»RSS Benchmark sajt
      Strana 1 od 27 1234511 ... PoslednjaPoslednja
      Prikazani rezultati od 1 do 15 od ukupno 394
      Tema: ZTE Blade G
      1. #1
        Member Avatar korisnika GiBo2pac
        Na forumu od
        Sep 2012
        Lokacija
        Banatsko Višnjićevo / Novi Sad
        Poruka
        5.938
      2. Moja mašina
        • CPU: AMD Ryzen r5 1600 + CM Nepton 280l+EK Vardar F3-140ER
        • MoBo: GIGABYTE AX370-GAMING 5
        • RAM: Kingston Hyper X Fury 8GB DDR4 - 2666MHz
        • VGA: ASUS R9 280X TOP V2 1180/1750MHz
        • MON: DELL P2417H
        • HDD: SSD Samsung 840 EVO 120GB + WD Blue 500GB + WD Red 1TB
        • Case: Fractal Design Define XL R2 Black Pearl, napajanje Thermaltake SPS730 - 730W
        • SND: Integrisana/2.0 Genius Wooden
        • OS: Win 10 Pro 64bit
        • LAP: HP ProBook 455 G1 - Win7 SP1 64bit Ultimate
        • TV: Samsung UE40 J5100
        • INET: Kablovska
        • Ostalo: /Nexus 6P / Stock+Root/ /Logitech G203 Prodigy/
      3. ZTE Blade G
        Vidim nema tema pa ajde da otvorim
        Brat je danas uzeo ovo čudo u Telenoru uz paket Play + M za 5940 din. Što nije loše za te pare
        Ne sviđa mi se 512mb rama, 640x480p video i neizmenjiva baterija, ali koliko para, toliko muzike.
        Evo nekih specifikacija :
        Dimensions
        (width x height x depth): 67 x 133 x 9.2 millimetres
        2.6 x 5.2 x 0.4 inches
        Bounding+Volume: 82 cubecentimetres
        Mass: 140 grams (battery included)
        Software;Environment
        Embedded:Operating+System: Google Android 4.1.2
        Browse devices running this OS
        Operating+System+Kernel: Linux
        Microprocessor,-Chipset
        CPU_Clock: 1200 MHz
        CPU: Qualcomm Snapdragon MSM8225
        Browse devices based on Snapdragon MSM8225
        Width:of:Machine-Word: 32 bit
        CPU-Core: 2x ARM Cortex-A5
        Instruction+Set: ARMv7-A
        Memory,_Storage-capacity
        RAM : type: LPDDR2 SDRAM
        RAM+capacity: 512 MiB
        ROM;type: Flash EEPROM
        ROM_capacity: 3814 MiB, including 1907MiB user-accessible non-volatile storage
        ROM:capacity:in:bytes: 4 GB (billion bytes)
        Graphical-subsystem
        Display+Type: color IPS TFT display
        Display-Diagonal: 4.5 " (114 millimetres)
        Display_Resolution: 480 x 854 (409920 pixels)
        Viewable;Display:Size: 2.2 " x 3.91 " (55.86 x 99.38 millimetres)
        Pixel-density: (dot:pitch): 218.3 pixel/inch (0.11637 millimetre/pixel)
        Graphical-Controller: Qualcomm Adreno 203
        Audio;Subsystem
        Audio;Channel(s): stereo sound
        Microphone(s): mono sound
        Loudspeaker(s): mono sound
        Audio;Output: 3.5mm plug
        Cellular;Phone
        Cellular;Networks: GSM900, GSM1800, GSM1900, UMTS900 (B8), UMTS2100 (B1)
        Cellular+Data:Links: GPRS, EDGE, UMTS, HSDPA, HSUPA
        Cellular;Antenna: Internal antenna
        Call+Alert: 64 -chord melody (polyphonic)
        Vibrating_Alert: Supported
        Speakerphone_: Supported
        Phone+Controller: Qualcomm MSM8225
        Control-Peripherals
        Positioning;Device: Multi-touch screen
        Primary:Keyboard: Not supported
        Directional;Pad: Not supported
        Scroll_Wheel: Not supported
        Interfaces
        Expansion_Interfaces: microSD, microSDHC, TransFlash
        Supports High Capacity (SD 2.0/HC) memory cards with capacity of up to 32GB
        USB: USB 2.0 client, Hi-Speed (480Mbit/s)
        USB Series Micro-B (Micro-USB) connector
        Bluetooth-(802.15): Supported, Internal antenna
        Wireless+LAN/Wi-Fi+(802.11): IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
        Internal antenna
        Infrared+Gate: Not supported
        Multimedia_Broadcast
        Analog-Radio: FM radio (87.5-108MHz) with RDS radio reciever
        Proprietary headset as antenna
        Digital_Media:Broadcast: Not supported
        Satellite-Navigation
        Built-in:GPS:module: Supported
        GPS_Protocol: NMEA 0183
        GPS-Antenna: Internal antenna
        Complementary-GPS:Services: Assisted GPS, QuickGPS, Geotagging
        Navigation+Chip(set): Qualcomm MSM8225 gpsOne
        Built-in+Digital-Camera
        Sensor+Type: CMOS sensor
        Resolution: 2592 x1944 pixels (5.04MP)
        Autofocus: (AF): Supported
        Optical_Zoom: 1 x
        Macro_Mode: Supported
        Built-in+Flash: mobile light (LED)
        Camcorder: 0x0 pixels
        Recordable-Image_Formats: JPG
        Recordable;Video+Formats: 3GP, 3G2, MPEG4
        Built-in+Secondary_Digital-Camera
        Sensor-Type: CMOS sensor
        Resolution: 640 x480 pixels (0.31MP)
        Camcorder: 640x480pixels
        Recordable:Image-Formats: JPG
        Recordable-Video:Formats: 3GP
        Power:Supply
        Battery+Technology: Lithium-ion battery
        Battery_Build: removable
        Battery;Capacity: 2000 mAh
        Additional-Details
        Built-in_accelerometer: Supported
        Additional-Features:
        capacitive touchscreen
        digital compass
        DLNA
        HSDPA 7.2
        HSUPA 5.76
        Bluetooth stereo audio profile (A2DP
        AVRCP)
        light sensor
        proximity sensor
        gyro sensor
        Datasheet;State: Preliminary specifications
        Datasheet;Views: 6629 times
        Datasheet+Added: May 4, 13 18:05:24
        Menjao GiBo2pac : 03.06.2013. u 19:17
        Albert Einstein -Mašta je važnija od znanja.Znanje je ograničeno, mašta okružuje svet!
      4. #2
        Member Avatar korisnika tolero
        Na forumu od
        Feb 2011
        Poruka
        3.065
        Posle zte grand x ovo bih bacio u đubre da mi neko pokloni. Kakav god da je
        Zte grand zapucava na svaki drugi poziv i jedino možeš da izvadiš bateriju i povratiš ga.
        Kakva je situacija sa ovim čudom kad ti zakuca a baterija ne može da se izvadi
        Menjao tolero : 03.06.2013. u 19:40
      5. #3
        Na forumu od
        Sep 2012
        Lokacija
        Poruka
        5.938
      6. Moja mašina
        • MON: DELL P2417H
        • INET: Kablovska
      7. Nemam pojma, burazer još nije ni uneo kontakte. Izgleda da ću i to morati da mu namestim
        Pisaću ovde ako krene da zapucava...
      8. #4
        Banned
        Na forumu od
        Jan 2010
        Lokacija
        krusevac
        Poruka
        752
      9. Moja mašina
        • CPU: Intel® Core™ i5-2500K,3.30GHz
        • MoBo: ASUS P8P67 B3
        • RAM: 2x4GB 1600MHz Patriot G2 Series CL9
        • VGA: Asus radeon hd 7870 2gb gddr5
        • MON: benq 2420 hdb
        • HDD: wd 320gb + 1tb wd
        • OPT: Samsung SH-S223C
        • Case: NZXT Tempest EVO, black- ocz 500w s/s
        • SND: altec 2.1
        • OS: windows 7
        • LAP: asus a52ju
        • TV: Samsung 40C650,LG 42PJ350,Samsung40D6000
        • INET: Kablovska
      10. Nisi u pravu za rezoluciju ,ima 480 x 854
      11. #5
        Na forumu od
        Sep 2012
        Lokacija
        Poruka
        5.938
      12. Moja mašina
        • MON: DELL P2417H
        • INET: Kablovska
      13. Pa napisao sam tako...
      14. #6
        Member Avatar korisnika Gizmoid
        Na forumu od
        Nov 2004
        Lokacija
        Doboj, R.S.
        Poruka
        1.651
      15. Moja mašina
        • CPU: Core2Duo T5800 2GHz
        • MoBo: Acer
        • RAM: Samsung 2GB 667MHz
        • VGA: Ati Radeon HD3650 512MB DDR2
        • MON: Acer 15,4" 1280x800
        • HDD: WD 250GB sata 5400 rpm
        • OPT: DVD-RW
        • Case: Acer Extensa 5630G
        • SND: Realtek HD Audio
        • INET: DSL
        • Ostalo: Acer Extensa 5630G-582G25Mn
      16. @dijabolik
        Menjao Gizmoid : 03.06.2013. u 20:58
        S ekranima na telefonima je kao i sa zenskim si*ama. Nema prevelikih,samo ima malih ruku)) by ChobbyNS
      17. #7
        Na forumu od
        Sep 2012
        Lokacija
        Poruka
        5.938
      18. Moja mašina
        • MON: DELL P2417H
        • INET: Kablovska
      19. Pa video, snima video u toj rezoluciji majku mu
      20. #8
        Na forumu od
        Nov 2004
        Lokacija
        Doboj, R.S.
        Poruka
        1.651
      21. Moja mašina
        • MoBo: Acer
        • OPT: DVD-RW
        • INET: DSL
      22. Do mene je, zaboravih postaviti prije recenice "@dijabolik" i pocrveneti i "video" .
        Edit: popravio sam.
        Menjao Gizmoid : 03.06.2013. u 20:59
      23. #9
        Member Avatar korisnika TosaNS
        Na forumu od
        Aug 2010
        Lokacija
        Novi Sad
        Poruka
        2.394
      24. Moja mašina
        • CPU: AMD FX-8320 3.5GHz
        • MoBo: MSI 970A-G43
        • RAM: Kingston DDR3 4 x 2Gb 1333Mhz
        • VGA: GeForce GTX660 MSI OC 2GB
        • MON: Dell
        • OPT: LG
        • Case: Blueberry CN-872BK sa napajanjem CHIEFTEC CTG-500-80P 500W
        • SND: Creative - Inspire P580 5.1
        • OS: Windows 7 Ultimate x64
        • INET: DSL
        • Ostalo: G110 + G9 :)
      25. Ja ovo neću ni da komentarišem samo ću da kažem zlo i naopako
        Soylent Green is people
      26. #10
        Banned
        Na forumu od
        Jan 2010
        Lokacija
        krusevac
        Poruka
        752
      27. Moja mašina
        • SND: altec 2.1
        • OS: windows 7
        • LAP: asus a52ju
        • INET: Kablovska
      28. Citat Citiram korisnika: GiBo2pac Pogledaj poruku
        Moja greska ,gledao sam ga danas u telenoru ,uzeo bih ga za klinca ,ali sve vise naginjem da uzmem lg l9 ,mora se malo vise dodati movca ,al sta je tu je.
      29. #11
        Na forumu od
        Sep 2012
        Lokacija
        Poruka
        5.938
      30. Moja mašina
        • MON: DELL P2417H
        • INET: Kablovska
      31. LG L9 je dosta bolji, ali bogami i skuplji...
        Edit:
        L9 uz play+M košta 25 800 din. a ovaj 5 940din, velika je to razlika...
        Menjao GiBo2pac : 04.06.2013. u 19:34
      32. #12
        Member
        Na forumu od
        May 2013
        Poruka
        2.221
      33. Moja mašina
      34. Ljudi pa pogledajte klip za zte blade g koji je postavio neki nas covek ,i pre neki dan je napisao da mu je otisao u servis a ima ga jedva dve nedelje
      35. #13
        Na forumu od
        Sep 2012
        Lokacija
        Poruka
        5.938
      36. Moja mašina
        • MON: DELL P2417H
        • INET: Kablovska
      37. Ako ovaj bratov počne da se gubi oma ga vraćamo
      38. #14
        Na forumu od
        Feb 2011
        Poruka
        3.065
        Pogledaj temu o zte grand x i vraćanju istog
        Jbt oni nisu normalni, šta ubacujete bre više taj zte krš u ponudu.
      39. #15
        Na forumu od
        Sep 2012
        Lokacija
        Poruka
        5.938
      40. Moja mašina
        • MON: DELL P2417H
        • INET: Kablovska
      41. Znam sve o tome ima drugarica taj telefon...
        Samo se nadam da neće biti ista priča isa ovim...
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
