»RSS Benchmark sajt
      Strana 1 od 19 1234511 ... PoslednjaPoslednja
      Prikazani rezultati od 1 do 15 od ukupno 275
      Tema: MSI AfterBurner: Overclocking reference based cards
      1. #1
        Member Avatar korisnika Zak81
        Na forumu od
        Sep 2008
        Lokacija
        Niš
        Poruka
        571
      2. Moja mašina
        • CPU: Intel G645
        • MoBo: MSI B75MA-E33
        • RAM: Patriot Signature 4GB DDR3 1333MHz
        • VGA: MSI GT630 4GB DDR3
        • MON: ViewSonic VX2739WM 27" 1080p
        • HDD: Mushkin Callisto Deluxe 60GB, WD 1TB EADS, WD 80GB JD
        • OPT: Lite-ON LH-20A1S Sata
        • Case: No Case
        • SND: SB X-Fi Extreme Music/Hi-Fi Speakers + Sub (5.1)
        • OS: Windows 7 x64 Ultimate
        • LAP: DELL N5010 R15
        • TV: Samsung 40D5500
        • INET: Kablovska
        • Ostalo: PS3
      3. MSI AfterBurner: Overclocking reference based cards
        Afterburner is powered by our own Rivatuner engine, but this software comes with a few extra's. AfterBurner will support both ATI and NVIDIA graphics cards, Voltage regulation on the GPU, overclocking on core, shader and memory domains, GPU load levels (ATI), fan speed adjustment, device information .. and a really wicked graphical (configurable) monitor.
        So with combined forces MSI will bring you their new AfterBurner overclock software. AfterBurner, as in giving that airplane an extra boost of power. The end-result (we feel) is a great looking user-friendly overclocking experience, with on-the-fly advanced user options .. including something I know many of you will like, VRM voltage control.
        * Overclocking:
        o Up to 85% overclocking capability
        o Over voltage function to significantly increase overclocking potential
        o Core/Shader/Memory clock adjustment
        o Core/Shader clock Link/Unlink capability
        * Monitor:
        o Clock/Voltage/Temperature/Fan Speed/Frame rate real-time monitor
        o Maximum/Minimum value for easy record of system condition
        o Real-time On-Screen-Display information in games
        o Real-time information in Windows Tray Icon
        o Detach mode for hardcore monitor style
        * Profile:
        o 5 Profile to easy save/load user customized setting
        o Profile hot-key for easy and quick switch in games
        o 2D/3D automatic profile switching for difference scenario
        * Special Function:
        o Advanced fan speed control for different speed under different temperature trigger points
        o Mutil-GPU independent or synchronous control for clock/voltage/fan speed
        o Information button for graphics card driver version, BIOS version, identification, OSD status and update link
        o User Customized skin function
        o Apply overclocking setting at system startup
        Please bare in mind that this software works with MSI graphics cards and a handful of reference based cards, you could be lucky though
        Menjao Paradigma : 14.11.2009. u 17:19
      4. #2
        Na forumu od
        Sep 2008
        Lokacija
        Niš
        Poruka
        571
      5. Moja mašina
        • CPU: Intel G645
        • Case: No Case
        • INET: Kablovska
        • Ostalo: PS3
      6. #3
        Member Avatar korisnika pixell
        Na forumu od
        Feb 2006
        Lokacija
        Éire
        Poruka
        2.144
      7. Moja mašina
      8. #RadeonRebellion against electrical safety
      9. #4
        Member Avatar korisnika sp@le
        Na forumu od
        Aug 2004
        Lokacija
        Novi Sad Vojvodina
        Poruka
        261
      10. Moja mašina
        • CPU: Intel i7 3820 Water cooled
        • MoBo: Asus rampage IV extreme
        • RAM: 16gb DDR3
        • VGA: crossfire ASUS 6870
        • MON: ViewSonic vx2433wm
        • HDD: patriot pyro se x2 raid 0 + WD 1001FALS 1tb
        • OPT: 2 x LG DVDRW
        • Case: Corsair Obsidian 800D Chiftec 750w CFT-750-14CS
        • SND: Creative x-fi titanium
        • OS: Windows 7 64bit
        • INET: Kablovska
        • Ostalo: Logitech g9x, Logitech Z5500 .....
      11. Citat Citiram korisnika: pixell Pogledaj poruku
        Kad se zavrsi instalacija i kad pokrenem program meni se zamrzne slika i pocne da pisti ...moram da restartujem ...
        Graficka je MSI 4870 1gb... nsita klokovano nije
      12. #5
        VIP member Avatar korisnika nikolas61
        Na forumu od
        Apr 2004
        Lokacija
        Čubura
        Poruka
        2.132
      13. Moja mašina
        • CPU: Intel Core i3-6320 , Prolimatech Megahalems
        • MoBo: ASUS ROG MAXIMUS VIII GENE
        • RAM: G.Skill Trident Z F4-3200C16D-16GTZ
      14. #6
        Member Avatar korisnika borab
        Na forumu od
        Jun 2000
        Lokacija
        Beograd
        Poruka
        8.701
      15. Moja mašina
        • CPU: I5 - 4460, Tx3 cooler AS5 pasta
        • MoBo: Gigabyte Z97- D3H
        • RAM: PC14200- HyperX Kingston Red 2x4Gb
        • VGA: Gigabyte GTX 760 OC, 2.0
        • MON: Samsung P2350
        • HDD: Samsung 840evo 128GB, Wdc 3TB Green x 2 kom
        • OPT: Lg GH22LS50
        • Case: LBX-03 B-B-B, CFT-750-14CS
        • SND: Realtek ALC1150 - onboard
        • OS: Win 8.1 pro. 64 bit - licenciran .
        • LAP: Hp - G7 , Del 3737, Win 7 pro. 32 bit - licenciran
        • TV: Samsung 40c650, fw 3017
        • INET: Kablovska
        • Ostalo: SGS 4 on Lp 5.0.1
      16. Lepo radi ovo parce softvera. I bey otkljucanog biosa, lepo se sloyio sa Eah5850. Terao sam ga do klokova 5870 i radi ok.
        Blade 350-Qx2 + APC 8 x 4.7 SF(P) + Spectrum Dx6i + SJ4000wifi
      17. #7
        Na forumu od
        Apr 2004
        Lokacija
        Čubura
        Poruka
        2.132
      18. Moja mašina
      19. MSI AfterBurner 1.40
        http://event.msi.com/vga/afterburner/download.htm
        Increase CCC limits
        !! This function has been disabled by default for safety reasons!
        Not responsible for your overclocking actions !!
        1. Go to installed directory of MSI Afterburner, default: C:\Program file\MSI Afterburner
        2. Use notepad to edit “MSIAfterburner.cfg”
        3. Change the parameter of “EnableUnofficialOverclocking” from “0” to “1”.
      20. #8
        Member Avatar korisnika Rapture
        Na forumu od
        Aug 2008
        Lokacija
        Kg
        Poruka
        3.066
        Takodje bez otkljucanog bios-a, na sapphir-u sa "0 to 1", pici na 1ghz.
      21. #9
        Na forumu od
        Apr 2004
        Lokacija
        Čubura
        Poruka
        2.132
      22. Moja mašina
      23. Menjao nikolas61 : 27.11.2009. u 07:23
      24. #10
        Member
        Na forumu od
        Jun 2009
        Poruka
        117
      25. Moja mašina
        • CPU: AMD Athlon x2 7750BE
        • MoBo: Biostar TA790GXB A2+
        • RAM: 2GB KingMax DDR2 1066MHz
        • VGA: MSI 4670
        • MON: BenQ G2420 HDBL
        • HDD: WD 640GB + 1TB
        • Case: kinez
        • INET: Kablovska
      26. Kako da proverim da li mu "odgovara" overclock, tj.da li će zapucavati?
        Imam MSI 4670 i pomoću CCC sam podigao GPU sa 750 na 800 a memory 873 na 900 i neće preko toga. E sa ovim Afterburn prog.sam memory clock podigao na 1000 i želim da proverim da li može. Drugo pitanje je zašto ne mogu da podignem Core clock, stoji mi na 800 i kada pomerim klizač na npr.850 i kliknem apply, on vrati na 800?
      27. #11
        Member
        Na forumu od
        Sep 2008
        Poruka
        2.514
      28. Moja mašina
        • CPU: AMD Phenom 1075T sa Thermalright true
        • MoBo: msi 970a g45
        • RAM: 2x4gb Transcend 2000MHz
        • VGA: gigabyte 6850
        • MON: samsung t220
        • HDD: Samsung SSD 830 128GB + 2x2TB WD Green
        • Case: chieftec big tower,Chieftec cft750c modularno
        • INET: DSL
      29. probaj furmark ili propusti vise krugova 3dmark i to onaj deo koji koristi grafiku ili crysis test par krugova
      30. #12
        Na forumu od
        Aug 2008
        Lokacija
        Kg
        Poruka
        3.066
        Citat Citiram korisnika: FilipV Pogledaj poruku
        Pogledaj sedmi post,iznad...
      31. #13
        Na forumu od
        Jun 2000
        Lokacija
        Beograd
        Poruka
        8.701
      32. Moja mašina
        • OPT: Lg GH22LS50
        • INET: Kablovska
      33. I dokle ste sa standardnim hladjenjem terali 5850 ?
        Koliko ste povecali fan speed?
        Koja je tada max gpu bila?
        Ima li smisla toliko silo*anje za svaki dan?
      34. #14
        Member Avatar korisnika bole083
        Na forumu od
        Aug 2007
        Poruka
        609
      35. Moja mašina
        • CPU: q9650 E0 @ 4001mhz , corsair h50
        • MoBo: ASUS maximus 2
        • RAM: 4 gb @ 1066 cas 5
        • VGA: ati 6950 unlocked to 6970
        • MON: 223bw
        • HDD: OCZ VERTEX 2
        • OPT: nemam
        • Case: gigabyte auroara 3d
        • OS: win7 ultimate x64
        • INET: DSL
      36. Svaki dan setup : 975 / 1200 na 1.2 V ... Kriza zna da je ugrije , ali mi se memorija grije i po 10 stepeni više od core . Core sa mojim fan profilom nije prešao 70 , ali kriza zna da mi zaglavi komp i na 65 , e sad nisam siguran zasto se ovo desava. E jos jedna stvar grijanje ploče je znatno pojačano ubacivanjem 5850 , pored 8800gt koja radi fiziku , ali tome dosta kumuje i činjenica da e8500 na 4050 i FSB od 1800 ferceraju u sistemu . Inače NB je u idle 65 - max load 75 ...
        Sa mnom strase malu djecu!
      37. #15
        Na forumu od
        Jun 2000
        Lokacija
        Beograd
        Poruka
        8.701
      38. Moja mašina
        • OPT: Lg GH22LS50
        • INET: Kablovska
      39. Citat Citiram korisnika: bole083 Pogledaj poruku
        Ajd sad u detalje, ako moze, ili da bude sticky, detaljno uputstvo za ati + nvidia ( fizika ). Koji driveri, kojim redom itd. Znaci, tvoje iskustvo ne c/p sa neta.
      Bookmarks
      Dozvoljeni tagovi
      • Ne možete odgovoriti u temi
      • Ne možete okačiti atačmente
