tris ratio: 0.66
Play Time: 46.02s, Average FPS: 32.59
Min FPS: 7.51 at frame 196, Max FPS: 44.95 at frame 80
Average Tri/Sec: 35722392, Tri/Frame: 1095947
Play Time: 47.00s, Average FPS: 31.91
Average Tri/Sec: 35020868, Tri/Frame: 1097366
Completed All Tests
Run #1- DX9 1680x1050 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 32.25
Izgleda da sam ja jedini koji se jos zamlacuje sa ovim g*vnetom...😀
CPU@ 2.7GHZ ,MEM@760MHZ
5/26/2008 2:17:08 AM - XP
Play Time: 59.53s, Average FPS: 33.60
Min FPS: 18.93 at frame 157, Max FPS: 52.70 at frame 982
Average Tri/Sec: 33102000, Tri/Frame: 985214
Play Time: 49.96s, Average FPS: 40.04
Min FPS: 18.93 at frame 157, Max FPS: 56.30 at frame 998
Average Tri/Sec: 39849800, Tri/Frame: 995371
Play Time: 49.69s, Average FPS: 40.25
Average Tri/Sec: 40095964, Tri/Frame: 996142
Completed All Tests
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 40.145
5/26/2008 2:25:17 AM - XP
Play Time: 45.68s, Average FPS: 32.84
Min FPS: 16.67 at frame 1093, Max FPS: 49.88 at frame 336
Average Tri/Sec: 32068644, Tri/Frame: 976605
Recorded/Played Tris ratio: 0.74
Play Time: 38.06s, Average FPS: 39.42
Min FPS: 16.67 at frame 1093, Max FPS: 58.08 at frame 106
Average Tri/Sec: 38541920, Tri/Frame: 977810
Play Time: 37.91s, Average FPS: 39.57
Min FPS: 16.67 at frame 1093, Max FPS: 58.30 at frame 107
Average Tri/Sec: 38615512, Tri/Frame: 975907
Completed All Tests
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 39.495
Inace,za one koji se secaju,onaj problem od pre par stranica sam resio flesom biosa ploce.Poz
56.365
CPU : 4.0 Ghz...Intel Quad Core Q9550
VGA :Asus 8800 GTS G92
GPU : 835
Memory :1100
Shader : 2040
MIN FPS :34.38
MAX FPS :65.26
AVERAGE FPS :56.365
    95 KB · Pregleda: 131
Ovo je najbolji rez sa single kartom do sada 🙂
Jedva cekam da se pojave novi Radeti u ovoj temi😀
radeon 3850 (256) 755-2100 32.345
    86.6 KB · Pregleda: 80
GPU : 837
Memory :1105
Shader : 2080
MIN FPS :32.87
MAX FPS :70.32
AVERAGE FPS :57.665
    93.4 KB · Pregleda: 308
Beast ajde uradi i na very high,
Evo kako je dobio jedan lik sa drugog foruma sto sam ga zamolio da uradi i u 1280x1024 sa GTX280.
Core: 730mhz
Shader: 1475mhz
Mem: 2600mhz
Vista64 FW177.39
Results at 1280x1024, same settings as above.
No AA:
Average FPS: 51.86
Min FPS: 33.49
Max FPS: 72.82
2xAA:
Average FPS: 47.79
Min FPS: 29.37
Max FPS: 67.97
4xAA:
Average FPS: 44.46
Min FPS: 29.57
Max FPS: 59.31
A above settings su
Crysis Bench: 1680x1050 - All settings very high, shaders on high
Core: 730mhz
Shader: 1475mhz
Mem: 2600mhz
Vista64 FW177.39
No AA:
Average FPS: 51.86
Min FPS: 33.49
Max FPS: 72.82
2xAA:
Average FPS: 47.79
Min FPS: 29.37
Max FPS: 67.97
4xAA:
Average FPS: 44.46
Min FPS: 29.57
Max FPS: 59.31
A above settings su
Probao sam Tweak da ukljucim na Very HI ali nije hteo da otvori...
@vlado_kovac@ Thanks.
Core: 730mhz
Shader: 1475mhz
Mem: 2600mhz
Vista64 FW177.39
No AA:
Average FPS: 51.86
Min FPS: 33.49
Max FPS: 72.82
2xAA:
Average FPS: 47.79
Min FPS: 29.37
Max FPS: 67.97
4xAA:
Average FPS: 44.46
Min FPS: 29.57
Max FPS: 59.31
A above settings su
Auu,extra rez,ako i oc GTX 280-ke! Mrzi me sad da citam celu temu,jel ima neko da je postovao very high rezultat pa da uporedimo?
@PCBeast: odlican oc,jel mozes da igras bez bagova na tim frekvencijama ili izdrzi samo da okrene GPU test?
@OCz: Jel imas neke rezove na high od nekog usera sa GTX 280 ?
@DAS@Sa malo nizim frekfencijama moze...Poenta je samo sto bolje ohladiti karticu,sam GPU a najbitinije naponsku sekciju i tad i na najvisim klokovima nece da puca...Inace sad je problem toplih dana pa se temperatura samog GPU-a popela 10c+ tako da ove frekfencije za realan rad ne prolaze..Recimo 830/1100 opusteno uz dobro pregrevanje GPU-a cak i sa Zalmanom u Crysis i do 86c....Znaci mucio sam je i na 856/1110 kad je hladna radi korektno bez trzaja...Cim se naponska sekcija pregreje odmah puca...Ima o tome objasnjavao sam na sx-team forumu...Opet kazem,sad je vec leto i tesko je zbog same vrucine uspeti izvuci stabilnost na tako visokim clockovima...Pozz.
Tomas sve je to extra ali ja bi se zabrinuo sa takvom temperaturom kartice. Nego aj odradi test sa 4xAA ili cak 8x ako ti nije frka :wave:
sigurno bi spusio temp još jer je amb tem oko 28c jer nisam palio klimu😉 a i te temp su samo u krizi ove ostae igre od 85 do 87c
Hvala na iscimavanju! ZAista mala razlika izmedju 4 i 8, to me je najvise zanimalo! U svakom slucaju extra je igrivo na high sa ti popaljenim cudima! :wave:
nemam sli matičnu
