На сваком телефону можеш да сурфујеш на једној а да будеш доступан за позиве на обе ... али кад једна почне разговор, онда друга постаје недоступна. Што се сурфа на обе тича, активни дуалсим имају поред осталог и два модема па може на оба. Видим да се помиње баш мали број оваквих телефона па је вероватно и цена пристојна.znači na ovim trenutnim kinezima, tipa prestigio itd. je moguće da surfuješ i radiš sinhronizaciju sa jednom karticom, a da istovremeno budeš dostupan na obe?
It is also known as Dual SIM Active (DSA) or Dual SIM Full Active (DSFA)
These phones have two RFs, two SIMs and two Modem Stacks hence it allows the device to be connected to both networks at the same time, hence simultaneously allow calls or datas to be received on either number at any given time.
Pros
The device can switch between two calls without dropping either, so while you are on a call you can still receive calls on the other number. These devices have two transceivers. Both SIMs are able to receive calls; once an active call on one SIM is established, a call can still be received on the other SIM. If the user likes, he or she can switch between two calls without disconnecting either of them.
Cons
All such phones have two transceivers built in, SIM1 may support 2G/3G while SIM2 may only support 2G to prevent interference and saving battery power.
Battery life (talk time and standby time) of active dual SIM mobile phones is reduced, typically by about a third. For instance, device manufacturer Samsung declares a 1/3 less standby time when used with two SIM cards.
Thicker based as to compensate for the shorter battery life, some dual SIM phones ship with better capacity batteries or these phones may also be supplied with two battery packs.
Higher retail cost due to higher demand in emerging market.
List of (DSA) Phone model
Most mid-range phone are using Snapdragon or Mediatek chipset.
Gigabyte GSmart Simba SX1
HTC T528w One SU/One 802, E1 603e, Desire 606w
Samsung B5722, B7722, Champ Duos E2652
ZTE U960
http://www.ebay.com/bhp/dual-sim-active
Ako neko ima licnih iskustava sa duals standby telefonima, neka napise par reci, pogotovo vezano za koriscenje interneta i dostupnost u tom momentu.Another issue with dual standby phones that support 3G is that, when the 3G / 2G network is used the other SIM becomes inactive. Usually you will not notice this issue with normal usage, but try downloading a big file or watch a streaming YouTube video, the other SIM will be unreachable.
Pozdrav, evo pokusacu da pomognem.
Pre godinu dana sam imao Galaxy S Duos ali sam zaboravio kako je funkcionisalo tamo.
A sada sam pre 2 dana kupio Jiayu G3T pa sam probao ovo sto si predlozio.
Ubacio sam MTS karticu na kojoj koristim 3g net i Telenor karticu na kojoj nemam interneta. Upalio sam video klip na yt i pozvao se na Telenor karticu i zvonilo je bez problema.
Zatim sam nazvao druga sa MTS kartice (rekao mu da saceka na vezi) i za to vreme sam sa fixnog pozvao Telenor karticu i rekose: "Zao nam je, ovaj poziv ne moze biti ostvaren."
Inace sam bio ubedjen da treba samo da kaze da sam zauzet. Ne znam jel ima veze sto sam probao sa fixnog :d
Javi ako te jos nesto zanima pa da probam
Inace je ovaj Jiayu dual standby.
Ja bih pre uzeo Xperiu C.
Samsung ko Samsung, i izgled i kvalitet izrade po meni nije nesto.
Xperia C ima bolju rezoluciju malo.
Xperia ima bolji procesor.
Xperia C ima jacu bateriju.
Xperia C je na 4.2 verziji Androida.
Grand ima vise interne memorije i podrzava veci Micro SD sto je meni recimo nebitno.
Ja nalazim SXC kod nas samo u radnjama za koje nikad nisam cuo - sto ce reci vecina sa "garancijom od 6 meseci"
Nasao sam cene u Dubai UAE http://souqmobi.com/mobiles/samsung-i9502-galaxy-s4/
Ima jos u Kini i Indiji za ostala trzista nisam jos nista nasao......
