Da i Office 2013 je imao click to run setup, doduse i obicnom setup-u je mogao da se prosledi config koji je bio malo drugaciji ili da se koristi OCT. Dakle samo se click-to-run setup fajlu /configuration parametru prosledi putanja do xml-a koji izmedju ostalog sadrzi npr
<Product ID="ProplusRetail">
<Language ID="en-us" />
<ExcludeApp ID="InfoPath" />
<ExcludeApp ID="SharePointDesigner" />
<ExcludeApp ID="Publisher" />
<ExcludeApp ID="OneNote" />
<ExcludeApp ID="Access" />
</Product>
Hvala za info. Nemam team wiever instaliran.Meni se jednom desilo, ali nisam video nigde resenje, ukljucujuci M$ podrsku. "Svesni su problema", ali resenje jos uvek nemaju. Imas li instaliran TeamViewer, imam teoriju da je on kod mene bio krivac?
PCI\VEN_8086&DEV_8C02&CC_0106.DeviceDesc = "Intel(R) 8 Series/C220 Chipset Family SATA AHCI Controller"
PCI\VEN_8086&DEV_8C03&CC_0106.DeviceDesc = "Intel(R) 8 Series Chipset Family SATA AHCI Controller"
PCI\VEN_8086&DEV_8C82&CC_0106.DeviceDesc = "Intel(R) 9 Series Chipset Family SATA AHCI Controller"
PCI\VEN_8086&DEV_8C83&CC_0106.DeviceDesc = "Intel(R) 9 Series Chipset Family SATA AHCI Controller"
PCI\VEN_8086&DEV_9C02&CC_0106.DeviceDesc = "Intel(R) 8 Series/C220 Chipset Family SATA AHCI Controller"
PCI\VEN_8086&DEV_9C03&CC_0106.DeviceDesc = "Intel(R) 8 Series Chipset Family SATA AHCI Controller"
PCI\VEN_8086&DEV_9C82&CC_0106.DeviceDesc = "Intel(R) 9 Series Chipset Family SATA AHCI Controller"
PCI\VEN_8086&DEV_9C83&CC_0106.DeviceDesc = "Intel(R) 9 Series Chipset Family SATA AHCI Controller"
PCI\VEN_8086&DEV_9D03&CC_0106.DeviceDesc = "Intel(R) 6th Generation Core Processor Family Platform I/O SATA AHCI Controller"
PCI\VEN_8086&DEV_A102&CC_0106.DeviceDesc = "Intel(R) 100 Series/C230 Chipset Family SATA AHCI Controller"
PCI\VEN_8086&DEV_A103&CC_0106.DeviceDesc = "Intel(R) 100 Series/C230 Chipset Family SATA AHCI Controller"
PCI\VEN_8086&DEV_8D02&CC_0106.DeviceDesc = "Intel(R) 9 Series Chipset Family SATA AHCI Controller"
PCI\VEN_8086&DEV_2822&CC_0104.DeviceDesc = "Intel Chipset SATA RAID Controller"
PCI\VEN_8086&DEV_282A&CC_0104.DeviceDesc = "Intel Chipset SATA RAID Controller"
Preko telefona radi, preko računara ne
Obični korisnici imaju 10240 (regularna verzija) samo, sve drugo je za insidere, negde u oktobru treba da izađe novi build.Ovaj novi build je za insajdere nije jos RTM za nas obicne korisnike ?
Pogledajte prilog 179987
Ljudi moze pomoc.. Nzm sta da radim.. Komp radi 3-4h super, i posle samo zakove, nece nista, samo se ovo pojavljuje, samo pomaze da ga iskljucim.. 10547 je.. Ni jedan problem nisam imao pre ovoga, pocelo je sve od ove verzije Windows-a.. :/
Uz pomoć Insider programa, ostali će znati šta ih čeka.@countmike, build za insajdere ili nas koji smo "obični" korisnici? za metar dana...brzo će to
+1odlično radi , a samo povremeno imaš BSOD ??!! da nemaš malo preniske kriterijume ?
Jel to pitanje ili šta? Ako je sarkazam u pitanju, ne radi se o tome da neko ne zna uključiti ili isključiti auto arrange, nego se jednostavno pojavi tako, iako je opcija isključena.Neko ima slican problem da ne moze da iskljuci auto arrange icons?
zasto ?@prijatelj.v
Mhm...
Intel G41tm P33 ploca, Amd Hd5450, 2gb ram-a, Intel E3300 2.5Ghz proc........ Jos nesto?
Skidam 10240 I izasao sam iz insajdera..
