zomg confirm...
So I can confirm that BIONZ for Mobile has made it into the new i1. It is a software based RAW->JPEG engine developed by the NEX/Alpha team for Krait architecture. The results are outstanding, noise is reduced and detail is kept and it also doesn't use too much compression like previous Sony phones, JPEGs on average are 20-30% larger than they would be with the older engine.
The engine could also be rolled out to Xperia Z/ZL with the next version of Android
Also, I just realised that Honami will get a much faster optical system that Nokia 808:
- Pixel pitch: Honami 1.7 micron, 808: 1.4 micron, so Honami has +47% of Pixel surface, so half a stop is gained here.
- Apperture: Honami F2, 808: F2.4, so about half a stop is gained here as well.
So approximately, there is about one stop gain in Honami compared to 808!!
Did I get something wrong?
Not only that, Back Illuminated surface gives it at least a 30% increase in light sensitivity over front illumination of the 808. so in theory, Honami's sensor should provide roughly 1 1/3 stop advantage, if we translate it on real life scenario, an ISO 3200 image from Honami would looks like ISO 1600 from the 808 with oversampling disabled of course
Auu kakva zbrka
Xperia KKRKZL
Sve je stalo jos juce, ko zna, mozda predstave sutra a mozda i za par nedelja.
Sad kao pominju da ce u Parizu predstaviti XZ ultra sa led flashom, znaci za EU i ostala trzista a ona bez kao samo za Kinu.. ma pise se svasta.
Neki cak tvrde da su videli 2 Honamija, fazon kao XZ (staklo/metal i vece dimenzije, IP55/58 itd) i XZL(alu/plastika i bez IP sertifikata ali uz mnogo manje dimenzije). Ili cak 2 modela u smislu da je jedan 5'' a drugi 4,3''..
Ovi sto su stvarno na bilo koji nacin imali pristup i1 ili bar softveru su ucutali jos pre 2 dana. To moze da znaci i da ce da predstave sutra ali i da je jos u fazi razvoja i peglanja softvera i da hoce da sprece curenje informacija..
Ja bih voleo da sto pre izbace IP 55/58, 4,3'' 720p triluminos model sa ovim senzorom iz glasina i xenonom. Pa makar i sa nekim brzim dual core-om i 1,5Gb rama, koji ce mi vise. Mada bi to onda znacilo ''samo'' 1080p kamkorder jer je za sve ostalo iz glasina stvarno potreban S800 cipset a i 2Gb rama.
Xperia i1 ZZ/ZZZL :d
Ali neverovatno koliko nemaju kesa za marketing, samsung da predstavlja ovako nesto organizovao bi onu njihovu kic prezentaciju koja vredja inteligenciju u trajanju od 48h :d
Ali sta se danas desilo??
Sta su najavljivali?
