Strana 2 od 2 PrvaPrva 12
Prikazani rezultati od 16 do 29 od ukupno 29
Tema: Athlon X2 4000+ Brisbane
  1. #16
    Member Avatar korisnika moca87
    Na forumu od
    Jan 2007
    Lokacija
    Novi Beograd - Bezanijska kosa
    Poruka
    305
  2. Moja mašina
    • LAP: Asus N73-SV
    • INET: Wifi
  3. Znam na sta se odnosilo pitanje,ali kakve veze ima sto je FSB 334MHz?Ako je dobra ploca,to nije nikakav problem i ako se proc lepo slaze sa memorijom.
    Nema bas puno primeraka na 3GHz ali znam da ih je bilo,kad sam ja uzeo taj proc.
    Menjao moca87 : 10.12.2007. u 23:36
    Some say that his voice can only be heard by cats, and that he is banned from the city of Chichester. All we know is... he's called The Stig
  4. #17
    Member Avatar korisnika The Philosopher
    Na forumu od
    Oct 2005
    Lokacija
    Chubura
    Poruka
    571
  5. Moja mašina
    • CPU: Intel Celeron G540 2.5GHz
    • MoBo: MSI H61M-P20 (G3)
    • RAM: Patriot Signature 4GB DDR3 1333MHz
    • VGA: MSI 7750 1GB GDDR5 OC V2
    • MON: 20" LG L204WT 1680x1050
    • HDD: Samsung F3 HD103SJ
    • OPT: Nema
    • Case: Frontier Trendsonic
    • SND: Onkyo Integra A-809 + DX-6870 + Jamo Classic 8 + Sennheiser HD 201
    • OS: Windows 7 Ultimate SP1 x64
    • LAP: Lenovo G770 17.3" i3/4GB/500GB
    • INET: Kablovska
  6. Citat Citiram korisnika: (po)cetnik Pogledaj poruku
    A na kom naponu?
    1.37V
  7. #18
    Member
    Na forumu od
    Jan 2007
    Lokacija
    Šabac
    Poruka
    300
  8. Moja mašina
    • CPU: Phenom II X4 955BE, Gelid Tranquillo Rev.2 + Alpenföhn Föhn 120 purple LED
    • MoBo: Biostar TA970XE
    • RAM: Exceleram EBW301A 2x4GB
    • VGA: Sapphire 5750 700/1000 > 870/1250, S1
    • MON: Samsung 2243NW
    • HDD: Seagate Barracuda 500 GB, WD RE2 500GB, WD 5000AAKS, WD2500AAJS
    • OPT: Samsung 18x, Plextor Premium
    • Case: TrendSonic Wizard wi20A & Enermax Pro87+ 500W
    • SND: X-Fi XtremeGamer Fatal1ty Pro modded (hardware)
    • OS: Win7 64bit
    • LAP: Toshiba Satelite (mator ali pouzdan)
    • INET: Wifi
    • Ostalo: Corsair SURVIVOR 8GB, G300
  9. Citat Citiram korisnika: moca87 Pogledaj poruku
    Velike, retko ko drzi Orleans za svaki dan preko 300.
    Izgleda da me koci ovaj GeIL Ultra.
    Ionako cu u narednom periodu (mesec-dva-tri) da uzmem X2 4000+ tako da mi je ovih 2520 dosta za sada...
  10. #19
    Na forumu od
    Jan 2007
    Lokacija
    Poruka
    305
  11. Moja mašina
    • LAP: Asus N73-SV
    • INET: Wifi
  12. Citat Citiram korisnika: zoki.d Pogledaj poruku
    Zbog toga sam i ja odustao od daljeg mucenja Orleansa
  13. #20
    Member Avatar korisnika shoma
    Na forumu od
    Sep 2006
    Lokacija
    RS, Banja Luka
    Poruka
    1.148
  14. Moja mašina
    • CPU: Phenom II X4 B50 @ 3.7GHz AC Freezer 64 Pro
    • MoBo: GA MA790X-UD4
    • RAM: KingMax 2x1GB DDRII 800MHz + OCZ 2x1GB 800MHz
    • VGA: VTX HD5770
    • MON: Samsung T190
    • HDD: 2x WD Caviar SATAII 250GB RAID 0; WD Green 1TB EARS
    • OPT: Pioneer DVD-RW DVR-112D
    • Case: Blueberry BC-G52; Mode Com 500W PSU
    • SND: X-Fi XtremeMusic / Genius SW-HF 5.1 5050
    • OS: W7 x64 Ultimate
    • LAP: Asus A53U
    • INET: DSL
    • Ostalo: Sky Star2 v2.6 D, Logitech LX8 Samsung I5500 CyanogenMod
  15. Imam mali problem sa klokovanjem ovog procesora. Digao sam ga na 3GHz i 3Dmark05 mi prodje bez problema ali orthos puca, ja smanjim na 2.9GHz ali mi opet puca orthos. Napon drzim na 1.376 ali i kad ga povecam isto se desava. Nekad pukne nakom 30 sec a nekad nakon par minuta. Nevjerujem da je do memorije jer je radila i na vecoj frekvenciji a HT drzim na 840MHz. Temperatura CPU je oko 47C.
    Ako vam ide suvise lako, pogledajte bolje. Mozda vam ide nizbrdo.
  16. #21
    Member
    Na forumu od
    Jul 2007
    Lokacija
    PK,Nish
    Poruka
    1.237
  17. Moja mašina
    • CPU: AMD athlon X2[Black Edition] 5000+@3160MHz / CM HyperTX2
    • MoBo: Biostar "TA690G" [316MHz X 10]
    • RAM: 4GB
    • VGA: Palit "8800GT Sonic" /512MB DDR3/ @736/1802/2090 - ona najruznija
    • MON: Acer "AL2216Ws" /22"lcd/ - i on je ruzan
    • HDD: Western Digital "Caviar 6400AAKS"/640GB/ & Seagate "Barracuda" /160GB/
    • OPT: TSSTcorp. CD/DVDW SH-S128D
    • Case: Antec Nine Hundred & Corsair "HX520W modular"
    • SND: Realtek ALC888- integr / Altec Lansing "VS2421"
    • INET: DSL
    • Ostalo: Win7/XP
  18. Citat Citiram korisnika: shoma Pogledaj poruku
    Koji test,blend ili samo za proc?Prioritet?
    Menjao vdr1981 : 11.12.2007. u 18:40
  19. #22
    Na forumu od
    Sep 2006
    Lokacija
    RS, Banja Luka
    Poruka
    1.148
  20. Moja mašina
    • VGA: VTX HD5770
    • MON: Samsung T190
    • LAP: Asus A53U
    • INET: DSL
  21. Pustio sam prvo Small FFTs a prioritet 10 poslije sam prebacio na blend i prioritet 1 ali opet isto.
  22. #23
    Member
    Na forumu od
    Jul 2007
    Lokacija
    PK,Nish
    Poruka
    1.237
  23. Moja mašina
    • RAM: 4GB
    • INET: DSL
    • Ostalo: Win7/XP
  24. Mozda je to ipak preveliki zalogaj za taj procesor.Orthos na 10-ki brzo razbija sve iluzije,zar ne?
    I ja sam imao skoro identicnu situaciju,izvucem 3dmarkove ali "Orthos kaze"smanji malo".Radice on mozda na 3GHz ,samo nemoj da te zacudi kada ti se u sred igrice zaplavi pred ocima.
    Mada,mozda je i do memorije...Int.mem.kontroler je chudo,radi kako mu se cefne.
  25. #24
    Na forumu od
    Sep 2006
    Lokacija
    RS, Banja Luka
    Poruka
    1.148
  26. Moja mašina
    • VGA: VTX HD5770
    • MON: Samsung T190
    • LAP: Asus A53U
    • INET: DSL
  27. Evo maloprije sam smanjio na 2,8GHz i prolazi orthos. Nista probacu jos malo da se mucim valjda cu nesto da uspijem. Vidim da dosta njih drzi proc na 2.9 i 3GHz pa bih i ja zelio da ga potjeram toliko. Nekako mi lijepo kad vidim da je proc na 3GHz
  28. #25
    Member
    Na forumu od
    Jul 2007
    Lokacija
    PK,Nish
    Poruka
    1.237
  29. Moja mašina
    • RAM: 4GB
    • INET: DSL
    • Ostalo: Win7/XP
  30. Citat Citiram korisnika: shoma Pogledaj poruku
    Lepa cifra,nema shta ,okrugla.Imash uslove,dobra ploca,memorija...Eksperimentishi.
  31. #26
    Member Avatar korisnika Jovandeka
    Na forumu od
    May 2007
    Lokacija
    Змајево Гнездо, околина НС
    Poruka
    449
  32. Moja mašina
    • CPU: A64 7750 BE
    • MoBo: Biostar 790
    • RAM: 4Gb DDR800
    • MON: Benq2420HDB
    • HDD: WD 320GB SATA
    • OPT: DVD/RW LG + Pioneer DVD
  33. Ево и ја мога потерах преко тројке! Данас је радио читав дан и није правио проблеме... тестирао сам га само са Еверестом...можда би могло и више - нисам пробао...
    Мало ме буни моја меморија... наиме, имам 2х512 Transcend и 1х1024 Kingmax, све то на 800... када сам пробао са 2х1024 Kingmax резултати су били смешни - мислим да је било до неких 20%... других модула немам да бих експериментисао...
    Menjao Jovandeka : 22.01.2008. u 22:21
  34. #27
    Member
    Na forumu od
    Jul 2007
    Lokacija
    PK,Nish
    Poruka
    1.237
  35. Moja mašina
    • RAM: 4GB
    • INET: DSL
    • Ostalo: Win7/XP
  36. Dobri vam ti "Biostari-i".Ja kad bih stavio toliki FSB istopio bih i ovo malo rebara shto je ostalo na chipsetu(pola se vec istopilo).
  37. #28
    Na forumu od
    Jan 2007
    Lokacija
    Poruka
    305
  38. Moja mašina
    • LAP: Asus N73-SV
    • INET: Wifi
  39. Da l' je moguce da je zbog Dual chanel-a tolika razlika u rezultatu ili je to do Everesta?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  40. #29
    Na forumu od
    May 2007
    Lokacija
    Poruka
    449
  41. Moja mašina
    • CPU: A64 7750 BE
    • MoBo: Biostar 790
    • RAM: 4Gb DDR800
    • MON: Benq2420HDB
  42. Сигурно да утиче и сингл-дуал ченел, али и тајминзи 4-4-4-12 као и ''кохабитација'' плоче и меморије...
Bookmarks
Dozvoljeni tagovi
  • Ne možete odgovoriti u temi
  • Ne možete okačiti atačmente
