Intel chopper from OCC
digitalis888
Intel and Orange County Choppers* (OCC) Teamed up and creted one of the meanest bikes ever built.
This Chopper has a four cylinder dual V-twin motors compined with Intel® quad-core processors enable a new level of performance.
The Chopper’s central management console is controlled through the SwitchBack* PC, the world’s first rugged, ultra-mobile personal computer (UMPC) from Black Diamond Advanced Technology*, an Intel® Communications Alliance (ICA) member, featuring Intel® Celeron® processor platform technology. A kind of a tablet Pc it can be de-attached from the chopper and used as a all different computer tablet.
This chopper has no rear view mirrors, replacing this are 2 cameras which give the video out in the central controller.
No Worries If you loose the keys, Because this chopper really has no keys. All you have to do to start the machine is just put your thumb on the finger print reader and the beast will start.
http://macrohard-stuffs.blogspot.com/2007/12/intel-chopper-from-occ.html
Momci su umetnici...svaki brend koga se "dohvate" postane josh veci
-Mali daj kljuceve.
-Ummm, pa ovaj.Znaaate ...
Chop!Chop!
AAAAAAAA !!!
Zamislite tek da prepoznaje mreznjacu oka 😛
Pride vozis motor sa stickerom "Intel inside" 😀
Ono, lozis se i pricas 1600 kubika, 100 konja, karbonski diskovi, C2Q6600 ali [email protected] 😀
Kad malo bolje pogledaš, noge će ti biti priljubljene uz auspuh cijevi 😉.
U paketu opreme idu i azbestne hlače 😀.
Jao jedva cekam da vidim Paul Seniora kako se svadjao dok su pravili motor, mogu zamisliti shockove kada su sprckali nesto od high tech elektronike na motoru...hahaahahahHAHAHAHAhhahahahah
Ova epizoda je vec bila na Discovery-iju,nista spektakularno,tablet umjesto kontrol table,2 kamerice umjesto retrovizora i Quad nalepnice na sve strane -🙂,samo je motor ogromannn!
@storm Sta ti mislis?🙂 samo poceo je Senior da smara sa drekom!
to kao privezak za ostale potrebne kljuceve 😛
