kada pokrenem igru dobijem ovo:
guglao sam ali nisam nasao nista konkretno. kada ubacite u gugleta "could not load OpenGL subsystem" dobijete gomilu foruma gde ljudi kukaju i zale se na isti problem u OGL igrama ali koliko sam video, niko nije ponudio resenje
drajvere nisam menjao jer vidim da nije ni drugima to resilo problem. secam se da sam svojevremeno igrao igru bez problema, a sada nikako nece...ocigledno neki dll ili tako nesto pravi problem?!
any ideas?
masina je celeron na 1100Mhz i MX200 32MB sa drajverima 56.73...--- Common Initialization ---
Medal of Honor Spearhead 2.15 win-x86 Mar 4 2003
----- FS_Startup -----
Current search path:
C:\PROGRA~1\EAGAME~1\MOHAA\mainta\pak5.pk3 (9 files)
C:\PROGRA~1\EAGAME~1\MOHAA\mainta\pak4.pk3 (59 files)
C:\PROGRA~1\EAGAME~1\MOHAA\mainta\pak3.pk3 (311 files)
C:\PROGRA~1\EAGAME~1\MOHAA\mainta\pak2.pk3 (767 files)
C:\PROGRA~1\EAGAME~1\MOHAA\mainta\pak1.pk3 (6969 files)
C:\PROGRA~1\EAGAME~1\MOHAA/mainta
C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak7Nl.pk3 (102 files)
C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak5.pk3 (259 files)
C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak4.pk3 (593 files)
C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak3.pk3 (669 files)
C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak2.pk3 (4722 files)
C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak1.pk3 (772 files)
C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak0.pk3 (11175 files)
26407 files in pk3 files
execing default.cfg
execing buildver.cfg
execing menu.cfg
execing newconfig.cfg
execing localize.cfg
Config: unnamedsoldier.cfg
couldn't exec configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 39
You are now setup for medium mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 24, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...35 PFDs found
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
any ideas?
