Ovaj fon cekam ja da izadje,sredili su kameru,sada sasvim dobre fotke,plus vodootpornost
General 2G Network GSM 850 / 900 / 1800 / 1900 - all models
3G Network HSDPA 850 / 900 / 2100 - D2403
HSDPA 850 / 1700 / 1900 / 2100 - D2406
4G Network LTE 800 / 850 / 900 / 1800 / 2100 / 2600 - D2403
LTE 700 / 1700 / 1900 / 2100 / 2600 - D2406
SIM Micro-SIM
Announced 2014, August
Status Coming soon. Exp. release 2014, September
Body Dimensions 140 x 72 x 8.6 mm (5.51 x 2.83 x 0.34 in)
Weight 149 g (5.26 oz)
- IP68 certified - dust and water proof up to 1.5 meter and 30 minutes
Display Type IPS LCD capacitive touchscreen, 16M colors
Size 540 x 960 pixels, 4.8 inches (~229 ppi pixel density)
Multitouch Yes, up to 4 fingers
Protection Scratch-resistant glass
Sound Alert types Vibration; MP3 ringtones
Loudspeaker Yes
3.5mm jack Yes
Memory Card slot microSD, up to 32 GB
Internal 8 GB, 1 GB RAM
Data GPRS Up to 107 kbps
EDGE Up to 296 kbps
Speed HSDPA, 42 Mbps; HSUPA, 5.76 Mbps; LTE, Cat4, 50 Mbps UL, 150 Mbps DL
WLAN Wi-Fi 802.11 a/b/g/n, dual-band, Wi-Fi Direct, DLNA, Wi-Fi hotspot
Bluetooth v4.0, A2DP, apt-X, LE
NFC Yes
USB microUSB v2.0, USB On-the-go, USB Host
Camera Primary 8 MP, 3264 x 2448 pixels, autofocus, LED flash, check quality
Features Geo-tagging, touch focus, face and smile detection, HDR, panorama
Video 1080p@30fps, HDR, check quality
Secondary VGA, 480p
Features OS Android OS, v4.4.2 (KitKat)
Chipset Qualcomm MSM8926-2 Snapdragon 400
CPU Quad-core 1.2 GHz Cortex-A7
GPU Adreno 305
Sensors Accelerometer, proximity, compass
Messaging SMS (threaded view), MMS, Email, IM, Push Email
Browser HTML5
Radio FM radio with RDS
GPS Yes, with A-GPS, GLONASS
Java Yes, via Java MIDP emulator
Colors Black, White
- ANT+ support
- SNS integration
- Active noise cancellation with dedicated mic
- MP4/H.263/H.264 player
- MP3/eAAC+/WAV player
- Document viewer
- Photo viewer/editor
- Voice memo/dial
- Predictive text input
Battery Non-removable Li-Ion 2300 mAh battery
Stand-by Up to 595 h (2G) / Up to 641 h (3G)
Talk time Up to 11 h 23 min (2G) / Up to 12 h 11 min (3G)
Music play Up to 37 h 11 min
Tests Camera Photo / Video
Battery life
Endurance rating 71h
Review-Cliffdriver http://www.gsmarena.com/sony_xperia_m2_aqua-review-1124.php
SIM Micro-SIM
Loudspeaker Yes
3.5mm jack Yes
EDGE Up to 296 kbps
NFC Yes
Secondary VGA, 480p
GPU Adreno 305
Browser HTML5
Colors Black, White
- ANT+ support
- SNS integration
- Document viewer
- Voice memo/dial
Battery life
